Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 03-19-2017, 13:14   #1 (permalink)
Member: 1420095
Thanks Meter: 216
G710S Screen Lock Help! (Still LOCK)
Using Version...1.0.0.0043
Selected Port ssudmdm0000 = COM3
Selected Model SM-G710
Selected Task SAMSUNG EE-LOCK Remove
Searching phone...
Init ok..
Samsung EE Lock Removed..
!!! Success !!!!
Restart Phone if not auto...
Total Time Take...00:00:16
https://ibb.co/iCyeBF
Old 03-19-2017, 13:36   #2 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,275
its not ee lock ..
this problem have another solution ..
is this Korean Samsung mobile?
Old 03-19-2017, 14:08   #3 (permalink)
Member: 1420095
Thanks Meter: 216
Yes it is Korean version..
Model G710S
Sent from my iPhone using Tapatalk
Old 03-19-2017, 14:09   #4 (permalink)
Member: 1420095
Thanks Meter: 216
Originally Posted by malka4u View Post
its not ee lock ..
Your Help is much appreciated..
Thank you!!!
Old 03-19-2017, 14:50   #5 (permalink)
Member: 2339843
Thanks Meter: 1,450
It's easy bro...just flash twrp...then mount data and system when u boot into twrp recovery..connect phone to pc and remove pattern adb...phone will reboot and after that you're good..post results
Old 03-19-2017, 15:38   #6 (permalink)
Member: 1420095
Thanks Meter: 216
I cannot find twrp for this korean model.. tried G710 twrp but didnt work. If u have link can u share?
Old 03-20-2017, 00:09   #7 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
So u still can not find solution right?
Old 03-20-2017, 01:48   #8 (permalink)
Member: 1420095
Thanks Meter: 216
Not yet sir!
Old 03-20-2017, 01:59   #9 (permalink)
Member: 2339843
Thanks Meter: 1,450
Just select remove pattern modem,you will need phone to be on play with emergency call keeping screen active while execute with gc pro..
Old 03-20-2017, 02:06   #10 (permalink)
Member: 1420095
Thanks Meter: 216
This did not work either.. tried and it failed..
Old 03-20-2017, 02:29   #11 (permalink)
Member: 2339843
Thanks Meter: 1,450
G710s screen lock
What os on it?i try to find.other solution for u
Old 03-20-2017, 02:30   #12 (permalink)
Member: 1420095
Thanks Meter: 216
4.4.4
Old 03-20-2017, 02:34   #13 (permalink)
Member: 2339843
Thanks Meter: 1,450
Ok here is what youre going to do,go on playstore with the device and install the official twrp app on the phone,execute operation and then follow procedure one that i gave you...contact me on.skype here it takes a while to get messages...send me request..
Old 03-20-2017, 02:55   #14 (permalink)
Member: 1420095
Thanks Meter: 216
Bro.. phone has screen lock and no access to home screen.. custom recoveries are nowhere to be find.
Old 03-20-2017, 09:18   #15 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
@himig_natin
Hello
Please flash frp zip from support links.
If your phone is qcom/qualcomm flash frp_qcom.zip (if exynos frp_exynos.zip) with gcprogsmtool- >sam flash zip
Do not extract zip just select as it.
If flashing is successful it will restart phone and menu/setting should be accessible.
Use basic steps like oem unlock enable - > factory reset from setting etc.
Post your result.
@ziggywong0305
Hello
Please if you do not know how to help people in there section do not post crap here about other tools. i have already deleted your many post regarding other tool advertisements..
Please this is last warning if you want to support other tool do on there section not here.This is GCProKey section if you don't know how to do then don't reply.
Page generated in 0.19841 seconds with 8 queries
