07-19-2018, 09:02 | #3616 (permalink) |
Junior Member Join Date: Jan 2014 Location: jhguijhffdevbgjhnfjh
Member: 2099697 Status: Offline Thanks Meter: 1 | Checking GCPro Card Details... session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Checking server connection... GCPro SN GC939CC828 Card OsVer 0003 Fail getactivation Card Locked.. Card Lock Reason := FcLJEQAhCATAlNgBOZ7oSP4hWVvdIOKm+mX1AGJWrUruPWfFHG cg9OfIahmhT1quj3w= CARD UUID:= 08557595F5973DFCEFB9C3A022DB7BF8F2A99AD9 Card crypto verify ok.. Server Reply Error := ERR_CARD_Already_Updated. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...19-07-2018-10-02-09 Using 1.25 |
07-19-2018, 09:04 | #3617 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @youce1978 Hello Contact me on skype details in profile. @jose1500ac Hello Make sure GCPro card driver installed and c:\gcpro_team\ is in execlude from scan in antivirus and windows defender. Try one more time. update gcpro. @Gabriele25_5 @gravemind @bismed Hello Please select update gcpro in update tool and issue will be solved. |
The Following User Says Thank You to stanner_austin For This Useful Post: |
07-21-2018, 01:09 | #3618 (permalink) |
Junior Member Join Date: May 2014
Member: 2178554 Status: Offline Sonork: clasico Thanks Meter: 0 | Using 1.25 Checking GCPro Card Details... Card verify ok... Card OsVer 0002 GCPro SN:= GC30D576FF GCPRO Activation := CARD IS ACTIVE Checking server connection... GCPro SN GC30D576FF Card OsVer 0002 Checking security of card... GCPRO Activation := CARD IS ACTIVE CARD UUID:= 09373095E7A7CA81B5E83C7CFF08E6069769F92A Card error fail to start security session....6982 Fail to start security session,This CARD CAN NOT be updated,DO NOT TRY MORE.. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...21-07-2018-02-07-59 Using 1.25 |
07-21-2018, 01:30 | #3619 (permalink) |
07-21-2018, 01:58 | #3620 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2055160 Status: Offline Thanks Meter: 0 | GCPro SN:= GC49FFBBCD GCPRO Activation := NOT ACTIVE Checking server connection... GCPro SN GC49FFBBCD Card OsVer 0003 GCPRO Activation := NOT ACTIVE CARD UUID:= 09228595AB96A4C2051544A13831F12279AFF061 Card crypto verify ok.. Server Reply Error := ERR_CARD_Already_Updated. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...20-07-2018-19-58-04 Using 1.25 |
07-21-2018, 11:39 | #3621 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @clasico2 Hello Please read thread http://forum.gsmhosting.com/vbb/f922.../#post12857266 @strufi Hello For activation only contact reseller not us.. in case you buy directly from GCPROKEY paste us your order number. without that we can not help sorry. |
07-21-2018, 14:26 | #3622 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2563583 Status: Offline Thanks Meter: 4 | sing 1.25 Card OsVer 0003 GCPro SN:= GC1E99E0E5 GCPRO Activation := NOT ACTIVE Checking server connection... Please check your internet connection...106 Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...21-07-2018-06-24-48 Using 1.25 |
07-21-2018, 14:59 | #3623 (permalink) | |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @noman_321 Hello This is your internet or vpn issue. Quote:
07-21-2018, 16:41 | #3624 (permalink) |
Member: 2563583 Status: Offline Thanks Meter: 4 | Sir Card Is Active Now But show this error Checking Card Ok. Verify Card verify ok... Card OsVer 0003 GCPro SN:= [GC1E99E0E5] GCPRO Activation := CARD IS ACTIVE Error 0x82 Security... |
07-21-2018, 17:01 | #3625 (permalink) |
Junior Member Join Date: Jul 2018
Member: 2852270 Status: Offline Sonork: [email protected] Thanks Meter: 0 | si me prodria ayududar don la activacion de mi gspro key solo me aparece esto Using 1.25 Card OsVer 0003 GCPro SN:= GCDA237D90 GCPRO Activation := NOT ACTIVE Checking server connection... Enter registration details for GCPro... Checking card.. This GCPro is not Allowed to UPDATE or Register, Contact reseller.. Fail at activation please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...21-07-2018-10-47-14 Using 1.25 |
