05-24-2014, 06:44 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | GCPro Exclusive Frequently Asked Questions
The Following 15 Users Say Thank You to Faisal_Computer For This Useful Post: |
01-08-2015, 15:01 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Where can i find free CERT by GCPro.?
The Following 17 Users Say Thank You to stanner_austin For This Useful Post: |
08-15-2017, 13:03 | #3 (permalink) |
The Following 7 Users Say Thank You to stanner_austin For This Useful Post: |
02-09-2018, 12:02 | #4 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Before start please verify with *#0011# IMEICERT PASS, MIPI PASS NO ERROR ELSE YOU HAVE NETWORK ISSUE.
For all other phones basic steps is same You can ether root or use combination & sprint unlock option in GCPro samsung tab will unlock it. Note that J327P/J727P use rsa protection on U3 firmware and newer firmware may use same in future so no more unlocking for them yet do not spam with when or unlock success not unlocked etc.. such post will be deleted. Please do not ask us stock or combination files we do not host them you can find them via google or androidfilehost . Warning if you do not follow exact steps you may brick your phone you are responsible for any mistake you do.. GCPro_Team tested this steps and found no issue no knox void.. You are the one who responsible for any mistake you did we are not. so do it carefully. Last edited by stanner_austin; 03-27-2018 at 09:41. |
The Following 5 Users Say Thank You to stanner_austin For This Useful Post: |
02-09-2018, 12:04 | #5 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | How to unlock Samsung application locked ? Answer Please Read steps from http://forum.gsmhosting.com/vbb/f922...gcpro-2300486/ Warning if you do not follow exact steps you may brick your phone you are responsible for any mistake you do.. GCPro_Team tested this steps and found no issue no knox void.. You are the one who responsible for any mistake you did we are not. so do it carefully. Last edited by stanner_austin; 05-04-2018 at 15:02. |
The Following 2 Users Say Thank You to stanner_austin For This Useful Post: |
02-13-2018, 10:03 | #6 (permalink) |
02-26-2018, 17:54 | #7 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | How to use RLOCK ADB = REACTIVATION REMOVE ON QCOM samsung device.. Answer You must have STOCK 5.1 or newer . You must have ADB & ROOT. TEMP root also ok. use google or search in forum to get more idea how to do it. if you can't sorry no other option we have. We have uploaded most of ENG ROOT at support and they are latest firmware so flash your device with need firmware first. Scan port & select samsung modem port before start. Go to samsung tab select RLOCK ADB. Select any model GCPro do not care models at most case. Press start follow steps. In case any error please format and re do.. if still say post log by making new thread do not forget to post all log in text format no images or files please. Most engineering root is already at support.. Last edited by stanner_austin; 07-05-2018 at 18:04. |
The Following 3 Users Say Thank You to stanner_austin For This Useful Post: |
02-26-2018, 17:56 | #8 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | How to REMOVE REACTIVATION ON EXYNOS samsung device with root. Answer If you already have flashed ENG ROOT Please use FRP REMOVE (ADB) this will clear FRP & REACTIVATION & screen lock,pattern,password etc same time.. We have uploaded most of ENG ROOT at support and they are latest firmware so flash your device with need firmware first. Last edited by stanner_austin; 02-26-2018 at 18:05. |
03-06-2018, 16:09 | #9 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | How to FRP,REACTIVATION LOCKS ON EXYNOS samsung device VIA FRP_UFS OLD device with UART C3303K ? Answer Please connect any FTDI box plug C3303K cable & make sure you know port number. do not need COM,VCP etc. only number REMEMBER IT. Please connect phone in download mode. plug usb scan port select samsung modem port. Select FRP_UFS press start. Wait till reading finish.. software will restart phone to normal mode. do not press OK on it. Power off your phone fully.in GCPro software enter box port only number press OK Software will start searching your phone.. now connect POWERED OFF phone by pressing VOLUME DOWN Always AND POWER KEY only for first 2 sec. if software detect it release key pressing. If some reason not detected follow process again power off device fully, press VOLUME DOWN AND POWER KEY 2 sec only. Once detected it will remove FRP,REACTIVATION,EELOCK same time. |
03-06-2018, 16:12 | #10 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | HOW TO READ CERT WITH EXYNOS UNLOCK AND DIAG PORT? Answer Start phone fully make sure stock firmware is in phone. in some case you may need combination MODEM only not full flash. Dial *#0808# select LAST OPTION..(some case you may need to reboot) Scan port and select SAMSUNG USB TO SERIAL port in GCPro software. Go to samsung tab select Exynos unlock. Press start wait till finish.. If you face any issue Please report by making thread and attach full log. |
03-29-2018, 13:53 | #11 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Last edited by stanner_austin; 01-23-2019 at 13:41. |
The Following 10 Users Say Thank You to stanner_austin For This Useful Post: |
03-22-2019, 18:08 | #12 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Question I have received GCPro.What next ? Answer.(Box or dongle same steps)
04-15-2019, 13:55 | #13 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Question How to unlock Samsung sprint most model with GCPro? Answer.(Box or dongle same steps)
Note:S9/S9+ SPRINT is via credits only supported at moment. http://forum.gsmhosting.com/vbb/f922...018-a-2371739/ Note2:J337,J727P U3,J737P,NOTE9,S10 SPRINT is not supported. Last edited by stanner_austin; 08-11-2019 at 11:20. |
