04-27-2016, 02:17 | #1 (permalink) |
Crazy Poster Join Date: Jan 2013 Location: san diego ca
Member: 1863178 Status: Offline Thanks Meter: 15 | GCPRO Verify card _islocked WHY?(solved) |
04-27-2016, 03:19 | #3 (permalink) |
No Life Poster Join Date: Nov 2013 Location: Third World ;)
Member: 2061381 Status: Offline Sonork: 100.1673769 Thanks Meter: 129 | I think they need to improve his security methods, I think instead of blocking card they shoud do to program close till "sppy", sniffer, logging or whatever else was closed or uninstalled from computer. In my opinion it is still secure and less complicated to resolve for supporters and users (that many times don't know why his cards get blocked). |
04-27-2016, 03:21 | #4 (permalink) |
04-27-2016, 07:11 | #6 (permalink) | ||
No Life Poster Join Date: Apr 2015
Member: 2385015 Status: Offline Thanks Meter: 884 | Quote:
Your card is blocked due to you have installed some Usb Port monitoring software. Br, GPGTeam | ||
The Following User Says Thank You to Natashah For This Useful Post: |
04-27-2016, 07:47 | #7 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1182534 Status: Offline Thanks Meter: 6 | Team GCpro should seek to monitor the users to buy and do not share do not crack, does not violate the charter of the team that was so not fair block. Other teams z3x, oct, medusa. setool ..... they do not need to do so, but still managed. Gcpro team hopes will change the way surveillance is not his intelligence. |
The Following User Says Thank You to imnhaque For This Useful Post: |
04-27-2016, 08:23 | #8 (permalink) |
Member: 1863178 Status: Offline Thanks Meter: 15 | @Natashah what software are you talking about tell me ill delete it or whaever it was BS pls unblock my card i dont even know how to use usb port monitoring software or whatever you are talking about |
04-28-2016, 06:20 | #10 (permalink) | |
Member: 2061381 Status: Offline Sonork: 100.1673769 Thanks Meter: 129 | Quote:
I wouldn't like to be using my GCPro for a job and in a second got it blocked and have to wait to supporter to unblock it again (I don't use any usb sharing and nothing like). My suggestion is that instead of block card, program closes with some warning message that it won't open untill you clean your pc, in my opinion it is more convenient for users and supporters without loosing security. PD: I agree with security methods to prevent cracking our investment. But also think that don't have to be harmful for users. | |
The Following User Says Thank You to joel_3mo For This Useful Post: |
04-28-2016, 07:24 | #11 (permalink) | |
Please contect to GCPro Team on skype. His skype ID is gcpro_support. Br, GPGTeam | |
04-28-2016, 10:36 | #12 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @joel_3mo Hello Again gcpro will lock card only if spy tool running. but i noticed user @trezegol uninstalled it and left drivers behind and used old gcpro version which do lock card even if you installed such things. i tell this again use latest or card will be blocked if pc have any spy tools. Latest update will give you warning limited time then lock card. Latest update will lock your card if you use any known spy tools while using gcpro. if you still use older version and lock your dongle instead of reporting with logs & found bug on any function we can help you one time with valid reason. btw user "trezegol" problem is solved yesterday same time when he contact us via skype. |
