Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 05-09-2018, 20:01   #1 (permalink)
Member: 2816155
G935P Network Unlocked Can't Access Hidden Menu
Hi,
I unlocked a G935P but I cannot access the IOHIDDEN menu. I am on binary 5. I have tried to downgrade with no success. ADB shows no command found when I try to use the commands to enter.
I also tried to jsut flash it over to a T-mobile rom but I can only find binary 4 for it.
Old 05-12-2018, 22:03   #2 (permalink)
Member: 2831070
I have the same use, ihave read you should download combination file of g935a binary 5 then unlock with ocopus or z3x
please if you find other way just say it to me
Old 05-13-2018, 21:23   #3 (permalink)
Member: 2309595
Thanks Meter: 91
1. Connect to WiFi
2. Setting/ active this phone
3. Wait till it say fail
4. Look at the top right connect for the "three dots icon"
5. click QPST, then select IO USB debug ( dont remember for sure the name - but you will find out.)
Old 05-14-2018, 04:46   #4 (permalink)
Member: 2833796
Thanks Meter: 4
I need to have 10 post for links, since there's no link here I don't understand but... anyways, remove the spaces on
"android . provider . Telephony . SECRET_CODE"
and
"android_secret_code : / / 27663368378"
flash stock
root with engroot
adb shell
su
am broadcast -a android . provider . Telephony . SECRET_CODE -d android_secret_code : / / 27663368378
​There you go, hidden menu. Hope it helps.
Old 05-15-2018, 11:12   #5 (permalink)
Crazy Poster
Member: 1778823
samsung j510f adb unlok helpme
Old 05-19-2018, 21:25   #6 (permalink)
Member: 2831070
Sujon111
Ican help you but you will need a box for unlock, dosent matter the smart card you should only will it for the com port.
Page generated in 0.24265 seconds with 7 queries
