Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 02-08-2018, 21:22   #1 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,645
Thumbs up G920V Pinlock remove done 7.0
Using Version...1.0.0.0054
Selected Model GT-I5500
Selected Task GTALK REMOVE SAFE
Searching ADB device Please wait..
Device Detected...
Security:= OFF Unsecure device
SELinux := Enforcing
model:= SM-G920V
Androids Version:= 7.0
Description Version:= zerofltevzw-user 7.0 NRD90M G920VVRS4DQE1 release-keys
Platform:= exynos5 [ samsungexynos7420 ] [ MDM9635M ]
Baseband:= G920VVRS4DQE1
VER:= G920VVRS4DQE1/G920VVZW4DQE1/G920VVRS4DQE1/G920VVRS4DQE1
Carrier := VZW_USA
EFS CSC := VZW
Knox Warranty := Not Void
AP UART Status := Enable Already.
Security Patch := 01-05-2017
Simstatus:= READY
ANDROID-ID = 0715f70c9acc0a36_00007975C4
Device is Unsecure Rooted
Repair Gtalk/pattern/lock code started..
Access Found Type 1.
Clearing Locks.
Repair Success..
Restart Phone if not done Auto...
Total Time Take...00:00:12
Log Saved
The Following 3 Users Say Thank You to ghacks For This Useful Post:
Old 02-09-2018, 20:14   #2 (permalink)
Member: 2309595
Thanks Meter: 112
Thanks for the report.
For everyone who dont know, you need to flash Eng Boot in order to have root and ADB then use GCPro to remove the password
Phone must be turn on at normal mode that mean regular turn on ( not by recovery like TWRP or any other state like ODin)
Device Detected...
model:= SM-G920V
Carrier := VZW_USA
EFS CSC := VZW
Simstatus:= READY
Clearing Locks.
Repair Success..
Log Saved
Old 02-10-2018, 00:58   #3 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,645
Talking for the info
bro my advise need root by engroot because he will enable usb debug and rooted phone give access with inside partition phone GC KEY can do the job easily without using twrp after can do but u can use twrp if u dont have engroot after root by engroot its easy to play by GC key .
this method already available from XDA
https://forum.xda-developers.com/and...overy-t3530008
Old 02-11-2018, 19:25   #4 (permalink)
Member: 2802156
Thanks Meter: 173
How about bypassing secure startup on phones like s7 s8 note 8?
Old 02-11-2018, 20:44   #5 (permalink)
Member: 2309595
Thanks Meter: 112
You forgot the android 7.0 and up encrypted the data already my friend. So the TWRP cant access the data
The XDA method with TWRP only work for NON ENCRYPTED PHONES. You sure can use ADB command to do the job as well as GCPro but I prefer GCPro.
Old 02-11-2018, 20:46   #6 (permalink)
Member: 2309595
Thanks Meter: 112
Sorry for my noop but first time ever heart about secure start up. Maybe we use different term?
You mean lock screen?
Old 02-11-2018, 21:08   #7 (permalink)
Member: 2802156
Thanks Meter: 173
Secure startup is a lockscreen but not the regular lockscreen, its a setting on newer firmwares 7.0+
Secure Startup - Samsung Galaxy Note 7 User Guide
Old 02-12-2018, 20:36   #8 (permalink)
Member: 2309595
Thanks Meter: 112
This is active encrypted. cant do anything for now. If I'm not wrong.
The encryption work this way.
1. Hardware encrypted key. That mean the phone automatic decrypted when the hardware ID match when you turn the phone on. Therefore, if you bring the SSD to another identical board then the data is not readable. This is most Android 7.0 and up is using by default. In this method of encryption, the phone was decrypted when the phone complete booted
2. Software encryption key, the phone will be decrypted with the password. Therefore even when the hardware ID match the phone still be encrypted state until the correct password was entered. in this method, the phone still in encrypted mode even when it complete booted.
THIS IS DEAD END. NO LOOP HOLE IF SAMSUNG DO ENCRYPTION CORRECTLY
MAYBE if you can pull the whole raw data out of the phone and look somewhere inside, you may find a encrypted key/string because this is in decrypted. but it may take years because they are millions key/string
The Following User Says Thank You to matthew.ebay For This Useful Post:
Page generated in 0.22567 seconds with 8 queries
