08-18-2018, 04:19 | #2 (permalink) |
Insane Poster Join Date: Jul 2009
Member: 1072857 Status: Offline Thanks Meter: 4 | Operation LOG 1.98263.1.102573.2 Device Detected... SELinux := Permissive model:= N9560 Androids Version:= 7.1.1 Description Version:= ZTE_BOLTON-user 7.1.1 NMF26F 20170312.213714 release-keys Platform:= msm8937 [ qcom ] [ ] Warning Baseband is Unknown or damaged.... Security Patch := 01-03-2017 BusyBox version := 1.18.4 ANDROID-ID = ?_00000C6FCD Device is Unsecure Rooted System Permission is Read/Write... Starting All QCOM IMEI Repair... IMEI-1 := 000039485642710 Repaired IMEI-1 := 990008827385936 Repaired IMEI-2 := !!! SUCCESS !!! Total Time Take...00:01:43 Log Saved |
The Following User Says Thank You to yako66 For This Useful Post: |
08-28-2018, 05:01 | #5 (permalink) |
Member: 1072857 Status: Offline Thanks Meter: 4 | @Bscaine Hi Sr: I couldnt restore the imei even thoug the operation with gcpro was succesfull but still same wrong imei. I appretiate any help. Best regards |
09-03-2018, 09:46 | #9 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello all ZTE Z series if imei is not zero GCPro can not repair it. user who posted log used OPPO method which is show invalid success on ZTE due to that method only apply on OPPO Phones only. |
10-18-2018, 14:39 | #11 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2449666 Status: Offline Thanks Meter: 1 | //model:= N9560 //Androids Version:= 7.1.1 //Description Version:= ZTE_BOLTON-user 7.1.1 NMF26F 20170912.000520 release-keys //Platform:= msm8937 [ qcom ] [ ] //Warning Baseband is Unknown or damaged.... //Security Patch := 01-09-2017 //BusyBox version := 1.18.4 //ANDROID-ID = ?_00007DE03F //Device is Unsecure Rooted //RW,Remount Success.... //System Permission is Read/Write... //Starting All QCOM IMEI Repair... //IMEI-1 := 000039485642710 //IMEI-1 Read-Only Fail to Write..... //!!! FAIL !!! |
10-20-2018, 09:30 | #12 (permalink) | |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @leobel Hello New qcom zte don't have zero imei.. by default qcom only allow rewrite if imei zero. so even if you reset/erase/anything you will have default imei so rewrite is not allowed over standard qcom methods.. We do not offer any special ZTE method at present. Quote:
The Following User Says Thank You to stanner_austin For This Useful Post: |
10-25-2018, 17:01 | #13 (permalink) |
Insane Poster Join Date: Oct 2017 Location: México Age: 46
Member: 2763934 Status: Offline Thanks Meter: 17 | not imei problem, secutiry problem. try writting modem only from firmware. not sure if GC supports... other tool does. i had this problem with one after security repair, flashing modem from firmware fixed the problem. hope this helps.. not sure if can mention other tools in post... so i wont.... |
10-25-2018, 17:03 | #14 (permalink) |
Member: 2763934 Status: Offline Thanks Meter: 17 | BTW here is firmware: ZTE N9560 Boost Mobile Rom Firmware 0B08 - Desbloqueo Kings i also have security backup if you need, but pretty sure writting other security from other phone only results in bad IMEI, as stanner said... |
The Following 2 Users Say Thank You to DesbloqueoKings For This Useful Post: |
04-24-2019, 10:24 | #15 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
this mean imei is not only stored modemst parts..? (modemst1-2 and fsg and fsc) stored to another part..? we need to erase another part like the others..? f.ex; ztecfg or ztelk or config..? | |
The Following User Says Thank You to LoveLess For This Useful Post: |
