Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 05-24-2014, 06:44   #1 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
GCPro Exclusive Frequently Asked Questions
  • Just bought GcPro Key or GcPro Box how to Register & Active & Download Latest Update Version ?
    • Download Drivers
      • For GcPro Key Download "CARD Driver"
      • For GcPro Box Download "FTDI BOX DRIVER" & "CARD Driver"
    • Extract GCProXXSetup.rar (which you download from support area) in Folder & Drivers as well
    • Plug GcproKey or GcProBox into computer's usb & Install drivers if needed
    • Run "GCPro UPDATE Tool" , Make sure Only GCPRO is plugged into computer & All other Devices/Boxes/Dongles are not attached with computer
    • Select "Register GCPro" From "GCPROUPDTOOLOK"
    • Click on "Do Job" & Make sure have stable Internet is Connected & All Firewall & Antivirus are Off
    • When software prompt. Enter you Valid email address
    • Wait few moments, Software will say Confirm your Registration and send you activation code to your email. enter that code in software without space or any other sign.
    • Enjoy !! your Gcpro is successfully Registered & Ready to use !!!
The Following 15 Users Say Thank You to Faisal_Computer For This Useful Post:
Old 01-08-2015, 15:01   #2 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
Where can i find free CERT by GCPro.?
  • From where to Download FREE Cert ?
    • Go to Support Area
    • Download "FREE_GC_CERTS_33.rar"
      • These CERT is Compatible only & only with GCProKey Software !!
      Here is list of CERT Available !!
      GCPRO_357554xxxxxx_G361F_MANY_PXA_0001_gc.cert
      GCPRO_351559xxxxxxxxx_G920_G925_ANYEXY_0346 _.cert
      GCPRO_351665xxxxxxxxx_N750_EXY_0640_gc.cert
      GCPRO_352309xxxxxxxxx_G7102.cert
      GCPRO_352554xxxxxxxxx_352555xxxxxxxxx_G355HANY_J100F_0118_gc.cert
      GCPRO_352558xxxxxxxxx_G900M,F,A,T_ANYQC.cert
      GCPRO_352608xxxxxxxxx_I9301I_0865_gc.cert
      GCPRO_352901xxxxxxxxx_N7502_0839_gc.cert
      GCPRO_353110xxxxxxxxx_G900M,F,A,T_ANYQC.cert
      GCPRO_353284xxxxxxxxx_G900H_EXY.cert
      GCPRO_353285xxxxxxxxx_G900H_EXY.cert
      GCPRO_353415xxxxxxxxx_G900H_EXY.cert
      GCPRO_355167xxxxxxxxx_I9500_EXY_.cert
      GCPRO_355427xxxxxxxxx_G850Y_G850F_0932_gc.cert
      GCPRO_355585xxxxxxxxx__G850A_G8508S_G850W_0793_gc.cert
      GCPRO_355698xxxxxxxxx_355699xxxxxxxxx_I8262_0086_gc.cert
      GCPRO_355847xxxxxxxxx_I9515_gc.cert
      GCPRO_356095xxxxxxxxx_N910T,F,A,W8_0772_.cert
      GCPRO_356886xxxxxxxxx_G110H_0093_gc.cert
      GCPRO_357092xxxxxxxxx_357091xxxxxxxxx_I8552_0246_gc.cert
      GCPRO_357138xxxxxxxxx_I9500_EXY_.cert
      GCPRO_357201xxxxxxxxx_357202xxxxxxxxx_G313ANY,G316ANY_0117_gc.cert
      GCPRO_357504xxxxxxxxx_I9500_EXY_.cert
      GCPRO_357633xxxxxxxxx_I9500_0833.cert
      GCPRO_357633xxxxxxxxx_I9500_EXY_.cert
      GCPRO_35789xxxxxxxxxx_I9500_0833.cert
      GCPRO_35802xxxxxxxxxx_N900ANY_.cert
      GCPRO_358917xxxxxxxxx_N900ANY_.cert
      GCPRO_359092xxxxxxxxx_N900ANY_.cert
      GCPRO_359542xxxxxxxxx_N900ANY_.cert
The Following 17 Users Say Thank You to stanner_austin For This Useful Post:
Old 08-15-2017, 13:03   #3 (permalink)
Member: 49752
Thanks Meter: 6,085
  • How to Update GcPro CARD for Latest version Updates
    • When GcPro Update needed ?
