Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 01-12-2018, 22:03   #2626 (permalink)
Member: 2663665
my card is blocked
log
Checking server connection...
Server access ok..
Making sure card is locked or not..
session fail Card Locked..
Fail cardos Card Locked..
Fail to get card os...
Reading Details..
Card Lock Reason := FcLBEQAhCASwlkAB4bkL2n9JNzfJ0Fghpn0n3aFnobAnpK51Jw GH/ehPZIXpeofJTfkA
Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help..
GCPro SN := GCAC84201B
Fail at unlock card please contact support...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...12-01-2018-16-01-31
help me
Old 01-12-2018, 22:05   #2627 (permalink)
Member: 1298793
Thanks Meter: 16
My card has ben also blocked , we need update 62, then unlock the box, can anyone provide us with da update
Old 01-12-2018, 23:00   #2628 (permalink)
Member: 2397266
My gcpro box not working
HELLO
I HAVE BEEN USING MY CG PRO BOX FOR ALMOST TWO YEARS TODAY IT GIVING ME THIS MESSAGE PLEASE HELP
Reading Details..
Card Lock Reason := FcLJDQAxCASwljgWGJ4oE/ovKVrZtlrTuHAHXWxsRYXcMO+dIE6d/LEy5RKMXv3Q3Q8=
GCPro SN := GC2C1ED4D0
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...12-01-2018-14-49-30
PLEASE REPLY ME ON MY EMAIL na
Old 01-13-2018, 02:16   #2629 (permalink)
Member: 1549521
Thanks Meter: 13
Hi br ask for help on sky search GCPro_Support
Old 01-13-2018, 05:52   #2630 (permalink)
rasgula's Avatar
Member: 119464
Thanks Meter: 222
This card is locked.
Server access ok..
Fail to get card os read details...
Reading Details..
security invalid 0..
Card Lock Reason :=  FcLJDcBACAPAlkLAy/I0V/8lRdFMoROqvq8c5KYtb0ddMlj5BMTG9oeZhUKcyTjo8Q8=
GCPro SN := GCBA86457D
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...12-01-2018-23-47-56
Old 01-13-2018, 12:51   #2631 (permalink)
Member: 720366
Thanks Meter: 13
Thumbs up card update
whenever i want to update it keep on saying fail card os with 1B00.PLS HELP ME.May *** help you in all your undertakings
Old 01-13-2018, 13:58   #2632 (permalink)
Member: 622715
Thanks Meter: 74
Server access ok..
Reading Details..
Card Lock Reason := FcJBEsBABATAL41YxBEZ/3/SVqrbt6hfVJpG4X2yKQuxQYU6e5uH9tsTdE0QGNGpyQs=
GCPro SN := GCB1360C7E
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...13-01-2018-16-56-47
Old 01-13-2018, 22:01   #2633 (permalink)
Member: 2799565
Problem activating gcpro
I PURCHASED SOME GCPRO BOXES FROM GSM SERVER, AT THE MOMENT I'M GETTING THIS ERROR WHEN TRYING TO REGISTER:
Card verify ok...
Card OsVer 0002
GCPro SN:= GC78914DCB
GCPRO Activation := NOT ACTIVE
Please check your internet connection...0
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...13-01-2018-16-52-42
PC HAS PERFECT INTERNET CONNECTION, I NEED HELP WITH THIS ASAP.
THANKS.
Old 01-14-2018, 01:48   #2634 (permalink)
Member: 1461041
Thanks Meter: 30
Please help me...
Read GCPro Details:
Card is Locked.
GCPro found...
ERROR 0x1_islocked
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...14-01-2561-07-44-29
Unlock GCPro:
Check internet connection, not able to connect server...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...14-01-2561-07-46-07
Best Reguard.
LP-SERVICE THAILAND
Old 01-14-2018, 01:54   #2635 (permalink)
Member: 2799606
hola acabo de adquirir gcprokey..podran activar dejo el log..
GCPro found...
Card verify ok...
Card OsVer 0002
GCPro SN:= GCC414A607
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...13-01-2018-21-33-37
Old 01-14-2018, 08:25   #2636 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 197
i need to use my gcpro
GCPro found...
Card verify ok...
Card OsVer 0002
GCPro SN:= GCA19A434C
GCPRO Activation := CARD IS ACTIVE
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...14-01-2018-15-26-20
Checking GCPro Card Details...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...14-01-2018-15-22-08
my internet is fast 40mbps so no problem on internet
Old 01-14-2018, 08:42   #2637 (permalink)
Member: 49752
Sonork: 100.112446
Thanks Meter: 5,345
Hello every one
We like to tell every one we have down one of our server due to hardware change and improvements.
As soon ready we will notify here.
The Following 3 Users Say Thank You to stanner_austin For This Useful Post:
Old 01-14-2018, 17:42   #2638 (permalink)
Member: 579725
Sonork: 100.1675677
Thanks Meter: 40
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...14-01-2018-20-42-11
Old 01-14-2018, 20:48   #2639 (permalink)
Member: 425933
Thanks Meter: 2
Card verify ok...
Card OsVer 0002
GCPro SN:= GCB7826C9B
Card is Already Activated...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...14-01-2018-19-47-49
Old 01-14-2018, 21:11   #2640 (permalink)
Member: 425933
Thanks Meter: 2
RESELLER TST DUBAI
wwwtstunlockingcom
GCPro found...
Card verify ok...
Card OsVer 0002
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...14-01-2018-19-24-05
PLEASE HELP ME SOLVE THIS PROBLEM
Page generated in 0.24335 seconds with 8 queries
