01-05-2017, 04:26 | #1 (permalink) |
Junior Member Join Date: Dec 2016 Location: Milwaukee
Member: 2658302 Status: Offline Thanks Meter: 0 | How to fix dm-verity verification failed? Galaxy S7 G930t pg1 Using Version...1.0.0.0040 Selected Model GT-I5510 Selected Task SAMSUNG DRK Repair ADB Searching ADB device Please wait.. Device Detected... Security:= OFF Unsecure device model:= SM-G930T Androids Version:= 6.0.1 Description Version:= heroqltetmo-user 6.0.1 MMB29M G930TUVU4APK1 release-keys Platform:= msm8996 [ qcom ] [ msm ] Baseband:= G930TUVU4APK1 VER:= G930TUVU4APK1/G930TUVU4APK1/G930TUVU4APK1 Unknown CSC EFS CSC := TMB AP UART Status := Disable. Network Mode := LTE Simstatus:= ABSENT ANDROID-ID = 27a1a36a_0000C75D9D Device is Unsecure Rooted SAMSUNG DRK Repair started... Checking Data... Waiting for Loader... Loader Ok... DRK Is Already Valid,Do Not Need DRK Repair... !!! Fail !!!! Restarted phone... Total Time Take...00:00:15 Any assistance would greatly be appreciated. Thank you. |
01-05-2017, 10:02 | #2 (permalink) |
Insane Poster Join Date: Nov 2015
Member: 2484103 Status: Offline Thanks Meter: 3 | i got the same message with one s7 edge while rooting ,i flashed the original rom again and everything worked. try flashing this file / https://www.androidfilehost.com/?fid=457095661767112353 with odin,i hope it works |
01-07-2017, 05:46 | #3 (permalink) |
Member: 2658302 Status: Offline Thanks Meter: 0 | Hello! I appreciate your reply. I did not expect any response. Yes flashing the 4 file rom was the first step I took to remedy the error but unfortunately it does not work. |
01-07-2017, 07:29 | #4 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
try flash combination than try uart repair and post log Uart here | |
01-07-2017, 17:39 | #5 (permalink) | |
Freak Poster Join Date: Mar 2016 Location: HUAWEI
Member: 2548753 Status: Offline Thanks Meter: 256 | Quote:
Flash Twrp here and Select Wipe , and then select Factory Reset to fomat data and download Disable_dm-verity and make it in your SD card Reboot into Recovery mode again and flash Disable_dm-verity from sdcard and reboot Working 100000% Only Thanks Bouton | |
The Following User Says Thank You to Medofficiel For This Useful Post: |
01-07-2017, 22:48 | #6 (permalink) | |
No Life Poster Join Date: Oct 2013
Member: 2051392 Status: Offline Thanks Meter: 161 | Quote:
The Following User Says Thank You to banziitox24 For This Useful Post: |
01-25-2017, 07:27 | #8 (permalink) | |
Member: 2658302 Status: Offline Thanks Meter: 0 | Update for dm-verity issue Quote:
I apologize for the late reply sir. I will keep this forum updated until we find the solution. Here is the log info you requested. First log is UART DRK repair with combination file. Second log is combination+root and adb drk repair. It says "ROOTKEY FAIL" or "ROOT KEY NOT GOOD." Using Version...1.0.0.0041 Selected Port VCP0 = COM90 Selected Model SM-G930T Selected Task SAMSUNG DRK FIX Started Samsung DRK Fix... Phone Found Wait... TEST MODE OK.. Details. SM-G930V,REV0.6,FA60_G930TUVU4API4,FA60_G930TUVU4API4 ,G Model := SM-G930V UNIQID := CE021602B908182 Phone IMEI := 35591607XXXXXX Phone MEID := 35591607XXXXXX MSL Address:= R58H33T13W ROOTKEY FAIL..fYxLDoAgEEOvxAhOdclHrvHufwsEVm5MmpemaRszsaGC OnH5TVV0I0OOdyT0YJVAnm1Pc/DKD9zRiRJWPhdh9xfa32jmRroG !!! Fail !!!! Total Time Take...00:00:20 Log Saved Using Version...1.0.0.0041 Selected Model GT-I5500 Selected Task SAMSUNG DRK Repair ADB Searching ADB device Please wait.. Device Detected... Security:= OFF Unsecure device model:= SM-G930V Androids Version:= 6.0.1 Description Version:= heroqltevzw-user 6.0.1 MMB29M FA60_G930TUVU4API4 release-keys Platform:= msm8996 [ qcom ] [ msm ] Baseband:= G930TUVU4API4 VER:= FA60_G930TUVU4API4/G930TUVU4API4/FA60_G930TUVU4API4 Unknown CSC EFS CSC := TMB AP UART Status := Enable Already. Simstatus:= ABSENT ANDROID-ID = 27a1a36a_0000EE84C4 Device is Unsecure Rooted SAMSUNG DRK Repair started... Checking Data... Waiting for Loader... Loader Ok... DRK Is Already Valid,Do Not Need DRK Repair... !!! Fail !!!! Restarted phone... Total Time Take...00:00:16 Log Saved | |
01-27-2017, 10:35 | #10 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @kishore1 Hello Select any model from list. Scan port & select modem port in ist. Go to samsung tab select exynos unlock press start. If its say unsupported check for yourmodel_cp_for_unlock flash it and re do exynos unlock & reflash stock. If your model cp for unlock is not exist then use adb unlock method.need root. ADB_UNLCK Steps. scan port select modem port. go to samsung tab select adb unlock press start. if you have any issue on adb unlock please let me know via skype. due to SS335 was on beta stage while we released you can contact me on skype for latest beta if you plan to root and unlock if no other option is available. |
The Following User Says Thank You to stanner_austin For This Useful Post: |