      • if your CARD FIRM VER := FFFF
      • if your CARD FIRM VER := 0001
      • if your CARD FIRM VER := 0002
        • Please Note: If your CARD FIRM VER := 0003 YOU MUST TRY FIRST UPDATE GCPro!!
        • Please Note: If your CARD FIRM VER := 0004 YOU DON'T(DO NOT) NEED UPDATE IT!
      • Precautions !! Read it Carefully !! if you failed to update, you may loose your GCPRO for ever !! by any Reason you managed to damaged your GCPRO we will not RESPONSIBLE
        • Make Sure GcPro is connected/Plugged directly into computer's usb port.
        • Do not Connect/Plug GcPro to USB HUB
        • If you have GcPro. Make sure you follow all above steps as well as USB cable is not more than 1 metter.
        • Make sure you use STABLE Internet. If during update internet disconnected you may lose your Gcpro.
        • Make sure you have Enough POWER BACKUP !! During Update if Computer Restarted or powered off result will be Bricked GCPRO
        • EACH GCPRO ALLOWED ONLY ONCE FOR UPDATE, DO NOT TRY TO UPDATE WITHOUT ANY REASON OR IF YOU GET ANY ERROR DO NOT TRY TO UPDATE AGAIN AND IF YOU ARE NOT SURE CONTACT WITH YOUR RESELLER FOR UPDATE
        • you do not understand any thing, we advice you do not update GCPRO to your own self. you must contact with your reseller for update.
        • Make sure no FIREWALL or ANTIVIRUS running behind & not blocked connectivity of GCPRO to it's server.
        • Make sure Windows Defender Add Folder Exclude from scan C:\GCPro_Team\ before start update or any exe.
    • I Read & Understand all & i'm updating at my OWN RISK.... Now, How to update GCPRO ?
      • Download GCPro SETUP from SUPPORT AREA
      • Open GCPro UPDATE Tool from desktop.
      • Select "Update GcPro" from list
      • Click on "Do Job"
        Picture for Reference !!
        • Common Server Problems,
          • ERR_BADCMD or SN GC00000000
            • You need to contact GCPro_support at skype with your REAL SN or last fail log.
          • ERR_USE_LATEST_UPDATE
            • You need to Download & Use Latest GCPRO Update... Support Area links already given in 1st post.
          • Card is not Allowed to UPDATE
            • If you get reply "NOT ACTIVE". you have to contact with your Reseller. Ask him to ADD serial in server for activation. Only your Reseller Can do !!!
    • In-case of any problem. Contact Us On Skype or GcproKey Facebook page or use this thread
    • In-case of any problem. you have to provide us ALL Files from
      UPDATETOOL\LOGS\ Folder
    • In-case of any problem. DO NOT DELETE ANY FILE - LOGS FROM UPDATETOOL\LOGS\ FOLDER.
    • In-case of any problem. IF YOU LOOSE/DELETE ANY FILE FROM UPDATETOOL\LOGS\ FOLDER WILL MAKE HARD FOR US FOR RECOVER YOUR CARD !!!!
    • In-case of any problem. DO NOT TRY TO UPDATE YOUR GCPRO AGAIN UNTIL WE DON'T SAY YOU FOR UPDATE !! IF YOU UPDATE YOUR GCPRO WITHOUT TELLING US RESULTS MAY LOCKED YOUR GCPRO FOREVER OR DAMAGED FOREVER !!
The Following 7 Users Say Thank You to stanner_austin For This Useful Post:
Old 02-09-2018, 12:02   #4 (permalink)
Member: 49752
Thanks Meter: 6,085
Before start please verify with *#0011# IMEICERT PASS, MIPI PASS NO ERROR ELSE YOU HAVE NETWORK ISSUE.
