Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 06-07-2018, 15:58   #3481 (permalink)
Member: 1396506
Using 1.25
Checking GCPro Card Details...
Card verify ok...
Card OsVer 0002
GCPro SN:= GCEFE39C6D
GCPRO Activation := NOT ACTIVE
Checking server connection...
GCPro SN GCEFE39C6D
Card OsVer 0002
Checking security of card...
CARD UUID:= 091566953FF913C5C5BF6848E03F778F316676B4
Card crypto verify ok..
Server Reply Error := ERR_CARD_Already_Updated.
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...01-06-2018-16-45-58 Using 1.25 NOT YET DONE
Old 06-07-2018, 16:26   #3482 (permalink)
Member: 2021294
Thanks Meter: 2
Hello CG pro team
I can't update cgpro key
how to update or fix Server Reply Error := ERR_CARD_Banned
Data....................
Card verify ok...
Card OsVer FFFF
GCPro SN:= GC8046D725
GCPRO Activation := CARD IS ACTIVE
GCPro SN GC8046D725
Card OsVer FFFF
Fail to get reply from server stage1.
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...07-06-2561-22-13-44 Using 1.25
Help me
Old 06-07-2018, 20:04   #3483 (permalink)
Member: 1648082
Sonork: dross
unlock my gcprokey, please.
Using 1.25
Server access ok..
Making sure card is locked or not..
session fail Card Locked..
Fail cardos Card Locked..
Fail to get card os read details...
Reading Details..
Card Lock Reason := FcLBEQAhCASwlljQRZ4o0H9JNzcJ9JU703IcOHF6IepiS0cD9E ej/txkq6QOprKCxQ8=
This GCPro is not Allowed to UPDATE or Register, Contact reseller..
GCPro SN := GCC2F02400
Fail at unlock card please contact support...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...07-06-2018-15-03-06 Using 1.25
Using 1.25
GCPro found...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...07-06-2018-15-03-57 Using 1.25
Old 06-07-2018, 21:44   #3484 (permalink)
Member: 2310178
order#8305
Using 1.25
Card OsVer 0003
GCPro SN:= GCDB7D6803
Enter registration details for GCPro...
Checking card..
Fail at activation please contact support...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...07-06-2018-16-36-47 Using 1.25
Old 06-08-2018, 00:15   #3485 (permalink)
Member: 1741168
com***** en gsmserver orden 1450316441
Using 1.25
Card OsVer 0003
GCPro SN:= GCFB575790
Checking card..
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...07-06-2018-17-05-12 Using 1.25
Old 06-08-2018, 01:54   #3486 (permalink)
Member: 2021294
Thanks Meter: 2
Hello Ahping LI GSM Number One Shop Seller
Help me
I can't update CGPro key
Using 1.25
Card verify ok...
Card OsVer FFFF
GCPro SN GC8046D725
Card OsVer FFFF
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...08-06-2561-07-52-31 Using 1.25
Old 06-08-2018, 02:32   #3487 (permalink)
Member: 2021294
Thanks Meter: 2
Where are you? Ahping LI GSM Number One Shop Seller
P้lease you help me
Where are you?
Thank so much >>>som**** form thailand : [email protected]
Old 06-08-2018, 16:08   #3488 (permalink)
Member: 332784
Thanks Meter: 12
Support off line please support help me friends
Old 06-08-2018, 16:15   #3489 (permalink)
Member: 332784
Thanks Meter: 12
Using 1.25
Server access ok..
Reading Details..
Card Lock Reason := FcLJEQAhCATAlHAGOZ6ImH9IW1vdCAN9d9M8l+OexcxdeJDaGS Qa98cemWNaOsIbGvwA
GCPro SN := GC50B697EF
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...08-06-2018-12-13-54 Using 1.25
Old 06-08-2018, 18:55   #3490 (permalink)
Member: 771786
Thanks Meter: 7
Exclamation
Using 1.25
Server access ok..
Reading Details..
Card Lock Reason := FcLBEQAgCAOwlSgKyLcI+4/keUmYl8mm5tgOqgRNeykSPuKovrjyFYxIgnq8j8z4Aw==
GCPro SN := GC9947A5A5
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...08-06-2018-12-53-35 Using 1.25
Old 06-08-2018, 22:32   #3491 (permalink)
Member: 2179112
Thanks Meter: 8
Using 1.25
Server access ok..
Reading Details..
Card Lock Reason := FcLJDcAwDAOwlXzUOb6ypf1HCgryxFagmp07T93yz1GWopnEq+ Cwf5qETxLWWgYsPg==
GCPro SN := GC181B4D83
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...08-06-2018-17-18-04 Using 1.25
Old 06-09-2018, 09:21   #3492 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
@rroca2015
@RONBEBE
@gustav8
@GARY2006A
@milk4you2c1
Hello
Open update tool and use update gcpro and issue will be resolved.
@David Cell
Hello
Your GCPro is demo/gift its expire, Please buy new gcpro.
@spc221
Hello
Please contact me on skype you used invalid email at register gcpro so its banned.provide us valid email and we will allow you update.
Best Regards,
GCPro_Team
GCPROKEY
The Following User Says Thank You to stanner_austin For This Useful Post:
Old 06-09-2018, 10:55   #3493 (permalink)
Member: 2295505
Using 1.25
Card verify ok...
Card OsVer FFFF
GCPro SN:= xxxxxxxxxx
GCPro SN xxxxxxxxxx
Card OsVer FFFF
CARD UUID:= xxxxxxxxxxxxxxxx
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...09-06-2018-14-53-00 Using 1.25
Old 06-09-2018, 12:48   #3494 (permalink)
Member: 332784
Thanks Meter: 12
Originally Posted by stanner_austin View Post
@rroca2015
@RONBEBE
@gustav8
@GARY2006A
@milk4you2c1
Hello
@David Cell
Hello
@spc221
Hello
Best Regards,
GCPro_Team
GCPROKEY
You can not afford to activate this same dongle so you do not have to buy another one.
The Following User Says Thank You to David Cell For This Useful Post:
Old 06-09-2018, 15:23   #3495 (permalink)
Member: 2310178
need activation please
Page generated in 0.35799 seconds with 9 queries
