12-05-2018, 22:14 | #1 (permalink) |
Freak Poster Join Date: May 2018 Location: Baku Age: 37
Member: 2836410 Status: Offline Thanks Meter: 99 | G920V IMEI Repair- Done! 1. Connect phone to any other box via UART Cable C330K 2. Select Box ComPort 3. Select MEIDCERT Write operation 4. Select your cert file and DONE! PS 1. If you need dial *#7284# (to activate UART, but by default it already activated), you need root, because USSD codes not work on this devices, so Verizon disabled it. For root, visit this link. PS 2. I tested it on G920VVRU4BOK7-5.1.1, then upgrded to latest Nougat without lose cert. I think this operation work on Nougat too, just test it, otherwise downgrade to Lollipop without any risk. |
The Following User Says Thank You to Rauf86 For This Useful Post: |
12-06-2018, 10:14 | #2 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @Rauf86 Hello You should post log to confirm your success to other users. You do not need this step or rooting. rooting may make phone warranty void and this will trigger knox void flag on latest firmware if knox is void will not allow you to rewrite cert. Quote:
The Following User Says Thank You to stanner_austin For This Useful Post: |
12-06-2018, 13:26 | #3 (permalink) | |
Member: 2836410 Status: Offline Thanks Meter: 99 | Quote:
Thank you for advice, it was very useful. And when root with this method that described in link, knox will not void. And please tell, can GCPro key write cert to J530FM with U5 binary and how? | |