  • How to Unlock Samsung SM-G950U & SM-G955U Locked on Sprint with GCPRO
    • You have to confirm your Firmware version inside mobile which you want to unlock.
      • you can confirm by "ADB INFO" from GCPRO software or Dial *#1234# from Mobile and check Firmware version inside phone.
    • NOW IF your phone have
      • S1 OR U1 this means your phone have REV 1 Firmware. So,
      • S2 OR U2 this means your phone have REV 2 Firmware. So,
        • For G950U download G950USQU2AQK2 full combination from internet and flash the phone (flash complete combination file)
        • For G955U download G955USQU2AQK2 full combination from internet and flash the phone (flash complete combination file)
      • Select Sprint Unlock from GCPro software. It will Unlock your phone
      • after successful unlock. Flash Stock firmware to your phone.
  • How to Unlock Samsung SM-N950U Locked on Sprint with GCPRO
    • Download Latest Odin
    • Put your phone into Recovery Mode
    • Select WIPE DATA
    • DO NOT RESTART PHONE !!!
    • Select REBOOT TO BOOT-LOADER
      • if you do not follow it exactly it will stuck on logo you have to reflash stock and continue again from first step.
For all other phones basic steps is same You can ether root or use combination & sprint unlock option in GCPro samsung tab will unlock it.
Note that J327P/J727P use rsa protection on U3 firmware and newer firmware may use same in future so no more unlocking for them yet do not spam with when or unlock success not unlocked etc.. such post will be deleted.
Please do not ask us stock or combination files we do not host them you can find them via google or androidfilehost .
Warning if you do not follow exact steps you may brick your phone you are responsible for any mistake you do.. GCPro_Team tested this steps and found no issue no knox void.. You are the one who responsible for any mistake you did we are not. so do it carefully.
The Following 5 Users Say Thank You to stanner_austin For This Useful Post:
Old 02-09-2018, 12:04   #5 (permalink)
Member: 49752
Thanks Meter: 6,085
How to unlock Samsung application locked ?
Answer
Please Read steps from
http://forum.gsmhosting.com/vbb/f922...gcpro-2300486/
The Following 2 Users Say Thank You to stanner_austin For This Useful Post:
Old 02-13-2018, 10:03   #6 (permalink)
Member: 49752
Thanks Meter: 6,085
  • GCPro Troubleshooting.
  • Problem: Error 0x82 Security
    • Solution:
      • Uninstall complete GCPRO setup/update/installed files from your computer.
      • ReDownload & Install GCPRO latest setup from Support Area
      • Add C:\GCPro_Team\ folder into TRUSTZone/Exclude on your AntiVirus
      • These above steps should solve your problem. but somehow if still getting same error then you have to clean your pc from any malware & virus by any AntiMalware & AntiVirus.
      • This error only comes only when your windows is VIRUS INFECTED AND CORRUPTED GCPro ADB_SERVICE\adb.exe.
      • Make sure do not make any change on ADB_SERVICE folder,This error have nothing to do with CARD ACTIVATION, CARD UPDATE,CARD LOCK ETC.
      • if still issue please check your PC for virus.. scan with better antivirus etc.
Old 02-26-2018, 17:54   #7 (permalink)
Member: 49752
Thanks Meter: 6,085
How to use RLOCK ADB = REACTIVATION REMOVE ON QCOM samsung device..
Answer
You must have STOCK 5.1 or newer .
You must have ADB & ROOT. TEMP root also ok. use google or search in forum to get more idea how to do it. if you can't sorry no other option we have.
We have uploaded most of ENG ROOT at support and they are latest firmware so flash your device with need firmware first.
Scan port & select samsung modem port before start.
Go to samsung tab select RLOCK ADB.
Select any model GCPro do not care models at most case.
Press start follow steps.
In case any error please format and re do.. if still say post log by making new thread do not forget to post all log in text format no images or files please.
Most engineering root is already at support..
The Following 3 Users Say Thank You to stanner_austin For This Useful Post:
Old 02-26-2018, 17:56   #8 (permalink)
Member: 49752
Thanks Meter: 6,085
How to REMOVE REACTIVATION ON EXYNOS samsung device with root.
