11-13-2015, 17:54 | #3 (permalink) |
Banned Join Date: Nov 2015
Member: 2485949 Status: Offline Thanks Meter: 11 | You have to solve the stuck on samsung screen issue first before you can fix the DRK. You have to be in normal mode. To get it into normal mode you need to flash the firmware without the cache portion of it. So extract the cache portion of the rom and flash everything else. It will then boot up into normal mode and then you can work on DRK issue. You really do not need the modem or recovery portions either. To make it simple just flash sboot, cm, boot and system portions of rom. |
11-13-2015, 19:07 | #4 (permalink) | |
Freak Poster Join Date: Jul 2008 Location: Redlands Ca Age: 49
Member: 810122 Status: Offline Thanks Meter: 65 | Quote:
how do i remove 1 item out of the tar file ? | |
