Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 01-16-2019, 19:27   #4126 (permalink)
Member: 322470
Sonork: 1596253
Thanks Meter: 25
hi , card is locked can you help me
Using 1.27
Checking GCPro Card Details...
Reader := Alcor Micro USB Smart Card Reader 0
session fail Card Locked..
Fail to start session with card...
Checking server connection...
GCPro SN GCC1BD89E2
Card OsVer 0003
Fail getactivation Card Locked..
Card Lock Reason := HcnBEQAhCASwloRdEJ4MaP8leXP5Zm8nZDLDr1/2AUdWUa0qzByt0B8wCEZ+KcwWwwM=
CARD UUID:= 07113295EE49AA0B0B7CD2EE3B8C102DCD938133
Card crypto verify ok..
Server Reply Error := ERR_CARD_Already_Updated.
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...16-
01-2019-15-20-33 Using 1.27
Using 1.27
Server access ok..
Making sure card is locked or not..
Fail cardos Card Locked..
Fail to get card os read details...
Reading Details..
Card Lock Reason := FcLJEQAgCASwlgQR8Llc/ZfkOMlkT+Aw7ZaWNPXUGzxoptVVYXDcLxyr+CiMVCZp5AE=
This GCPro is not Allowed to UPDATE or Register, Contact reseller..
GCPro SN := GCC1BD89E2
Fail at unlock card please contact support...
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...16-01-2019-15-22-42 Using 1.27
Old 01-17-2019, 09:03   #4127 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
@tageroice
Hello
Look like you failed to update last time.. Please contact us on skype.
@cellmod
Hello
Please use update gcpro in update tool and issue will be solved.
Old 01-17-2019, 18:29   #4128 (permalink)
Member: 194874
Thanks Meter: 458
not update
HELP ME PLEASE . ALL BOX ALL WORKS.GC PRO DOES NOT WORK.
I deleted the GCPRO FOLDER. I INSTALL AGAIN GCPro69Setup
SAME ERROR.
Using 1.27
GCPro SN GCFAD7883A
Card OsVer 0003
Card Lock Reason := FcLJDcBACAPAljhCFp4B4/5LWkUz3/aZmE4FQZ83SyPFSqUfApDh7A+0U/T1sNDsWF4=
CARD UUID:= 06856995ADB07F84BDB73CB759E3F141884863AF
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...17-01-2019-20-17-49 Using 1.27
Using 1.27
Server access ok..
Reading Details..
Card Lock Reason := FcJBEsBABATAL1kTxBGz/v+kVKrb5jEEMqBUzs1yVK04Npu6qiDmp+S1PHGq3xbxqQ8=
GCPro SN := GCFAD7883A
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...17-01-2019-20-24-02 Using 1.27
Old 01-18-2019, 16:12   #4129 (permalink)
Member: 2726882
Thanks Meter: 2
register gcp pro key
Using 1.26
Reader := Generic EMV Smartcard Reader 0
Card OsVer 0003
GCPro SN:= GCC2270B19
GCPRO Activation := NOT ACTIVE
Server Reply Error := ERR_USE_NEW_SETUP..
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...18-01-2019-12-50-02 Using 1.26
i bought it on aliexpress from ha smart
now i cannot register,
plz help
Old 01-19-2019, 04:57   #4130 (permalink)
Member: 2889658
Sonork: cu
Post Help my please
Using 1.27
Card OsVer 0003
GCPro SN:= GCAD6228D6
Enter registration details for GCPro...
Checking card..
Fail at activation please contact support...
Job finish
Old 01-19-2019, 09:32   #4131 (permalink)
Member: 49752
Thanks Meter: 6,085
@WhyLeR
Hello
Old 01-19-2019, 09:32   #4132 (permalink)
Member: 49752
Thanks Meter: 6,085
@WhyLeR
Hello
Old 01-19-2019, 14:05   #4133 (permalink)
Member: 2889658
Sonork: cu
nada todabia
Card OsVer 0003
Checking card..
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...19-01-2019-08-04-35 Using 1.27
Old 01-19-2019, 16:49   #4134 (permalink)
Member: 2889658
Sonork: cu
Thumbs up Please I need help I need urgently to activate my key....
Using 1.27
Card OsVer 0003
Checking card..
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...19-01-2019-08-22-37 Using 1.27
: eek:: eek:: eek:: eek:: eek:
Old 01-19-2019, 22:59   #4135 (permalink)
Member: 2726882
Thanks Meter: 2
Originally Posted by Aliesky cell View Post
Using 1.27
Card OsVer 0003
Checking card..
Job finish
facing the same problem
i bought my gcpro key in aliexpress as in my country dont have oficial reseller now i cannot activate my gcpro key NOT ACTIVE
Enviado de meu SM-G935F usando Tapatalk
Old 01-19-2019, 23:01   #4136 (permalink)
Member: 2726882
Thanks Meter: 2
Originally Posted by stanner_austin View Post
@WhyLeR
Hello
Using 1.26
Card OsVer 0003
Job finish
help please, its been 3 days trying to activate, its says NOT ACTIVE
Old 01-20-2019, 07:04   #4137 (permalink)
Member: 2889658
Sonork: cu
I supplicate help please
Usando 1.27
Reader: = Generic EMV Smartcard Reader 0
Tarjeta OsVer 0003
GCPro SN: = GCAD6228D6
Activación de GCPRO: = NO ACTIVA
Comprobando la conexión del servidor ...
Ingrese los detalles de registro para GCPro ...
Tarjeta de verificación.
Este GCPro no se puede ACTUALIZAR o Regístrese, póngase en contacto con el revendedor ...
Fallo en la activación, póngase en contacto con el servicio de asistencia ...
Finalización del trabajo
No pierda el borrado de registros antiguos, pueden ayudar en algún momento para solucionar su problema rápi*****te ... Mostrar registro al equipo de soporte en caso de error ... 19-01 -2019-08-22-37 Usando 1.27
Old 01-20-2019, 12:51   #4138 (permalink)
Member: 2889658
Sonork: cu
Usando 1.27
Tarjeta OsVer 0003
Comprobar la conexión del servidor ...
Ingrese los detalles del registro para GCPro ...
Este documento no se puede ACTUALIZAR o Regístrese, póngase en contacto con el revendedor ...
No pierda el préstamo de los registros antiguos, puede ayudar en algún momento ***** te ... Mostrar registro en el equipo de soporte en caso de error ... 19-01 -2019-08-22-37 Usando 1.27
Old 01-21-2019, 12:14   #4139 (permalink)
Member: 194874
Thanks Meter: 458
thanks
@WhyLeR
Hello
Using 1.27
GCPro SN GCFA
Card OsVer 0003
Card Lock Reason := FcvBEYAwDAOwlSClTv20Sbr/SIXTW++qW0PVaZpTV+8cjWcnKmgbotbPhIEI1AT9LRw=
CARD UUID:= 06
Please do not make any other task.
Card Update Started...
Updating GCPro DO NOT TOUCH...
Card update ok..
Card OsVer 0003
GCPro SN:= GCFA
GCPRO Activation := CARD IS ACTIVE
Job finish
Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...19-01-2019-11-58-30 Using 1.27
Old 01-22-2019, 16:13   #4140 (permalink)
Member: 2619575
help Fail getactivation Card Locked..
Page generated in 0.31557 seconds with 10 queries
