Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 05-05-2018, 10:47   #61 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 360
RMM:normal FRP:OFF and oem enable this can solved ? cant root any guide for remove RMM
Old 07-25-2018, 14:14   #62 (permalink)
Member: 2611417
Thanks Meter: 9
Dont update to Android 8. You will get lock again!
Old 08-14-2018, 13:00   #63 (permalink)
mr_loverman's Avatar
Member: 87722
Thanks Meter: 109
hello all
is there any way to try disable or stop or am kill RLC services by adb shell (not rooted)
i can connect to phone by adb but cant go to settings or any phones menu.
combination file COMBINATION_FA70_G950USQU5ARG4 gives error
custom binary(boot) blocked due to remaining installment balance
Old 08-15-2018, 21:18   #64 (permalink)
Member: 317790
the lordofthepings solution worked the firmwares until June, from July
forward to freeze the rlc is not the solution. I have a j530g that
in the J530GUBU2ARB1 version worked, however it has been upgraded to
the J530GUBU3ARG1 version and now nothing works.
the device is unlocked oem and frp with adb active, even then I did not
identify the one that triggers the lock
adb shell dumpsys activity log show:
Foreground Processes:
mStartedUsers:
User #0: state=RUNNING_UNLOCKED
mWakefulness=Awake
mSleepTokens=[]
mSleeping=true mLockScreenShown=LOCK_SCREEN_SHOWN
mShuttingDown=false mTestPssMode=false
TRIM_EMPTY_APPS: 8
TRIM_CACHED_APPS: 5
TRIM_CRITICAL_THRESHOLD: 3
TRIM_LOW_THRESHOLD: 5
when it's unlocked show:
mSleeping=false mLockScreenShown=LOCK_SCREEN_HIDDEN
instead of
Old 08-21-2018, 15:00   #65 (permalink)
Member: 2749921
alguem encontrou uma solução??
Old 09-01-2018, 12:47   #66 (permalink)
Crazy Poster
Member: 2622037
Thanks Meter: 8
when you flash combination via odin latest patch 13.1 , check one thing ( NAND ERASE ALL ) after that when re-flash with new firmware choose ( NAND ERASE ALL ).
it shud clear all partition
Old 09-04-2018, 07:46   #67 (permalink)
Member: 2862499
Thanks Meter: 2
Hello!
First, I want to thank you for the previous instructions. They helped me a lot.
I made all the instructions and it worked while my Note 8 (N950F) worked with the firmware N950FXXU3CRDF (Binary 3).
But I did not uncheck the automatic update (I still have not forgiven myself).
When the device restarted, the firmware N950FXXU4CRG5 (Binary 4) was installed.
With this update, the "Icebox" app can not delete the SEM_LOGISTICS PIN Code prompt and unfortunately we are back to the initial problem.
After trying several times, I could observe some things:
1. I have about 30 sec until the appliance locks again.
2. At that time I was able to open the "Icebox" app and I was able to verify that "rlc apk" does not appear as an option for freeze.
I read an article that in this update, Samsung corrected an issue that caused users to gain access to applications in the same security folder with the password enabled.
I think that's just what blocked the freeze to "rlc apk".
Is there any possibility of deleting or freeze this software with this new update in another way?
Thank you and forgive me the bad English.
The Following User Says Thank You to anthoniarsg For This Useful Post:
Old 09-05-2018, 05:52   #68 (permalink)
Member: 2862499
Thanks Meter: 2
Originally Posted by dapinderjit View Post
Need to download firmware for U.K. From Sam firm
With the region O2U and don't forget pit file
Try and post reply
Thanks, bro.
I am downloading firmware U.K. (O2U), but my device is configured for Brazil (ZTO), can I install it without corrupting the device?
Forgive my lack of information, but what do you mean by pit file?
Old 09-05-2018, 16:01   #69 (permalink)
Member: 2862499
Thanks Meter: 2
Hello guys,
I downloaded the U.K. (O2U) firmware and installed it, but it did not work.
After 1 minute, the device has locked again.
Does anyone have any suggestions on what I can do within this 1 minute time to freeze or delete the software that generates the lock?
Old 09-13-2018, 07:34   #70 (permalink)
Member: 2864902
you found some solution I have the same problem update to binary 4 and I can not freeze it noté 8 n950f
Old 09-13-2018, 09:11   #71 (permalink)
Member: 2338252
Sonork: 100.100
wht about s9...................................?
Old 09-15-2018, 03:59   #72 (permalink)
Member: 2862499
Thanks Meter: 2
Unfortunately nothing worked.
I tried some things like login with the Samsung account, try activating the OEM unlock to try "root".
But, nothing works.
I see no solution.
At the moment, I'm trying to keep the device turned on for 7 days to see if the RMM State Lock disappears.
Old 09-18-2018, 03:28   #73 (permalink)
Member: 2864902
Originally Posted by anthoniarsg View Post
Hello!
hello I have the same problem in my note 8 n950f you could solve it since I've been looking for a solution for a week and nothing
Old 09-19-2018, 04:23   #74 (permalink)
Member: 2862499
Thanks Meter: 2
Unfortunately nothing work.
I've been looking for a solution for almost a month.
I don't know what to do anymore.
Old 11-13-2018, 21:17   #75 (permalink)
Member: 2862499
Thanks Meter: 2
Anywhere found some solution?
Page generated in 0.37657 seconds with 7 queries
