Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 12-05-2017, 01:28   #1906 (permalink)
Member: 2502377
I can not upgrade
Checking GCPro Card Details...
Checking server connection...
GCPro SN GC6A273639
Card OsVer 0002
Checking security of card...
GCPRO Activation := CARD IS ACTIVE
Card crypto verify ok..
Please install JAVA before update & restart computer before using.
error := bY5ZDgQhCAWvBPZj8RO3+x9poJPOpCcTIwpKFWjostHJMy4JGW AYlJyCOylTbjfjzouDoklr+vSQTRVichu6MoYsqMwkCDLXyjZY oohVq9ckE+onA8jsj0WQbt7EL5srwWTaEK/za9eRJH7otrP66wheaXjTQZ4zsVB2zvtumDn3bW1eK67tfnRfL n12nNM+
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-18-14-07
Old 12-05-2017, 01:33   #1907 (permalink)
Mr_F10ch3's Avatar
Member: 469532
Sonork: TG: CodebUnlocks
Thanks Meter: 868
GCPro SN GC6A273639
Card OsVer 0002
Job finish
This is a java problem, you can solve this uninstalling java, rebooting pc, installing java, rebooting pc and gonna be ok but plz read carefully all post about update 59 many damaged card after update, some cards update ok, others not, you can do it on your own risk
Old 12-05-2017, 01:43   #1908 (permalink)
Zilre's Avatar
Member: 2000941
Sonork: 100.1612069
Thanks Meter: 72
GCPro SN GC
Card OsVer 0000
Verifying Update....
Invalid card sn...
Fail to update security details contact support DO NOT TRY AGAIN...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-18-14-02
Log Saved
GCPro SN GCXXXXX
Card OsVer 0002
Please do not make any other task Card Update Started...
Please do not REMOVE CARD or Power off PC..
BACKUP OF NEW CARD IS SAVED.. !!! PLEASE COPY AT SAFE PLACE !!..
Backup Created..
Seed:= FcrBDQQxCATBlDBmbOYJGPIP6W7Vr5I6cFT4PNL83GfKquk6JT KfS1tnsFHM93+NzqWZQ6u2u+MslyVtu/UUEdww6MTls8G0fVWKEoBUv0E49Qc=
Fail to verify security 2...
Fail to restore old card details contact support DO NOT TRY AGAIN...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-18-08-11
Old 12-05-2017, 01:49   #1909 (permalink)
Mr_F10ch3's Avatar
Member: 469532
Thanks Meter: 868
GCPro SN GC
Card OsVer 0000
Invalid card sn...
Job finish
Log Saved
Wait till tomorrow, support is working on a solution for cards that can be recovered, i saw you log and looks like my log and they told me that my card can be recovered but need some time to work on solution..
Old 12-05-2017, 01:50   #1910 (permalink)
Member: 2603960
Server Reply Error := ERR_CARD_Already_Updated.
when wanting to register my new gcpro tells me this
GCPro SN GC95AD5ED1
Card OsVer 0002
card error bad activation level...FE
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-18-20-05
Log Saved
Old 12-05-2017, 01:50   #1911 (permalink)
Member: 2127804
Thanks Meter: 6
Following the steps well Claro and you get error
Originally Posted by editodj View Post
Spanish Disculpa de donde sacas las estadisticas para comentar que el 90% de las tarjetas funcionan bien, te puedo decir que es la segunda actualizacion que da serios problemas y creo que no es muy profesional dar un buen soporte cuando al momento de actualizar ocurren errores como estos, algunos de nosotros compramos las dongles a travez de personas que ni siquieran tiene pagina web y la unica forma que tenemos de reclamar es con el soporta y ellos te mandan al revendedor y eso me parece poco profesional y al final es darle solucion pero que sea definitiva porque repito es la segunda vez que a mi en lo personal me sucede y no puedo darme el lujo de comprar otra porque baratas no son. Saludos
English Sorry where you get the statistics to comment that 90% of the cards work well, I can tell you that it is the second update that gives serious problems and I think it is not very professional to provide good support when updating errors occur like these , some of us buy the dongles through people who do not even have a website and the only way we have to claim is with the support and they send you to the reseller and that seems unprofessional and in the end is to give solution but Definitive because I repeat is the second time that I personally happen and can not afford to buy another because cheap are not. regards
Well said colleague your comment editodj, The steps are fine Of course if it is not discussed, I followed it step by step and the error ... 6982
The Following 2 Users Say Thank You to omarnexus For This Useful Post:
Old 12-05-2017, 01:57   #1912 (permalink)
editodj's Avatar
Member: 2528726
Sonork: 100.1679759
Thanks Meter: 36
Angry 90% of the Card are working Fine ???
