Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 01-11-2018, 00:19   #2611 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 30
Originally Posted by migue148 View Post
esta empresa de gcprokey no es nada profecional 3 meses y no puedes desbloquear mi gcprokey
Checking server connection...
Server access ok..
Card is Locked.
Making sure card is locked or not..
ERROR 0x1_islocked
Reading Details..
Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help..
GCPro SN := GC38420AEA
Fail at unlock card please contact support...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...10-01-2018-17-00-18
No digas nada porque luego stanner te pone ban por 20 días en todo gsmhosting marcando como spam las quejas
Sent from my iPhone using Tapatalk
Old 01-11-2018, 00:33   #2612 (permalink)
Member: 1081728
Thanks Meter: 7
Checking GCPro Card Details...
GCPro SN GCFD8E5C42
Card OsVer 0002
Checking security of card...
GCPRO Activation := CARD IS ACTIVE
Card crypto verify ok..
Please install JAVA 8 before update & restart computer before using. https://java.com/en/download/
error := bZBZDsMgDESvZJbg5NPb3P9IHVpFVaoKYbCN543AiVETwzujll SDIxHeXWx4mHH3SBumJi4XrjPvGYuVcPceLZVRShG1qAAwz51N eMlW3LXdpbJhv3QUmP2hAGTbdH/QehqyVrTq+/zSs1HJb/WYrP4yxJSEp3p5pycv4+R63xOLvlnnLxipwvnA8fFx9b1k2dJQ iaMdaypkvAA=
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...10-01-2018-18-23-24
ayuda con esto, cuando la trato de activar al update 61 me arroja este error y cuando abro el update 61 me dice lo siguiente
checking card failed apdu2
con un warning ... card not found ... error 33111.
agradesco la ayuda
Old 01-11-2018, 00:50   #2613 (permalink)
Member: 2502377
Hi,I purchased credits a few days ago,I had no problems at all.
Today,I bought Chimeratool and installed it on the same pc,but,when I tried to open Gcpro says it is locked..
Please help...I added the log
Server access ok..
session fail Card Locked..
Fail cardos Card Locked..
Fail to get card os...
Reading Details..
Card Lock Reason := Fce5EQAhDAPAlqzzF0sG+i/pYDbaVACzgSIPGdaZA++qim+F5ByuR+MNI2Xt2/ruBw==
GCPro SN := GC6A273639
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...10-01-2018-17-45-46
Old 01-11-2018, 01:30   #2614 (permalink)
Member: 2502377
Server access ok..
Reading Details..
Job finish
Old 01-11-2018, 02:13   #2615 (permalink)
Member: 2395490
Thanks Meter: 508
Smile
Originally Posted by mamun_noakhali View Post
gc pro card not found....error 33111
Very easy. Just reflash the driver card.
I had that problem almost every day
Old 01-11-2018, 02:39   #2616 (permalink)
Member: 2588927
Server access ok..
Reading Details..
Card Lock Reason := FcLJEQAxCAOwliAHOE8HnP5L2tmRWjLIeYr+2INelcx5sAFjpI fi/VK+Vk3UvQa0FB8=
GCPro SN := GC1536615D
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...10-01-2018-21-16-31
Old 01-11-2018, 09:36   #2617 (permalink)
Member: 1108881
gcpro card not found....error 33111
please help me---
gcpro card sn:-GCPro found...
Card verify ok...
Card OsVer 0002
GCPro SN:= GC4EFC6F40
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...10-01-2018-22-32-24
Old 01-11-2018, 14:10   #2618 (permalink)
Member: 2588927
Server access ok..
Reading Details..
Job finish
Old 01-11-2018, 17:17   #2619 (permalink)
Member: 2740916
Server access ok..
Card is Locked.
ERROR 0x1_islocked
Reading Details..
Job finish
problema resuelto gracias a Contact GCPro_support at skype
Old 01-11-2018, 18:04   #2620 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 30
Cuando llegan a contestar ! Tengo 2 semanas mandando mensajes y no me atienden
Old 01-12-2018, 00:30   #2621 (permalink)
Member: 1549521
Thanks Meter: 19
GC Pro Box card Blocked
My card was block it but support send me a software to fix it and is working but allway appear this message desconect your card to avoid to block... I dont know what is the problem, Gc_support told me "Log say it's locked due to 10 bad commands to card" and my question is " Bad Commands what it means"... I have other boxes and I don't have this problem... Thank You so much...
Old 01-12-2018, 07:15   #2622 (permalink)
Member: 247433
Thanks Meter: 25
Help bro...this is my customer
Server access ok..
Card is Locked.
ERROR 0x1_islocked
Reading Details..
GCPro SN := GC1B197A4A
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...06-01-2018-12-36-41
please help me ,,, still waiting for my solution ,,,
this my log before error
GCPro found...
Card verify ok...
Card OsVer 0002
GCPro SN:= GC1B197A4A
Job finish
In case of any error do not forget to show log to support team...29-10-2017-19-00-56
Log Saved
Verifying GCPro...
Card is already Updated to latst os := 0002
Job finish
In case of any error do not forget to show log to support team...29-10-2017-19-01-11
please help me ,, gcpro team ,, thanks.
Old 01-12-2018, 12:41   #2623 (permalink)
Member: 1947667
Thanks Meter: 30
GCPro found...
Card verify ok...
Card OsVer 0002
GCPro SN:= GC123A40F5
GCPRO Activation := NOT ACTIVE
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...11-01-2018-17-47-49
Old 01-12-2018, 13:28   #2624 (permalink)
Member: 2353137
Thanks Meter: 3
Hi, the message "desconect your card to avoid to block" it's a normal message, just appear to let you know if you have connected your smartcard and you do a not allowed step (ex. remote) or use any illegal program (ex. flexihub) your card will be blocked.
"Log say it's locked due to 10 bad commands to card" you should know what exactly you did, maybe another card or not allowed software.
Regards
Old 01-12-2018, 19:18   #2625 (permalink)
Member: 1549521
Thanks Meter: 19
Thank You for you repaly I'm going to check my pc because I don't share anything Thank You
Page generated in 0.45830 seconds with 8 queries
