01-11-2018, 00:19 | #2611 (permalink) | |
No Life Poster Join Date: Jan 2014 Location: San Luis Potosi, Mexico
Member: 2109200 Status: Offline Thanks Meter: 40 | Quote:
No digas nada porque luego stanner te pone ban por 20 días en todo gsmhosting marcando como spam las quejas Sent from my iPhone using Tapatalk | |
01-11-2018, 00:33 | #2612 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1081728 Status: Offline Thanks Meter: 7 | Checking GCPro Card Details... Checking server connection... GCPro SN GCFD8E5C42 Card OsVer 0002 Checking security of card... GCPRO Activation := CARD IS ACTIVE Card crypto verify ok.. Please install JAVA 8 before update & restart computer before using. https://java.com/en/download/ error := bZBZDsMgDESvZJbg5NPb3P9IHVpFVaoKYbCN543AiVETwzujll SDIxHeXWx4mHH3SBumJi4XrjPvGYuVcPceLZVRShG1qAAwz51N eMlW3LXdpbJhv3QUmP2hAGTbdH/QehqyVrTq+/zSs1HJb/WYrP4yxJSEp3p5pycv4+R63xOLvlnnLxipwvnA8fFx9b1k2dJQ iaMdaypkvAA= Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...10-01-2018-18-23-24 ayuda con esto, cuando la trato de activar al update 61 me arroja este error y cuando abro el update 61 me dice lo siguiente checking card failed apdu2 con un warning ... card not found ... error 33111. agradesco la ayuda |
01-11-2018, 00:50 | #2613 (permalink) |
Junior Member Join Date: Dec 2015
Member: 2502377 Status: Offline Thanks Meter: 0 | Hi,I purchased credits a few days ago,I had no problems at all. Today,I bought Chimeratool and installed it on the same pc,but,when I tried to open Gcpro says it is locked.. Please help...I added the log Checking server connection... Server access ok.. Making sure card is locked or not.. session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os... Reading Details.. Card Lock Reason := Fce5EQAhDAPAlqzzF0sG+i/pYDbaVACzgSIPGdaZA++qim+F5ByuR+MNI2Xt2/ruBw== Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help.. GCPro SN := GC6A273639 Fail at unlock card please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...10-01-2018-17-45-46 |
01-11-2018, 01:30 | #2614 (permalink) |
01-11-2018, 02:39 | #2616 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2588927 Status: Offline Thanks Meter: 0 | Checking server connection... Server access ok.. Making sure card is locked or not.. session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os... Reading Details.. Card Lock Reason := FcLJEQAxCAOwliAHOE8HnP5L2tmRWjLIeYr+2INelcx5sAFjpI fi/VK+Vk3UvQa0FB8= Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help.. GCPro SN := GC1536615D Fail at unlock card please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...10-01-2018-21-16-31 |
01-11-2018, 09:36 | #2617 (permalink) |
Junior Member Join Date: Aug 2009 Location: bangladesh.ctg.noakhali
Member: 1108881 Status: Offline Thanks Meter: 0 | gcpro card not found....error 33111 please help me--- gcpro card sn:-GCPro found... Card verify ok... Card OsVer 0002 GCPro SN:= GC4EFC6F40 GCPRO Activation := CARD IS ACTIVE Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...10-01-2018-22-32-24 |
01-11-2018, 14:10 | #2618 (permalink) |
01-11-2018, 17:17 | #2619 (permalink) | |
Junior Member Join Date: Jul 2017
Member: 2740916 Status: Offline Thanks Meter: 0 | Quote:
problema resuelto gracias a Contact GCPro_support at skype | |
01-12-2018, 00:30 | #2621 (permalink) |
Freak Poster Join Date: Apr 2011 Location: Los Angeles California
Member: 1549521 Status: Offline Thanks Meter: 19 | GC Pro Box card Blocked My card was block it but support send me a software to fix it and is working but allway appear this message desconect your card to avoid to block... I dont know what is the problem, Gc_support told me "Log say it's locked due to 10 bad commands to card" and my question is " Bad Commands what it means"... I have other boxes and I don't have this problem... Thank You so much... |
01-12-2018, 07:15 | #2622 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: Surabaya
Member: 247433 Status: Offline Thanks Meter: 25 | Help bro...this is my customer Quote:
01-12-2018, 12:41 | #2623 (permalink) |
Freak Poster Join Date: May 2013
Member: 1947667 Status: Offline Thanks Meter: 31 | GCPro found... Card verify ok... Card OsVer 0002 GCPro SN:= GC123A40F5 GCPRO Activation := NOT ACTIVE Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...11-01-2018-17-47-49 |
01-12-2018, 13:28 | #2624 (permalink) | |
Junior Member Join Date: Feb 2015
Member: 2353137 Status: Offline Thanks Meter: 3 | Quote:
"Log say it's locked due to 10 bad commands to card" you should know what exactly you did, maybe another card or not allowed software. Regards | |
