Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 12-06-2014, 13:52   #1 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,414
GcProKey0015 World's 1st Usb Debug Enable for All Samsung.Plan format IMEICERT & More
Gsm & Cdma Professional Key Team
Happy To Announce
GCProKey Update 0015
  • World's 1st & Unique Solution & Only Introduced by GcProKey
    • Added Samsung ENABLE USB Debug option for MOST Samsung Phones.
      • How to Enable Usb Debug Option While Phone is Locked ?
        1. Power On Phone
        2. Connect Phone with Pc by Normal Usb Cable
        3. Install Samsung Drivers if Needed
        4. Open GcProKey GSMTool Version 1.0.0.0011
        5. Click on Scan Ports
        6. Select Modem Port ( of your connected Samsung Phone )
        7. Click on "Enable ADB"
        8. !!! Success !!!!.. As you see Success Written. It's SuccessFully Now Enabled Usb Debug
      • What is Enable ADB is for ?
        • If you want to Remove Pattern Lock without getting Lost Data. just Connect phone and Enable Usb Debug and bypass Pattern Lock
        • If you want to Remove User Code without getting Lost Data. just Connect phone and Enable Usb Debug and bypass User Code
        • If you want to Remove Screen Lock without getting Lost Data. just Connect phone and Enable Usb Debug and bypass Screen Lock
        • Many other things can be done... Many Locks can be Bypass by this way. OR if you want to do some thing with phone with ADB commands on LOCKED phones.... This is What Solution we MADE for you.
    • Added Samsung plan format imeicert handling
    • Gcpro is only tool can write all samsung certificate
  • Added handle samsung msl code if present in certificate file.
    • no need reset efs for imei,unlock etc
    • no need write qcn if not erased efs.
  • Added factory unlock possible if msl code present in certificate file.
  • Improved adb related task.
  • Improved MTK imei repair via baseband method which fail before.
  • Improved HTC read imei,write imei task..should fix DESIRE 600 imei reading issue.
  • Improved samsung imei write method.
  • Note:
    • ENABLE ADB option is used by most samsung. i can not test all phones made by samsung.
      But it should work on MOST of them. incase if your phone not worked with it,
      There is no other option to enable adb if this solution fail.
  • Note2:
    • Imeicert in plan text format like all other tools use.you can use any other tool imei certs now for write with GCPROKEY.
      All model should work 100%.
      Tested on N910C,N910T,G800H,G900F,I8552,SM-G850Y etc.
  • Note3:
    • Read Read Read HELPFILES in HelpFile folder for all details info.
  • Sample 1
    • Using Version...1.0.0.0011
      Selected Port VCP0 = COM11
      Selected Model Samsung GSM
      Selected Task SAM IMEI1
      SAMSUNG IMEI REPAIR & CERT WRITE STARTED...
      Searching Phone Please wait...
      Phone Found Wait...
      TEST MODE OK..
      Model := GT-I8552
      UNIQID := CKxxxx
      Phone IMEI := 35xxx
      MSL CODE FOUND USING IT..
      MSL Autho Pass..
      Update IMEI Ok..
      Update IMEI2 Ok..
      SKEY := 0246
      QCOM(QUALCOMM) detected..
      Checking imeicert...
      IMEISIGN PASS..
      Checking imeicert2...
      IMEISIGN2 PASS..
      Update Simlock Ok..
      Wifi_mac := 34xxx
      Wifi_mac update ok.
      Update SerialNumber ok..
      Fixing FTM ok..
      Repairing finish.
      All Finish..
      !!! SUCCESS !!!!
      Total Time Take...00:00:56
      Log Saved
  • Sample 2 Enabling Usb Debug
      Selected Port ssudmdm0000 = COM39
      Selected Task SAMSUNG ENABLE ADB
      SAMSUNG ENABLE ADB STARTED...
      Searching Phone...
      Phone Found Please Wait...
      Sending Loader...