Answer
If you already have flashed ENG ROOT Please use FRP REMOVE (ADB) this will clear FRP & REACTIVATION & screen lock,pattern,password etc same time..
Old 03-06-2018, 16:09   #9 (permalink)
Member: 49752
Thanks Meter: 6,085
How to FRP,REACTIVATION LOCKS ON EXYNOS samsung device VIA FRP_UFS OLD device with UART C3303K ?
Answer
Please connect any FTDI box plug C3303K cable & make sure you know port number. do not need COM,VCP etc. only number REMEMBER IT.
Please connect phone in download mode. plug usb scan port select samsung modem port.
Select FRP_UFS press start.
Wait till reading finish.. software will restart phone to normal mode. do not press OK on it.
Power off your phone fully.in GCPro software enter box port only number press OK
Software will start searching your phone.. now connect POWERED OFF phone by pressing VOLUME DOWN Always AND POWER KEY only for first 2 sec. if software detect it release key pressing.
If some reason not detected follow process again power off device fully, press VOLUME DOWN AND POWER KEY 2 sec only.
Once detected it will remove FRP,REACTIVATION,EELOCK same time.
Old 03-06-2018, 16:12   #10 (permalink)
Member: 49752
Thanks Meter: 6,085
HOW TO READ CERT WITH EXYNOS UNLOCK AND DIAG PORT?
Answer
Start phone fully make sure stock firmware is in phone. in some case you may need combination MODEM only not full flash.
Dial *#0808# select LAST OPTION..(some case you may need to reboot)
Scan port and select SAMSUNG USB TO SERIAL port in GCPro software.
Go to samsung tab select Exynos unlock. Press start wait till finish..
If you face any issue Please report by making thread and attach full log.
Old 03-29-2018, 13:53   #11 (permalink)
Member: 49752
Thanks Meter: 6,085
GCPro Credits Details.
!!! GCPro Credits Consumption . !!!
Best Regards,
GCPro_Team
The Following 10 Users Say Thank You to stanner_austin For This Useful Post:
Old 03-22-2019, 18:08   #12 (permalink)
Member: 49752
Thanks Meter: 6,085
Question
I have received GCPro.What next ?
Answer.(Box or dongle same steps)
  1. Please download latest update from GCPro key updates history - Page 5 - GSM-Forum
  2. Once you download latest setup. install it.
  3. Now you see on desktop shortcut GCPro UPDATE Tool. open this.
  4. Select UPDATE GCPro.(You can select english,chinese,russian,spanish more will be added)
  5. Press Start.Wait till finish. (If its say not allowed please ignore it.)
  6. Once finish select Register GCPro.
  7. If its say not allowed on Register GCPro. please contact Reseller only he can help.
  8. If you buy directly from www.gcprokey.com you can contact GPG sales team they will help.
Old 04-15-2019, 13:55   #13 (permalink)
Member: 49752
Thanks Meter: 6,085
Question
How to unlock Samsung sprint most model with GCPro?
  1. Make sure you are using Latest update.
  2. Select model any (samsung usb serial port J327P U3 temp unlock or N900P Only.. ##3424# to enable diag. You can read SPC without select diag and once you have SPC enable diag and continue for Unlocking.)
  3. Method 1 If phone firmware is combination or combination modem is used in samsung tab, select Sprint Unlock & press Start
  4. Method 2 if phone is stock firmware & newer then last 3 digit PDx[x=0 to anything ] You must root phone. in samsung tab, select sprint unlock & press start.
  5. For S9/S9+ if firmware is U3= REV 3 or newer flash combination modem from support area before continue. Note NO NEED TO SELECT ANY PORT JUST NEED TO ENABLE IT NOT SELECT.
  6. For sprint spc/msl read only, you can use UART method SPC/AKEY or use sprint unlock without root.
Note:S9/S9+ SPRINT is via credits only supported at moment. http://forum.gsmhosting.com/vbb/f922...018-a-2371739/
Note2:J337,J727P U3,J737P,NOTE9,S10 SPRINT is not supported.
Page generated in 0.33382 seconds with 8 queries
