12-04-2017, 19:35 | #1876 (permalink) |
No Life Poster Join Date: Sep 2004 Location: srbija Age: 49
Member: 80567 Status: Offline Thanks Meter: 53 | I think that is your server side mistake,not our!!! can you make that is our dongle working? very bad move from your team and also your dongle is too expensive for buing new after your mistake. also my dongle is working before this update(ios 0002 is also make problem with my dongle,after your help I can used again). but now I have the same problem.. Help us p.s send us a new card without paying(only shipping) Checking GCPro Card Details... Checking server connection... GCPro SN GC84AE45E6 Card OsVer 0002 Checking security of card... GCPRO Activation := CARD IS ACTIVE Card error fail to start security session....6982 Fail to start security session,This CARD CAN NOT be updated,DO NOT TRY MORE.. Fail at verification... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-19-27-20 Last edited by pava; 12-04-2017 at 19:41. |
12-04-2017, 19:39 | #1877 (permalink) |
No Life Poster Join Date: Apr 2010 Location: NYC/USA
Member: 1283129 Status: Offline Thanks Meter: 135 | Checking GCPro Card Details... Checking server connection... GCPro SN GC194BFB03 Card OsVer 0002 Checking security of card... CARD IS LOCKED CONTACT SUPPORT.. Card crypto verify ok.. Please do not make any other task Card Update Started... Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help.. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-13-34-23 |
12-04-2017, 20:23 | #1879 (permalink) | |
Junior Member Join Date: May 2015
Member: 2393578 Status: Offline Thanks Meter: 0 | Quote:
I also have the same problem some solution please GCPRO we need your help attached my log Checking GCPro Card Details ... Checking server connection ... GCPro SN GC7323A852 Card OsVer 0002 Checking security of card ... GCPRO Activation: = CARD IS ACTIVE Card error fail to start security session .... 6982 Fail to start security session, This CARD CAN NOT be updated, DO NOT TRY MORE .. Fail at verification ... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error ... 04-12-2017-13-18-22 Log Saved Please give me a faster solution and I did all of everything but it keeps coming out that I hope you can help us all who have this problem thank you. | |
12-04-2017, 20:27 | #1880 (permalink) |
Crazy Poster Join Date: Mar 2014
Member: 2154508 Status: Offline Sonork: javier-86 Thanks Meter: 9 | problem update 59 card update os 003 Please help me with this error Please install JAVA Runtime before update & restart computer before using... error := jVDRDgMhCPslRT3LIyL3/5+0cstlW5Ysiw9CoaVgU4sWbC0bLqtgYmBp1YP4coFi5u9jVWx 04gONjLnCwKij3ZUXkko64Xpg4cR0scw6lTkLnlhWqRpW9enhQ lZHZpU89vmIMwCjanVJZQR1Z/rZzX2bDw+65DSq3eggKrkFOdTVRs66JhzuqWgfW4P+2RGsCr3t VAK9Ms7o3okZe+Kbbz/5bzepNv++zOUzJB/X4iG4qjQ5qNjxAA== Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-11-03-22 |
12-04-2017, 20:43 | #1881 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Dominican Republic
Member: 469532 Status: Offline Sonork: TG: CodebUnlocks Thanks Meter: 868 | Uninstall java, do a registry clean, reboot pc, install java, reboot pc, follow the steps in this post GcProKey Update59 Exclusive & World's 1st Solutions Inside Feel the Heat in winter and try again but WARNING some card are getting blocked or damage with this update, i suggested to you that keep using update 58 till support solve this issue. Report Post |
12-04-2017, 20:46 | #1882 (permalink) |
