08-06-2016, 06:56 | #1 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Minneapolis MN USA
Member: 1815016 Status: Offline Thanks Meter: 77 | G925T PF1 Cert Write Fail Selected Port ssudmdm0000 = COM80 Selected Model SM-G925T Selected Task SAM CERT WRITE ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := G925T VER := G925TUVU4EPF1/G925TTMB4EPF1/G925TUVU4EPF1/G925TUVU4EPF1 Phone IMEI := 35774xxxxxxx Default MSL NO NEED RESET EFS... MSL Autho Pass.. Unknown reply:= NDhfNEZfMTBfRF8xMF8xMF83XzQ4XzRGXzQ4XzRGXzVfQ18xRF 8xQl8xNl9CXzEwXzE3XzFfN18xMV82RV83MF83OF8xNl8xMV83 XzE2X0JfN19GX0JfNjlfNDhfNEZfNDhfNEZfNzVfN0FfNzZfNz RfNzFfNzJfNzRfNzJfN0JfNzdfNzFfN0JfNzdfNzFfNkVfNzBf N0ZfMTZfMTFfN18xNl9CXzdfRl9CXzY5XzE2XzNfNjY= !!! FAIL !!!! Total Time Take...00:01:00 Log Saved |
08-06-2016, 14:50 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @cwcast Hello Phone is warranty void , you have used imeicert write usb so error not showed., Flash eng sboot then only you can write cert on such phone. |
08-06-2016, 15:21 | #5 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @raulka2003 Hello G925TUVU4EPF1 PG etc tested work fine. i am not aware if more new come out or not. But this version is 100% tested with eng sboot. |
08-08-2016, 15:33 | #7 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Dominican Republic Age: 33
Member: 2057260 Status: Offline Thanks Meter: 97 | G920TUVU4EPF1 Write cert error, Need eng sboot please help: Using Version...1.0.0.0035 Selected Port ssudmdm0000 = COM300 Selected Model SM-G920T Selected Task SAM CERT WRITE ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := G920T VER := G920TUVU4EPF1/G920TTMB4EPF1/G920TUVU4EPF1/G920TUVU4EPF1 Phone IMEI := 00000000000000 Default MSL NO NEED RESET EFS... MSL autho fail CustomKernal Error use ENG SBOOT OR ENG KERNEL.. !!! FAIL !!!! Total Time Take...00:00:55 Log Saved |
08-08-2016, 15:45 | #8 (permalink) |
Member: 2057260 Status: Offline Thanks Meter: 97 | I was able to flash eng sboot, but now phone stuck on logo. http://1a6bacde31b58164e265-663390ea...920T_4_PE1.tar Restore with this one to normal mode, but still not able to write cert. http://1a6bacde31b58164e265-663390ea..._G920T_PF1.tar |
The Following User Says Thank You to samuel1003 For This Useful Post: |
08-08-2016, 15:51 | #9 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @samuel1003 Hello After flash with eng sboot did you try to connect and write cert ? I am not sure but you can try even at hang on samsung you can still write cert. Once its done reflash stock. |
08-08-2016, 17:15 | #10 (permalink) | ||
No Life Poster Join Date: Apr 2007 Location: Inside Samsung Pocket Age: 40
Member: 489331 Status: Offline Thanks Meter: 1,141 | Quote:
08-08-2016, 17:25 | #12 (permalink) | |
Member: 1815016 Status: Offline Thanks Meter: 77 | Quote:
You cannot have sboot 5.x and system 6.x Sboot and system must match , otherwise it won't boot. | |
08-08-2016, 18:58 | #14 (permalink) | |
Member: 2057260 Status: Offline Thanks Meter: 97 | Quote:
I tried this way but got this error after your instructions: Using Version...1.0.0.0035 Selected Port ssudmdm0000 = COM326 Selected Model SM-G920T Selected Task SAM CERT WRITE ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := G920T VER := G920TUVU4EPF1/G920TTMB4EPF1/G920TUVU4EPF1/G920TUVU4EPF1 Phone IMEI := 00000000000000 Default MSL NO NEED RESET EFS... MSL autho fail CustomKernal Error use ENG SBOOT OR ENG KERNEL.. !!! FAIL !!!! Total Time Take...00:00:45 Log Saved | |
08-08-2016, 21:24 | #15 (permalink) | |
