Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 10-29-2017, 01:49   #1 (permalink)
Member: 2611417
Thanks Meter: 9
G955F RMM State locked, asking password
Hello
I have G955F on G955FXXU1AQH3 firmware
Phone locked to company and asking password
i already flashed COMBINATION and removed FRP lock but phone asking password over and over i cant get into menu or settings
Reset via recovery - not remove this password
Flash another stock - not remove this password
There is no OEM Unlock in Developer options (when it on COmbination firmware)
Any advice?
thanks
(i dont understand this language)
The Following 2 Users Say Thank You to USflash For This Useful Post:
Old 10-29-2017, 14:37   #2 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,273
Did you tried bypass by using combination file
Originally Posted by USflash View Post
Hello
Any advice?
thanks
IF YOU LIKE WHAT I POST PRESS THANKS BUTTON
The Following 4 Users Say Thank You to souma_k For This Useful Post:
Old 10-29-2017, 15:36   #3 (permalink)
Member: 2611417
Thanks Meter: 9
Yes but only FRP bypassed
Old 10-29-2017, 15:38   #4 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,273
You didn't have acces to phone meniu?
Sent from my Le X829 using Tapatalk
The Following User Says Thank You to souma_k For This Useful Post:
Old 10-29-2017, 15:42   #5 (permalink)
Member: 2611417
Thanks Meter: 9
No access to menu or settings
Old 10-30-2017, 23:28   #6 (permalink)
Member: 819163
Thanks Meter: 45
I guess it has mdm profile active. You got to check via by pass if there’s any & removenit.
The Following User Says Thank You to fakeprince_ For This Useful Post:
Old 10-31-2017, 07:19   #7 (permalink)
chubbie's Avatar
Member: 281801
Sonork: 100.1608672
Thanks Meter: 158
Yeah, definitely MDM PROFILE/Corporate LOCK
Try Get FULL firmware that have all partition and Flash or Format Persist partiton
The Following 2 Users Say Thank You to chubbie For This Useful Post:
Old 11-03-2017, 12:04   #8 (permalink)
Member: 819163
Thanks Meter: 45
Confirmed us if it worked!
Old 11-08-2017, 15:49   #9 (permalink)
Member: 2611417
Thanks Meter: 9
Not working
Still trying to unlock
Old 11-24-2017, 05:21   #10 (permalink)
Member: 2781991
you could fix it bro? I have 1 with the same problem
Old 11-25-2017, 00:02   #11 (permalink)
Member: 2611417
Thanks Meter: 9
Still can’t unlock it
Old 11-25-2017, 02:17   #12 (permalink)
Member: 2781991
Red face
no bro I can not find a solution
Old 11-28-2017, 07:04   #13 (permalink)
Member: 2000325
Thanks Meter: 3
Hello
Any advice?
thanks
Try Kies or SmartSwitch. Go to the "tools" dropdown menu and choose*software*update and Initialisation. Fill out the*device model and*samsung*serial numbers.
Sent from my LG-H830 using Tapatalk
The Following User Says Thank You to hgrunwell For This Useful Post:
Old 11-30-2017, 01:09   #14 (permalink)
Member: 2611417
Thanks Meter: 9
Ok will try
Thanks .
Old 11-30-2017, 02:20   #15 (permalink)
Member: 2000325
Thanks Meter: 3
Ok will try
Thanks .
Let me know if it works, I've heard it does.
Page generated in 0.20286 seconds with 8 queries