      BASE(SM-N900)
      VER(I9300XWUGML4/I9300ODDGML4/I9300DDUGNB1/I9300XWUGML4)
      HIDVER(I9300XWUGML4/I9300ODDGML4/I9300DDUGNB1/I9300XWUGML4)
      MNC(24)
      MCC(404)
      PRD(GT-I9300RWDINS)
      SN(RZ1C9192V9R)
      IMEI(353743050349073)
      UN(CVTF1DA877BCF6F)
      PN()
      CON(AT,MTP)
      LOCK(NONE)
      LIMIT(FALSE)
      SDP(RUNTIME)
      HVID(Data:196609,Cache:262145,System:327681)
      USER(OWNER)##
      Loader Ready..
      ADB IS NOW ENABLE ENJOY...
      !!! Success !!!!
      All job finish..
      Restart Phone Manually before doing anything...
  • Sample 3
      Selected Port VCP0 = COM4
      Phone Found Wait...
      TEST MODE OK..
      Model := SM-G850Y
      UNIQID := CRxxxxx
      Phone IMEI := 35xxxxxx
      MSL Autho Pass..
      Update IMEI Ok..
      SKEY := 0932
      EXYNOS Type Detected..
      Cert write ok..
      IMEICERT PASS..
      Update Simlock Ok..
      Wifi_mac := F4xxxxx
      Wifi_mac update ok.
      Fixing FTM ok..
      Repairing finish.
      All Finish..
      !!! SUCCESS !!!!
      Total Time Take...00:01:50
DOWNLOAD LINK..
All Updates & History :
GCPro key updates history
Successful Stories
http://forum.gsmhosting.com/vbb/f922...o-key-1818329/
Follow Us on Twitter for always Update to Date:
https://twitter.com/GPGWorld
Follow us on Facebook
https://www.facebook.com/GPGINDUSTRIESWORLD
The Following 15 Users Say Thank You to Faisal_Computer For This Useful Post:
Old 12-06-2014, 16:11   #2 (permalink)
fabicel's Avatar
Member: 808967
Thanks Meter: 143
these keys supports samsung s5 n900m n900f n900t n900a to repair imei or writing cert where under the cert to repair imei thanks
The Following User Says Thank You to fabicel For This Useful Post:
Old 12-06-2014, 21:00   #3 (permalink)
Member: 1971921
Thanks Meter: 24
Here Gcpro SUpport
Originally Posted by julipsike View Post
you can write all samsung .cert files with ufst
Hi man dont need say here any other tool ,here Gcpro support We are olso know that but always Gcpro doing best and good solutations thank you
Regard:China_Phones
Old 12-06-2014, 21:01   #4 (permalink)
Member: 1971921
Thanks Meter: 24
Originally Posted by carlos32 View Post
and about unlock fones???
cheers
Which phone you want to unlock bro?
Old 12-06-2014, 21:02   #5 (permalink)
Member: 1971921
Thanks Meter: 24
Yes imei repair support,with imei cert
The Following User Says Thank You to China_Phones For This Useful Post:
Old 12-06-2014, 21:05   #6 (permalink)
Member: 1971921
Thanks Meter: 24
Direct imei repair in new samsungs not possibel possibel only 3-4 models ,in new phones like G900F A T and etc have imei cert you can check in the phone *#0011# if have imei cert so you can repair only with write cert,,,
Old 12-06-2014, 22:30   #7 (permalink)
Member: 1971921
Thanks Meter: 24
Originally Posted by octopus82 View Post
it's like gpg elmmc and magma, first fake in the world of phone's
Hello Gpg EMMC and Magma it is diffirent projects and diffirent teams!!! What i s
fake here can you explane ? Usb Debug Enable for All Samsung it is fake? Do you have Gcpro? Do you test it? If not have if not test dont need here bla bla Gcpro Key dont working like other fake first... Only Working solutation,,,,, If you mean here Faisal_Computer with magma and Gpg EMMC Faisal_Computer is Product Manager ...... EMMC MAGMA AND GCPRO OTHER TEAmS AND other coders .....
