Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 12-07-2017, 10:22   #1 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,582
How to Direct Unlock Samsung APP Locked With GCPro.
Before start please verify with *#0011# IMEICERT PASS, MIPI PASS NO ERROR ELSE YOU HAVE NETWORK ISSUE.
Galaxy J7 Star Application Locked (SM-J737T) Direct Unlock
1. Download ENG BOOT from Support Area:
-J737T_UVU1ARF3_ENGBOOT_FOR_UNLOCK - for phones with rev1
1. Flash ENG ROOT depending on your phone firmware and it's revision.
2. Tick on Use server on top and go to samsung tab select ASK/RPL option press yes ask read.
Galaxy J3 Star Application Locked (SM-J337T) Direct Unlock
-J337T_UVU1ARE1_ENGBOOT_FOR_UNLOCK.7z - for phones with rev1
Note 8 Application Locked (SM-N950U/SM-N950U1) Direct Unlock
1. Download ENG ROOT from Support Area:
- N950U_SQU1AQH8_ENG_SPRINT_UNLOCK.7z - for phones with rev1
- N950U_SQU2AQK2_ENG_SPRINT_UNLOCK.7z - for phones with rev2
2. Reboot to Recovery mode with VOL UP + POWER + HOME and WIPE phone (this is mandatory, not optional)
3. Reboot to bootloader from RECOVERY MODE
4. Flash ENG ROOT depending on your phone firmware and it's revision.
5. Tick on Use server on top and go to samsung tab select ASK/RPL option press yes ask read.
S8plus Application Locked (SM-G955U, SM-G955U1) REV 1 Direct Unlock
- G955U_SQU1AQD8_ENG_SPRINT_UNLOCK.7z - for phones with rev1
2. Put phone into Download Mode with VOL DOWN + HOME + POWER.
3. Flash ENG ROOT depending on your phone firmware and it's revision.
4. Tick on Use server on top and go to samsung tab select ASK/RPL option press yes ask read.
S8plus Application Locked (SM-G955U, SM-G955U1) REV 2 Direct Unlock
- G955U_SQU2AQK2_ENG_SPRINT_UNLOCK.7z - for phones with rev 2
4. Tick on Use server on top and go to samsung tab select ASK/RPL or Tmobile unlock option press yes when ask for read ask.
S8 Application Locked (SM-G950U, SM-G950U1) REV 1 Direct Unlock
- G950U_SQU1AQD8_ENG_SPRINT_UNLOCK.7z - for phones with rev1
S8 Application Locked (SM-G950U, SM-G950U1) REV 2 Direct Unlock
- G950U_SQU2AQK2_SPRINT_UNLOCK.7z - for phones with rev 2
S7edge Application Locked (SM-G935T, SM-G935T1) Direct Unlock
- G935T_UVE2APD7_ENGROOT.7z - for phones with Android 6.X
- G935T_UVE4BQH7_ENGROOT.7z - for phones with Android 7.X
S7 Application Locked (SM-G930T, SM-G930T1) Direct Unlock
- G930T_UVE2APD7_ENGROOT_6X.7z - for phones with Android 6.X
- G930T_UVE4BQB1_ENGROOT_7X.7z - for phones with Android 7.X
J3 Prime Application Locked (SM-J327T, SM-J327T1) Direct Unlock
1. Dial *#0808# make sure selected MTP/ADB.. do not root or flash any files on this phone.
2. Tick on use server on top, go to samsung tab Select T-Mobile unlock Press start.
J7 Prime Application Locked (SM-J727T, SM-J727T1) Direct Unlock
1. Dial *#0808# select last option. scan port and select samsung usb to serial port.
2. Go to samsung tab select Exynos unlock Wait till finish.
3. Dial *#0808# select MTP/ADB
4. Tick on use server on top, Select T-Mobile unlock Press start.
Some case you may need to downgrade modem.
If you have credits please tick on USE SERVER on top to do via credits instant direct unlock else it will save ASK you can process ASK 2 RPL with any reseller and get unlock with ASK/RPL option press NO when start process of ASK RPL.
The Following 5 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 12-07-2017, 17:31   #2 (permalink)
Member: 2188956
Thanks Meter: 28
how do i know if my note 8 is on rev1 or rev2? where do i check that? thanks
Old 12-07-2017, 19:54   #3 (permalink)
Member: 2107306
Thanks Meter: 607
N950USQU1AQI5 rev 1
N950USQU2BQJA rev 2
The Following 4 Users Say Thank You to Prsctt For This Useful Post:
Old 12-07-2017, 20:21   #4 (permalink)
Member: 2188956
Thanks Meter: 28
k so QU1 = Rev 1, QU2 = Rev 2
thanks
Old 12-07-2017, 20:36   #5 (permalink)
kanokh's Avatar
Member: 1736804
Sonork: 100.1644836
Thanks Meter: 431
N950USQU1AQI5 rev 1
N950USQU2BQJA rev 2
The Following User Says Thank You to kanokh For This Useful Post:
Old 12-27-2017, 05:34   #6 (permalink)
Member: 1326364
Sonork: 100.1646584
Thanks Meter: 2
Using Version...1.0.0.0052
Selected Model GT-I5503
Selected Task SAMSUNG ASK/RPL UNLOCK
Searching ADB device Please wait..
Device Detected...
SELinux := Permissive
model:= SM-J327T1
SAMSUNG ASK/RPL STARTED...
type1 root exploit possible.
Device is not rooted
Please Wait while...
Please wait starting task...
Send ASK Saved := 42000d8cce2564e7.ask
!!! Success !!!!
Restart Phone Manually if not done auto...
Total Time Take...00:00:04
Log Saved
Old 01-04-2018, 16:25   #7 (permalink)
Member: 2565568
Thanks Meter: 8
Selected Model SM-G530T
Device Detected...
SELinux := Enforcing
model:= SM-G530T
SU Version..2.79:SUPERSU
Device is Secure Rooted..uid=0
Reading ASK Please Wait..
Credits Left:= 40
Loader Ok Starting task...
!!! Success !!!!
Total Time Take...00:00:10
Log Saved
good job team
The Following 2 Users Say Thank You to snydertecnology For This Useful Post:
Page generated in 0.27777 seconds with 7 queries
