09-26-2018, 19:03 | #3843 (permalink) |
Junior Member Join Date: Jul 2018
Member: 2850455 Status: Offline Thanks Meter: 0 | Using 1.25 Card OsVer 0003 GCPro SN:= GC6712102C GCPRO Activation := NOT ACTIVE Checking server connection... Enter registration details for GCPro... Checking card.. This GCPro is not Allowed to UPDATE or Register, Contact reseller.. Fail at activation please contact support... Job finish. help me please! |
09-27-2018, 08:14 | #3844 (permalink) |
No Life Poster Join Date: Jul 2012 Location: vietnam
Member: 1781157 Status: Offline Sonork: 100.1624851 Thanks Meter: 167 | Checking GCPro Card Details... session fail Card Locked.. session fail Card Locked.. Fail to start session with card... Checking server connection... GCPro SN GC6DBD8723 Card OsVer 0003 Fail getactivation Card Locked.. |
The Following User Says Thank You to ngocdiemmobile For This Useful Post: |
09-27-2018, 08:15 | #3845 (permalink) |
09-27-2018, 09:52 | #3846 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @black_spider00 @Expertos Hello Please select update gcpro in update tool and issue will be solved. @aodunsi Hello Please check your pc date and update to latest update from sticky thread. @ngocdiemmobile Hello Your log is half we need full log to help you. |
The Following 2 Users Say Thank You to stanner_austin For This Useful Post: |
09-27-2018, 21:43 | #3847 (permalink) |
Junior Member Join Date: Sep 2018
Member: 2868426 Status: Offline Thanks Meter: 1 | Can you help me with this problem? Using 1.25 Checking GCPro Card Details... Card verify ok... Card OsVer 0001 GCPro SN:= GCD9DB20DD GCPRO Activation := NOT ACTIVE Checking server connection... GCPro SN GCD9DB20DD Card OsVer 0001 Checking security of card... GCPRO Activation := NOT ACTIVE CARD UUID:= 06528595EA85BC747F0DF660476CE8F7067EF7C6 Card crypto verify ok.. This GCPro is not Allowed to UPDATE or Register, Contact reseller.. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...27-09-2018-14-26-10 Using 1.25 |
The Following User Says Thank You to memecruz For This Useful Post: |
09-28-2018, 13:10 | #3848 (permalink) |
Member: 1781157 Status: Offline Sonork: 100.1624851 Thanks Meter: 167 | Using 1.25 Checking GCPro Card Details... session fail Card Locked.. session fail Card Locked.. Fail to start session with card... Checking server connection... GCPro SN GC6DBD8723 Card OsVer 0003 Fail getactivation Card Locked.. Card Lock Reason := FcLJEQAgCASwljgE5SnH9l+S4yQECh7zpMuQJjm51MentE9ehU xPfWiEWUtgbQ6pxAM= CARD UUID:= 0998559548AC0A6F6CC2B9911313331151F9D59C Card crypto verify ok.. Server Reply Error := ERR_CARD_Already_Updated. |
09-28-2018, 21:20 | #3850 (permalink) |
Junior Member Join Date: Jan 2007 Location: accra
Member: 425933 Status: Offline Thanks Meter: 2 | Problem with my dongle Using 1.25 Checking server connection... Server access ok.. Making sure card is locked or not.. session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Reading Details.. Card Lock Reason := FcbBEQAhCAPAlm5EAnyDof+STmc/u+nGziLk4WESLIjKWkatrW9m9Gimj4B7KlLoHw== This GCPro is not Allowed to UPDATE or Register, Contact reseller.. GCPro SN := GCB7826C9B Fail at unlock card please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...28-09-2018-20-19-47 Using 1.25 |
09-29-2018, 11:20 | #3851 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2525507 Status: Offline Thanks Meter: 0 | read Using 1.25 GCPro found... session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...29-09-2018-13-18-04 Using 1.25 update Using 1.25 Checking GCPro Card Details... session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Checking server connection... GCPro SN GC1A7ABDBA Card OsVer 0003 Fail getactivation Card Locked.. Card Lock Reason := czRxMsUHHZ2czKAsE0dLc1dnZ0MXFwtHQ1cDYwMA Please UnLock GCPro First... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...29-09-2018-13-18-38 Using 1.25 register Using 1.25 session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...29-09-2018-13-19-01 Using 1.25 unlockk Using 1.25 Checking server connection... Server access ok.. Making sure card is locked or not.. session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Reading Details.. Card Lock Reason := M3c2c8EHzY3NXKEsZwsDQzMDYwM3J0cnEwtDNxMA This GCPro is not Allowed to UPDATE or Register, Contact reseller.. GCPro SN := GC1A7ABDBA Fail at unlock card please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...29-09-2018-13-19-33 Using 1.25 check replacement Using 1.25 CARD UUID:= 0637439599C7331A86931E72A18C2C1DE9500B86 1 Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...29-09-2018-13-19-50 Using 1.25 |
09-30-2018, 03:29 | #3852 (permalink) |
Member: 2868846 Status: Offline Thanks Meter: 0 | please help Using 1.25 Card OsVer 0003 GCPro SN:= GCA9E2B594 GCPRO Activation := NOT ACTIVE Checking server connection... Enter registration details for GCPro... Checking card.. This GCPro is not Allowed to UPDATE or Register, Contact reseller.. Fail at activation please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...29-09-2018-22-06-05 Using 1.25 |
09-30-2018, 08:39 | #3853 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2659500 Status: Offline Thanks Meter: 6 | Using 1.25 Checking server connection... Server access ok.. Making sure card is locked or not.. session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Reading Details.. Card Lock Reason := MzI3NsMHjSyMTaEscxMXRycjFycTF1MLV2MLA2cA This GCPro is not Allowed to UPDATE or Register, Contact reseller.. GCPro SN := GCE6F54DE3 Fail at unlock card please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...30-09-2018-14-42-01 Using 1.25 Please Help me! Last edited by minhhai1241991; 09-30-2018 at 08:45. Reason: log |
09-30-2018, 12:28 | #3854 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Dubai
Member: 703206 Status: Offline Sonork: 100.1601193 Thanks Meter: 412 | Using 1.25 Checking GCPro Card Details... session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Checking server connection... GCPro SN GCABDB3FEF Card OsVer 0003 Fail getactivation Card Locked.. Card Lock Reason := FcJBEsBABATALyExOBp2//+kVKpbU93NyygSnTvGQ31G+sbGiwAK+YtaGdfTyeJtQD8= CARD UUID:= 0052429550DBB1B827FAF90FAB36C4E28E0EF188 Card crypto verify ok.. Server Reply Error := ERR_CARD_Already_Updated. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...30-09-2018-16-26-27 Using 1.25 |
09-30-2018, 13:13 | #3855 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @phonet Hello Please select update gcpro in update tool and issue will be solved. @esevindi @minhhai1241991 Hello You try to use spy tool no unlock for you sorry. buy new gcpro and do not use spy tool. |