Originally Posted by allumts View Post
Lol instead of SPAM and MISGUIDE users becouse not be silent when NOT KNOW NOTHING about?
90% of the Card are working Fine and w/o any Issue, who had issue are been solved by SUPPORT with one easy Step, so if haven't nothing of do NOT WRITE HERE!!!!! LOL
More good First of UPDATE CARD was reading Carefully all Step by Step "HOW TO UPDATE CARD"
Old 12-05-2017, 02:31   #1913 (permalink)
Member: 2508944
Originally Posted by Natashah View Post
Hello Sir,
Your activation is done, kindly Register your GcPro and Use it.
Thanks you for Choosing Gcpro.
Br,
GPGTeam
GCPro SN Gxxxxxxx
Card OsVer FFFF
Server Reply Error := ERR_CARD_Banned
Fail check internet connection.
Fail at verification..
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-21-12-41
Log Saved
Try to solve this
Old 12-05-2017, 02:50   #1914 (permalink)
Member: 2785723
HELP ME TEAM. I try to update the card for use the update 59 and show me this error
GCPro SN GC03298030
Card OsVer 0002
Card Init update ok..
Updating to Latest Card OS...
Fail to start session with card error 89123...
Fail to verify updated security,contact support DO NOT TRY AGAIN...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...05-12-2017-01-00-23
NOW IS
GCPro SN GC03298030
Card OsVer 0000
Server Reply Error := ERR_92_Contact_Support
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...05-12-2017-01-02-36
Old 12-05-2017, 02:54   #1915 (permalink)
Member: 2284504
please help me u
Please install JAVA Runtime before update & restart computer before using...
error := lVBLlgMgDLpSVIi69Hv/Iw2ZTqddts+FCQGC1oaLjcLOw8ZiAwk3btu1g1jCNybFq+6mam E+Jy/ERm28AA8KKq4Nj27JuYmLwGIqRefVpvbXL0TXpRLLdq7ZkOXZb YQvXK430qRpSNm2uTJqF88/uoSOeIM08uWUpvxuODKToz82ki2ZmEovhms6lIzhBCVVHdXzRe rE8W/1bz/S/X76L4+cecQ5667e6bPg0NLh+AE=
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...05-12-2017-08-52-38
Log Saved
Old 12-05-2017, 03:09   #1916 (permalink)
Member: 1211915
Sonork: 345634564
Thanks Meter: 93
INSTALL THIS JAVA
Old 12-05-2017, 03:22   #1917 (permalink)
Member: 1745922
same error 3311 after update from 58 to 59 i used it yesterday and it was working fine when i update the card it does it right but when i try to open the update 59 it say error 33111 no card this is my information
GCPro found...
Card verify ok...
Card OsVer 0002
GCPro SN:= GC5CCB1485
thanks.
Old 12-05-2017, 03:23   #1918 (permalink)
Member: 1930570
Thanks Meter: 82
HELLO
TEAM WILL NEED SOLUTION FOR THIS CARD PROBLEM
ALMOST ALL PEOPLE HAVING THE SAME PROBLEM
THE UPDATE WIPE THE SERIAL NUMBER AND CHANGE IT TO 0000
WILL NEED SOLUTION ASAP THANKS
GCPro SN GC
Card OsVer 0000
Invalid card sn...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-17-14-21
Log Saved
Old 12-05-2017, 03:40   #1919 (permalink)
Member: 2695419
i need help
GCPro SN
Card OsVer 0000
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-21-35-03
Old 12-05-2017, 03:44   #1920 (permalink)
Member: 2446529
Thanks Meter: 32
Help!!!
Bought from GPG
GCPro SN xxxxxxxxxx
Card OsVer 0002
CARD IS LOCKED CONTACT SUPPORT..
Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help..
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-19-43-42
Log Saved
Page generated in 0.32451 seconds with 10 queries
