Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 10-27-2017, 08:36   #1 (permalink)
maliro2012's Avatar
Member: 1859060
Sonork: 100.1651029
Thanks Meter: 170
How to repair imei 350000000 G920T latest security level binary 5 ?
Repair imei and security damaged s6 g920t T-Mobile latest binary level 5
I need help and guide please. I'm new here
Old 10-27-2017, 10:52   #2 (permalink)
Member: 2130017
Thanks Meter: 43
-first method flash combination file rev 5 then imei repair after finish flash back to stock rom done.
-second method root phone, bypass knoox , write cert done.
The Following User Says Thank You to izzicruise For This Useful Post:
Old 10-29-2017, 18:24   #3 (permalink)
Member: 2529775
Thanks Meter: 68
UART or another method
Old 10-29-2017, 19:03   #4 (permalink)
Member: 2529775
Thanks Meter: 68
flashed combination
wipe efs
write a good nv data file
write the cert
fix drk
all good
Old 10-29-2017, 19:21   #5 (permalink)
..::SH@RIF®™::..'s Avatar
Member: 929782
Sonork: 100.1641069
Thanks Meter: 617
Originally Posted by kbdaking1 View Post
flashed combination
wipe efs
write the cert
fix drk
all good
This method Root need or not?
Old 11-02-2017, 11:53   #6 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
@..::SH@RIF®™::..
Hello
if you are GCPro user go to helpfiles
Read how to use exynos imei repair. its show you both way with and without root imeicert write methods with GCPro.
Old 11-02-2017, 12:09   #7 (permalink)
jhames47's Avatar
Member: 895644
Sonork: 098765
Thanks Meter: 161
How about no nv backup?
Old 11-02-2017, 12:14   #8 (permalink)
Member: 49752
Thanks Meter: 6,085
@jhames47
Hello
GCPro do not need NV backup. Please use steps in helpfile carefully..
If your device is warranty void you may need to use combination or ROOT to bypass knox.. not both only 1 of them.
Old 11-06-2017, 21:59   #9 (permalink)
Member: 2529775
Thanks Meter: 68
yes it does need root to work
Page generated in 0.59199 seconds with 8 queries
