Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 01-14-2018, 19:48   #2641 (permalink)
Member: 425933
Thanks Meter: 2
Card verify ok...
Card OsVer 0002
GCPro SN:= GCB7826C9B
GCPRO Activation := CARD IS ACTIVE
Card is Already Activated...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...14-01-2018-19-47-49
Old 01-14-2018, 20:11   #2642 (permalink)
Member: 425933
Thanks Meter: 2
RESELLER TST DUBAI
wwwtstunlockingcom
GCPro found...
Card verify ok...
Card OsVer 0002
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...14-01-2018-19-24-05
PLEASE HELP ME SOLVE THIS PROBLEM
Old 01-14-2018, 20:36   #2643 (permalink)
Member: 1176958
Thanks Meter: 157
hello friends i just got my new gcpro key dongle i got it form ebay and i need to activate
GCPro found...
Card verify ok...
Card OsVer 0002
GCPro SN:= xxxxxxxx
GCPRO Activation := NOT ACTIVE
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...14-01-2018-14-33-08
please help`me how to activated thanks in advance
Old 01-14-2018, 22:07   #2644 (permalink)
Member: 2388669
Sonork: 100.1664564
GCPro found...
Card verify ok...
Card OsVer 0002
GCPro SN:= GCE69BBBD4
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...14-01-2018-14-06-07
Checking GCPro Card Details...
Checking server connection...
Please check your internet connection...0
Check internet connection, not able to connect server...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...14-01-2018-13-50-03
GCPROKEY CAN NOT UPDATE , PLEASE HELP ME SOLVE THIS PROBLEM
Old 01-15-2018, 04:26   #2645 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 251
server still not up? we need to use our gcpro asap.
Old 01-15-2018, 13:35   #2646 (permalink)
Member: 368923
Thanks Meter: 79
gcpro key register problem.
hello gcpro key team , i have problem in registering gcpro key.pls help me
Card verify ok...
Card OsVer 0002
GCPro SN:= GC14B6F386
Please check your internet connection...404
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...15-01-2018-18-59-24
Old 01-15-2018, 13:57   #2647 (permalink)
Member: 2206266
Thanks Meter: 17
Checking Card failed apdu2
First Run this error
failed apdu2
Ok.
Verify Card verify ok...
Card OsVer 0003
GCPro SN:= [GC0559E5E8]
failed apdu3
Error 0x15.....
Fail to get Card reply...
Secend run this error
Checking Card Ok.
Verify Card session fail Card Locked..
fail to verify card...
PLEASE HELP
Old 01-15-2018, 20:32   #2648 (permalink)
Member: 1176958
Thanks Meter: 157
hello sr i purchase ur produts on ebay from reseller GPG industries GPGIndustries - The #1 Cable and Hardware used around the world
PJSparker his email is [email protected] address jian pan room 503 number 299.Xingnan street,Xinggiao,Songiang, Shangai 201612
here is my dongle details
GCPro found...
Card verify ok...
Card OsVer 0002
GCPro SN:= GC42E937E3
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...15-01-2018-15-23-52
please sir help me to activated ur the dongle thanks in advance
Old 01-15-2018, 20:33   #2649 (permalink)
Member: 1176958
Thanks Meter: 157
GCPro found...
Card verify ok...
Card OsVer 0002
Job finish
Old 01-15-2018, 22:04   #2650 (permalink)
Member: 2663665
My card is blocked
TEAM PLEASE HELP ME
my card is blocked
log
Server access ok..
Making sure card is locked or not..
Fail cardos Card Locked..
Fail to get card os...
Reading Details..
Card Lock Reason := FcLBEQAhCASwlkAB4bkL2n9JNzfJ0Fghpn0n3aFnobAnpK51Jw GH/ehPZIXpeofJTfkA
Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help..
GCPro SN := GCAC84201B
Fail at unlock card please contact support...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...12-01-2018-16-01-31
Old 01-16-2018, 00:37   #2651 (permalink)
Member: 2639378
Sonork: Legna
Install / update GCPro key issue
Hello
Recently I bought my GCProo. But I have not been able to use it, it marks me several errors.
Please help me install / update my GCPro key.
Attached screenshots with errors
Old 01-16-2018, 01:39   #2652 (permalink)
Member: 2800161
Problem activating gcpro
Por favor activar mi gcpro box
GCPro found...
Card verify ok...
Card OsVer 0000
GCPro SN:= GCA68CFF4A
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...15-01-2018-21-37-55
Old 01-16-2018, 02:47   #2653 (permalink)
Member: 2714111
GSM SOURCES
GCPro found...
Card verify ok...
Card OsVer 0002
GCPro SN:= GC753C1F66
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...15-01-2018-21-41-54
Old 01-16-2018, 03:03   #2654 (permalink)
Member: 2714111
GSM SOURCES
GCPro found...
Card verify ok...
Card OsVer 0002
Job finish
Old 01-16-2018, 05:59   #2655 (permalink)
Member: 2093632
Thanks Meter: 45
I had the same problem I solve it in the following way
first by deactivating my antivirus firewall second Update GCpro to the version 61 and third Register GCpro
Originally Posted by gttech View Post
I PURCHASED SOME GCPRO BOXES FROM GSM SERVER, AT THE MOMENT I'M GETTING THIS ERROR WHEN TRYING TO REGISTER:
Card verify ok...
Card OsVer 0002
GCPro SN:= GC78914DCB
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...13-01-2018-16-52-42
PC HAS PERFECT INTERNET CONNECTION, I NEED HELP WITH THIS ASAP.
THANKS.
Page generated in 0.41284 seconds with 8 queries