07-21-2018, 19:08 | #3626 (permalink) |
Member: 2852270 Status: Offline Sonork: [email protected] Thanks Meter: 0 | si me prodria ayududar don la activacion de mi gspro key solo me aparece esto Usando 1.25 Card OsVer 0003 GCPro SN: = GCDA237D90 GCPRO Activación: = NO ACTIVO Comprobando la conexión del servidor ... Ingrese los datos de registro para GCPro ... Tarjeta de verificación .. Esto GCPro no se permite ACTUALIZAR o registrar, contactar al distribuidor .. Fallar al momento de la activación, contactar con el servicio de asistencia ... Finalización del trabajo No perder los registros antiguos que pueden ayudar a solucionar el problema rápi*****te. Mostrar registro al equipo de soporte en caso de error ... 21-07-2018-10-47-14 Usando 1.25 |
07-22-2018, 09:10 | #3627 (permalink) |
Member: 2099697 Status: Offline Thanks Meter: 1 | ---------------------update---------------------------------- Using 1.25 Checking GCPro Card Details... session fail Card Locked.. session fail Card Locked.. Fail to start session with card... Checking server connection... GCPro SN GC939CC828 Card OsVer 0003 Fail getactivation Card Locked.. Card Lock Reason := FcLHDcAwDASwlU7lYvmpEu0/UhCQILYhb7N0EvF0qdTy2vjZcSeT9fM8ptcitMR2DPgA CARD UUID:= 08557595F5973DFCEFB9C3A022DB7BF8F2A99AD9 Card crypto verify ok.. Server Reply Error := ERR_CARD_Already_Updated. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...22-07-2018-10-07-09 Using 1.25 ----------------unlock gc pro key----------------------- Using 1.25 Checking server connection... Server access ok.. Making sure card is locked or not.. session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Reading Details.. Card Lock Reason := FcLBEYAwDAOwlcCOU/pMqLP/SBwnQRhftLUxhSfeDfZRc0IzkVq1+pdVt1khHoGC8wM= This GCPro is not Allowed to UPDATE or Register, Contact reseller.. GCPro SN := GC939CC828 Fail at unlock card please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...22-07-2018-10-07-37 Using 1.25 i send you message on skype : le bon coeur |
07-23-2018, 17:51 | #3628 (permalink) |
Junior Member Join Date: Sep 2016
Member: 2630420 Status: Offline Sonork: chipo Thanks Meter: 0 | Using 1.25 Checking GCPro Card Details... Fail to start session with card... Checking server connection... GCPro SN GCF21E024C Card OsVer 0000 Fail getactivation with 1B00 Card Lock Reason := NcK5EQAwCAOwlcC8Lc6R/UdKlZPU9XDzOtkTkAa2Kjtt7AQp9imIhbDWpTWj8AA= Please UnLock GCPro First... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...23-07-2018-11-49-53 Using 1.25 |
07-23-2018, 20:47 | #3629 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2230711 Status: Offline Thanks Meter: 0 | hi i need help my gcpro is blocked that's my data GCPro SN := GCD734E821 Using 1.25 Checking server connection... Server access ok.. Making sure card is locked or not.. session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Reading Details.. Card Lock Reason := FcLBDcAwCASwlQ4IAZ7lBPuPFFW2dmIC+1mhRH0nRh1XcsmQEc KgP7HjdxiFPrbbyQc= Server Reply Error := ERR_CARD_Banned GCPro SN := GCD734E821 Fail at unlock card please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...23-07-2018-15-44-57 Using 1.25 |
07-23-2018, 21:11 | #3630 (permalink) |
Freak Poster Join Date: Apr 2014
Member: 2161676 Status: Offline Thanks Meter: 7 | help my card is locked Using 1.25 Checking server connection... Server access ok.. Making sure card is locked or not.. session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Reading Details.. Card Lock Reason := FcLBEcAwCAOwlQoGJzzjQPcfqdeT3gLt9sPQwlGCNzU0zwlb3r vLC7/tKY7QQRzKmB8= This GCPro is not Allowed to UPDATE or Register, Contact reseller.. GCPro SN := GC7AC1D6CA Fail at unlock card please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...23-07-2018-17-11-01 Using 1.25 |
