12-04-2017, 22:02 | #1891 (permalink) |
Freak Poster Join Date: Sep 2010
Member: 1392507 Status: Offline Thanks Meter: 38 | logs: -------------------------------------------- GCPro found... Card verify ok... Card OsVer 0002 GCPro SN:= GC0B1AFC71 GCPRO Activation := NOT ACTIVE Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-15-34-24 Log Saved Checking GCPro Card Details... Checking server connection... GCPro SN GC0B1AFC71 Card OsVer 0002 Checking security of card... GCPRO Activation := NOT ACTIVE Card crypto verify ok.. Please do not make any other task Card Update Started... Server Reply Error := ERR_CARD_Already_Updated. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-15-36-05 |
12-04-2017, 22:13 | #1892 (permalink) |
No Life Poster Join Date: Jan 2014 Location: San Luis Potosi, Mexico
Member: 2109200 Status: Offline Thanks Meter: 40 | I have error ....6982 Checking GCPro Card Details... Checking server connection... GCPro SN GC035B5DE1 Card OsVer 0002 Checking security of card... GCPRO Activation := CARD IS ACTIVE Card error fail to start security session....6982 Fail to start security session,This CARD CAN NOT be updated,DO NOT TRY MORE.. Fail at verification... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-08-08-50 |
12-04-2017, 22:14 | #1893 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Cuba Age: 45
Member: 1020744 Status: Offline Thanks Meter: 428 | Card is locked contact support.. Quote:
Here's the thing.... I started the update, but Not Java on the PC, now thers Java, but says card is locked.! what to do?? | |
12-04-2017, 22:15 | #1894 (permalink) |
Insane Poster Join Date: Feb 2014 Location: Honduras , la ceiba atlantida
Member: 2127804 Status: Offline Thanks Meter: 6 | I also have the same problem then my card could not be used. with the new version If so, it is not fair, it has to be a patch of updates without errors for all, or open a solution later * Checking the details of the GCPro card ... Verifying server connection ... GCPro SN GCEFECF6EA OsVer Card 0002 Checking the security of the card ... GCPRO Activation: = THE CARD IS ACTIVE Card error when security session is not started .... 6982 The security session can not be started, this CARD CAN NOT be updated, DO NOT ATTEMPT MORE. Verification failed ... End of work Do not lose the elimination of the previous records, it can help you a bit to solve the problem quickly. It shows the record to the assistance team in case of error ... 03-12-2017-12-24-13 Log Saved |
12-04-2017, 22:17 | #1895 (permalink) | |
Member: 2109200 Status: Offline Thanks Meter: 40 | Quote:
Lets wait whats wrong Sent from my iPhone using Tapatalk | |
12-04-2017, 22:47 | #1897 (permalink) |
Junior Member Join Date: Nov 2014 Location: ecuador,azuay, cuenca
Member: 2292937 Status: Offline Thanks Meter: 0 | help me Checking server connection... Server access ok.. Making sure card is locked or not.. ERROR 0x1_islocked Reading Details.. Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help.. GCPro SN := GC94710413 Fail at unlock card please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-16-11-30 |
12-04-2017, 23:33 | #1898 (permalink) |
Junior Member Join Date: Sep 2017 Location: Nueva Concepcion
Member: 2762884 Status: Offline Thanks Meter: 0 | update my gc pro and I got blocked buy my gc pro in gsmserver Checking GCPro Card Details... Checking server connection... GCPro SN GC11E36333 Card OsVer 0002 Checking security of card... CARD IS LOCKED CONTACT SUPPORT.. Card crypto verify ok.. Please do not make any other task Card Update Started... Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help.. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...03-12-2017-14-27-30 Log Saved |
12-05-2017, 00:17 | #1899 (permalink) |
Junior Member Join Date: May 2016
Member: 2571129 Status: Offline Thanks Meter: 0 | Please help Checking server connection... GCPro SN GC68A69108 Card OsVer 0002 Checking security of card... CARD IS LOCKED CONTACT SUPPORT.. Card crypto verify ok.. Please do not make any other task Card Update Started... Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help.. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-17-05-31 Log Saved |
12-05-2017, 00:40 | #1901 (permalink) | |
Freak Poster Join Date: Feb 2016 Location: RooTCeLL - CUBA
Member: 2528726 Status: Offline Sonork: 100.1679759 Thanks Meter: 36 | 90% of the Card are working Fine ??? Quote:
The Following 3 Users Say Thank You to editodj For This Useful Post: |
12-05-2017, 01:10 | #1902 (permalink) |
Crazy Poster Join Date: Mar 2015
Member: 2357902 Status: Offline Thanks Meter: 5 | Card Uppdate Problem Checking GCPro Card Details... Checking server connection... GCPro SN GC1EF20EE8 Card OsVer 0000 Verifying Update.... Server Reply Error := ERR_92_Contact_Support Fail to update security details contact support DO NOT TRY AGAIN... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...05-12-2017-01-01-21 Log Saved |
12-05-2017, 01:14 | #1903 (permalink) |
No Life Poster Join Date: May 2013
Member: 1930570 Status: Offline Thanks Meter: 82 | am getiing this erro Checking GCPro Card Details... Checking server connection... GCPro SN GC Card OsVer 0000 Verifying Update.... Invalid card sn... Fail to update security details contact support DO NOT TRY AGAIN... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-17-14-21 Log Saved |
12-05-2017, 01:18 | #1904 (permalink) |
Junior Member Join Date: Jul 2016
Member: 2603960 Status: Offline Thanks Meter: 0 | GCPro found... Card verify ok... Card OsVer 0002 GCPro SN:= GC95AD5ED1 card error bad activation level...FE Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-18-17-36 Log Saved |
12-05-2017, 01:27 | #1905 (permalink) | |
Freak Poster Join Date: Aug 2013 Location: E.U.A.
Member: 2000941 Status: Offline Sonork: 100.1612069 Thanks Meter: 72 | Please Help - Card Uppdate Problem Checking GCPro Card Details... Checking server connection... GCPro SN GC Card OsVer 0000 Verifying Update.... Invalid card sn... Fail to update security details contact support DO NOT TRY AGAIN... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-18-14-02 Log Saved Quote:
