03-07-2016, 23:26 | #1 (permalink) |
Freak Poster Join Date: Apr 2012
Member: 1745496 Status: Offline Thanks Meter: 68 | g928t Exynosefs reset stuck I have a g928t I tried to reset efs to be able to repair imei, when I do it I get stuck on Using Version...1.0.0.0026 Selected Port ssudmdm0002 = COM4 Selected Model SM-G928T Selected Task SAMSUNG ExynosEFS RESET Searching phone... Device Found.. MODEL=SM-G928T;UN=0715F735436E2938;CAPA=32;VENDOR=SAMSUNG;F WVER=0301;PRODUCT=KLUBG4G1BD-E0B2;PROV=PASS; Init ok.. Samsung Exynos EFS Reset Success.. the software says not responding, I tried different ports, what can I do? thank you |
03-08-2016, 12:02 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,086 | @anglngr9 Hello Flash older sboot to make resetefs or frp remove. new firmware closed this solution. ps:Use latest update please. |
03-09-2016, 04:49 | #4 (permalink) |
Freak Poster Join Date: Sep 2015 Location: HERE
Member: 2457641 Status: Offline Thanks Meter: 153 | 1st flash G928TUVU2COJ5 firmware through odin, then ur phone will be stuck on samsung screen 2nd you need to either flash engineering sboot or flash custom/root kernel to make the phone boot up all the way. 3rd now you can fix drk and write cert. gcpro will not let you write cert if the phone is rooted, so you can use z3x to write cert using usb and it will work fine 4th you can flash the stock rom again to remove root if you like pm me or message me on skype if you need further help skype id is truunlocker |
The Following User Says Thank You to ali2194 For This Useful Post: |
03-09-2016, 05:43 | #5 (permalink) |
Member: 1745496 Status: Offline Thanks Meter: 68 | The phone was stuck as it is since it never turned on, i flashed the sboot file with the firmware i had installed then tried the process again, it worked thank u guys Dont forget to hit the thanks button |