Member: 2154508 Status: Offline Sonork: javier-86 Thanks Meter: 9 | Update error Checking GCPro Card Details... Checking server connection... GCPro SN GC5BE60C7B Card OsVer 0002 Checking security of card... GCPRO Activation := CARD IS ACTIVE Card crypto verify ok.. Please install JAVA Runtime before update & restart computer before using... error := jVDRDgMhCPslRT3LIyL3/5+0cstlW5Ysiw9CoaVgU4sWbC0bLqtgYmBp1YP4coFi5u9jVWx 04gONjLnCwKij3ZUXkko64Xpg4cR0scw6lTkLnlhWqRpW9enhQ lZHZpU89vmIMwCjanVJZQR1Z/rZzX2bDw+65DSq3eggKrkFOdTVRs66JhzuqWgfW4P+2RGsCr3t VAK9Ms7o3okZe+Kbbz/5bzepNv++zOUzJB/X4iG4qjQ5qNjxAA== Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-11-03-22 |
12-04-2017, 20:58 | #1884 (permalink) |
Freak Poster Join Date: Dec 2009 Location: egypt
Member: 1188874 Status: Offline Sonork: 100.1610116 Thanks Meter: 8 | hecking GCPro Card Details... Checking server connection... GCPro SN GC39D74EAA Card OsVer 0002 Checking security of card... CARD IS LOCKED CONTACT SUPPORT.. Card crypto verify ok.. Please do not make any other task Card Update Started... Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help.. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-21-56-53 i was work fine last update 85 help plz |
12-04-2017, 20:58 | #1885 (permalink) |
Junior Member Join Date: Nov 2008
Member: 898823 Status: Offline Thanks Meter: 4 | help me , what can i do ?? Checking GCPro Card Details... Checking server connection... GCPro SN GCXXXXXXXX Card OsVer 0002 Checking security of card... CARD IS LOCKED CONTACT SUPPORT.. Card crypto verify ok.. Please do not make any other task Card Update Started... Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help.. Job finish |
12-04-2017, 21:03 | #1886 (permalink) |
Member: 1188874 Status: Offline Sonork: 100.1610116 Thanks Meter: 8 | hecking GCPro Card Details... Checking server connection... GCPro SN GC39D74EAA Card OsVer 0002 Checking security of card... CARD IS LOCKED CONTACT SUPPORT.. Card crypto verify ok.. Please do not make any other task Card Update Started... Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help.. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-21-56-53 help plz iwas working fine with last update 58 |
12-04-2017, 21:03 | #1887 (permalink) |
Crazy Poster Join Date: Jan 2008
Member: 686206 Status: Offline Thanks Meter: 3 | Please Help Update Error Checking GCPro Card Details... Checking server connection... GCPro SN GCF91D72CA Card OsVer 0001 Checking security of card... GCPRO Activation := CARD IS ACTIVE Card crypto verify ok.. Please do not make any other task Card Update Started... Please do not REMOVE CARD or Power off PC.. Card Init update ok.. Verifying Update.... Security Check Fail 1... Fail to update security details contact support DO NOT TRY AGAIN... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-13-24-06 |
12-04-2017, 21:03 | #1888 (permalink) |
12-04-2017, 21:11 | #1889 (permalink) |
Junior Member Join Date: May 2016
Member: 2576701 Status: Offline Thanks Meter: 0 | GCPro encontró ... Tarjeta bloqueada.. No se puede iniciar la sesión con la tarjeta ... Final del trabajo No pierdas la eliminación de los registros antiguos, es posible que te ayuden un poco a solucionar tu problema rápi*****te. Muestra el registro al equipo de asistencia en caso de error ... 04-12-2017-17-09-50 ayuda por favor |
12-04-2017, 21:18 | #1890 (permalink) |
Member: 2154508 Status: Offline Sonork: javier-86 Thanks Meter: 9 | After problem install java runtime now!!!! Checking GCPro Card Details... Checking server connection... GCPro SN GC5BE60C7B Card OsVer 0002 Checking security of card... GCPRO Activation := CARD IS ACTIVE Card crypto verify ok.. Please do not make any other task Card Update Started... Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help.. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-15-06-09 |
