12-27-2017, 03:05 | #2461 (permalink) |
Freak Poster Join Date: Dec 2006 Location: ib da da dan
Member: 405806 Status: Offline Thanks Meter: 17 | Card OsVer 0001 GCPro SN:= GC06A89B82 GCPRO Activation := NOT ACTIVE Checking server connection... Enter registration details for GCPro... Checking card.. Please update Card before using activation.. Fail at activation please contact support... Job finish ASAP.............. |
12-27-2017, 03:53 | #2462 (permalink) |
Junior Member Join Date: May 2006
Member: 277867 Status: Offline Thanks Meter: 1 | gs pro key fail update Checking GCPro Card Details... Checking server connection... GCPro SN GC26C500DE Card OsVer 0002 Checking security of card... GCPRO Activation := CARD IS ACTIVE Card error fail to start security session....6982 Fail to start security session,This CARD CAN NOT be updated,DO NOT TRY MORE.. Fail at verification... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...26-12-2017-21-51-08 |
12-27-2017, 07:57 | #2464 (permalink) |
Freak Poster Join Date: Apr 2006 Location: PH-unlocktoys
Member: 265729 Status: Offline Thanks Meter: 144 | my NEW gcpro key failed to update and register.. here's is the logs: Card verify ok... Card OsVer 0001 GCPro SN:= GCD342443A card error bad activation level...FE Checking server connection... Server Reply Error := ERR_USE_LATEST_UPDATE Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...27-12-2017-14-56-00 Log Saved |
12-27-2017, 16:39 | #2465 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1866017 Status: Offline Thanks Meter: 0 | lets try this for the 3rd time. would you please activate my card? Card verify ok... Card OsVer 0002 GCPro SN:= GC5A8C5CF3 GCPRO Activation := NOT ACTIVE Checking server connection... Enter registration details for GCPro... Checking card.. Please update Card before using activation.. Fail at activation please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...27-12-2017-09-33-06 |
12-27-2017, 23:08 | #2466 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dominican Republic Age: 40
Member: 605730 Status: Offline Sonork: 100.1605690 Thanks Meter: 70 | my card is bloked Checking server connection... Server access ok.. Making sure card is locked or not.. session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os... Reading Details.. Card Lock Reason := FcfBEQAhCAPAlhA0MU8Osf+Sbpx9raLvSjvaY6H6DhWDBC17np 549Qch0eSdHxzJ2j8= Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help.. please help |
12-28-2017, 05:11 | #2467 (permalink) |
Freak Poster Join Date: Aug 2013 Location: California
Member: 2013942 Status: Offline Thanks Meter: 33 | Card Locked?? Wont start?? Nothing new has been updated or added. The software simply wont start anymore out of the blue I have "GCPro_Update60" don't know what happend. |
12-28-2017, 15:46 | #2469 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @JHUNpanabO Hello Download update61 and update your gcpro then register it. @enrique702 Hello Please contact your reseller and tell him to add in server. |
The Following User Says Thank You to stanner_austin For This Useful Post: |
12-28-2017, 16:08 | #2470 (permalink) |
Junior Member Join Date: May 2016 Location: lima
Member: 2573235 Status: Offline Thanks Meter: 1 | please help GCPro found... Card verify ok... Card OsVer 0002 GCPro SN:= GC671745BC GCPRO Activation := CARD IS ACTIVE Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...28-12-2017-10-03-36 Log Saved |
12-28-2017, 16:13 | #2471 (permalink) |
12-28-2017, 16:25 | #2472 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2761501 Status: Offline Thanks Meter: 0 | Card verify ok... Card OsVer 0002 GCPro SN:= GC0DF7784C GCPRO Activation := NOT ACTIVE Checking server connection... Server Reply Error := ERR_USE_LATEST_UPDATE Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...28-12-2017-09-21-24 tengo este problema para poder activar mi caja alguien me puede ayudar |
12-28-2017, 16:34 | #2473 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @celcomputec Hello Download latest update61 and update with update tool if you have any issue paste log. @TRAZEK Hello Talk with your reseller tell him to allowed to be register/update. |
12-28-2017, 16:45 | #2475 (permalink) |
Member: 2573235 Status: Offline Thanks Meter: 1 | update error GCPro_Update59 help please GCPro found... Card verify ok... Card OsVer 0002 GCPro SN:= GC671745BC GCPRO Activation := CARD IS ACTIVE Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...28-12-2017-10-42-34 Log Saved Checking GCPro Card Details... Checking server connection... Server Reply Error := ERR_USE_LATEST_UPDATE Check internet connection, not able to connect server... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...28-12-2017-10-39-49 Log Saved |