ThanKs!
Old 12-06-2014, 22:43   #8 (permalink)
mfeliu07's Avatar
Member: 517318
Thanks Meter: 79
ThanKs!
You are GcProKey stand?
As you respond in every post?
Old 12-06-2014, 23:02   #9 (permalink)
Member: 1971921
Thanks Meter: 24
I am only user not stand
What you need about Gcpro? Can Answer you
Here if not stanner so i can answer here says fake etc dont need without test any respons i think that
If bug if not support so please report can be fixed always thanks..
Old 12-07-2014, 08:44   #10 (permalink)
mediaextensions's Avatar
Member: 1123079
Sonork: 100.1586814
Thanks Meter: 424
GCPro Key team are real and doing great job and needs to be encouraged to do more. Great work done once again.
Always read the contents and dont just bla bla bla after reading heading and then jump to judgement , most guys are found of doing this always, it's not proper.
Regards,
Mediaextensins.
The Following User Says Thank You to mediaextensions For This Useful Post:
Old 12-07-2014, 17:36   #11 (permalink)
Member: 1159099
Thanks Meter: 6,353
you first need get CERT FILE and after can with this dongle
regards/,
The Following User Says Thank You to xcachorrox For This Useful Post:
Old 12-07-2014, 19:42   #12 (permalink)
Member: 2140825
Thanks Meter: 5
read in few other post about gcpro key write cert with no root needed just like factory solution
so if i wipe using hiemdall (no root needed) will i be able to write to quallcomm phones that require cert with out the root such as n910a which has locked bootloader and currently cant find root
very interested in this tool
and also do the imei repair on 4.4.2 go to the newest baseband/modem for the older phones such as i337 i317 etc.. really looking to narrow down to one tool instead of the many i have now
Old 12-08-2014, 05:35   #13 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,067
@smsprepaids
100%
supported and tested N910C,N910T,so N910A is no difference.
our tool also support msl in cert if msl code in cert. you do not need root or erase efs or qcn write.
for sure no root need all this via uart cable it have nothing to do with adb or root.
Regards,
Chevli
GCPROKEY
Old 12-08-2014, 05:40   #14 (permalink)
Member: 2140825
Thanks Meter: 5
Thank you mr stanner austin, couple other question if i choose to root and write thru usb does tool support it? Or strictly uart no exception, or is there a work around to do same no root not reset efs thru usb.. And i must admit you have really outdone your self with that update to this tool.. Also what about imei repir on models no cert method needed is usb or uart and does it support 4.4.2 newest modems. Will be ordering this week just want to know all about products
Old 12-08-2014, 07:03   #15 (permalink)
Member: 49752
Thanks Meter: 6,067
@smsprepaids
About usb you can try readinfo over modem port.if readinfo come with all info same as uart. for sure imeicert,imeirepair will work over modem port too..
i just have tested 1 cpu BCM model S7582 everything work over modem port no need to mess with uart or change settings etc..
but this can be only for this cpu no idea if QC new model will do so like N910C,G900F etc.only users of gcprokey can report such thing if he decided to post.
sample log is here..
Selected Port ssudmdm0000 = COM97
Details. GT-S7582,MP 0.101,S7582DDUAND1,S7582DDUAND1,S7582DDUANC
Model := GT-S7582
UNIQID := CK5034C48E4B371
Phone IMEI := 35500806184306
MSL Address:= RZ1F72VRED
SKEY := 0957
all device without imeicert is same for us.exactly same like factory tool no need root.
if msl known no need reset efs or qcn write.
for reset efs we have via adb due to must make backup before damage or erase original security units.. we can add in boot mode erase its too easy for sure..
but 90% user will use it on imeicert device and kill there certificates without backup.
Regards,
Chevli
GCPROKEY
The Following User Says Thank You to stanner_austin For This Useful Post:
Page generated in 0.46299 seconds with 7 queries
