12-10-2017, 18:49 | #1 (permalink) | |
Insane Poster Join Date: May 2009
Member: 1041728 Status: Offline Thanks Meter: 3 | G920V Samsung Account Removal Fail!!(solved) Quote:
12-10-2017, 20:26 | #3 (permalink) |
Member: 1041728 Status: Offline Thanks Meter: 3 | Using Version...1.0.0.0052 Selected Port Com:4 Selected Model SM-G920V Selected Task SAMSUNG_FRP_UFS Searching phone... Device Found.. MODEL=SM-G920V;UN=0915F981793A0703;CAPA=32;VENDOR=SAMSUNG;F WVER=0200;PRODUCT=KLUBG4G1BD-E0B1;PROV=PASS; Init ok.. Press VOLUME DOWN and Power ON for few sec.. Device detected.. Release power.. Release Volume Down.. Fail to setup device may fail... Fail Unsupported BOOTLOADER for FRP_UFS... !!! Success !!!! Phone Restarted... Total Time Take...00:02:42 Log Saved |
12-10-2017, 22:11 | #10 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Try flashing combination and see if you can root it( mostly combination has old os inside,try kingroot apk or any other root procedure). After that try gc pro remove reactivation lock. In past i did root some mobiles having combination os inside. But I'm not sure about Verizon Variant. Try your luck. |
12-11-2017, 09:43 | #13 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @playa4life352 Hello Recheck steps if steps are wrong results is same. If still same flash same rev combination bootloader and do again. We will improve RLOCK ADB soon to support all 64bit device.. at present it was only supporting 32bit @zishhaider Hello You are wrong. GCPro support FRP_UFS will remove FRP/REACTIVATION/EELOCK same time. |
The Following 2 Users Say Thank You to stanner_austin For This Useful Post: |
12-15-2017, 08:19 | #14 (permalink) | |
Member: 1041728 Status: Offline Thanks Meter: 3 | Quote:
Thanks I got it working with FRP_UFS I flashed eng root, combination, and nothing worked. I reflashed stock QJ1, then it worked when I held volume and power down for EXACTLY 5 seconds. First try | |
The Following User Says Thank You to playa4life352 For This Useful Post: |
