How to update to latest version? Hello every one. Please go to support download latest GCPROKEYupdate62 or newer. Make sure GCPro dongle is connected direct to PC on USB 2.0 no hub no 3.0. if you have GCPro box make sure cable is less then 1 meter . Make sure If you fail to understand steps or have issue with English reading i suggest you to contact your reseller and ask him help for your card update.. If you fail to update you may lost your GCPro.. Make sure you do not lost internet,power,pc off etc, we won't be responsible for you card brick.You are doing at your own risk. You must follow steps and do exactly what we said. If you have any issue in understanding steps please talk with your reseller & tell him to update for you. Each card only allowed once to update.. You can not use ANY OLD version after update. Go to C:\GCPro_Team\UPDATETOOL\ folder open GCPROUPDTOOLOK select Update GCPro press do job. https://s28.postimg.org/bluzeyr2l/howtoupd.jpg In case any error contact at skype. if you can't use skype use facebook gcprokey page to talk, if you can't use both post in activation thread with UPDATETOOL\LOGS\ all files. DO NOT LOST/DELETE ANY UPDATE LOG IT MAY HELP TO FIX YOUR ISSUE FAST. Server reply ... ERR_BADCMD or ERR_USE_LATEST_UPDATE This error means you are not using latest update. go to support link and download latest update. Card is not Allowed to UPDATE if your dongle is "NOT ACTIVE" Contact reseller tell him to add in server to allow activation. Only your reseller can allow this we can not. DO NOT TRY MORE THEN 1 TIME UNLESS GCPro_support said you to try. IT MAY LOCK OR YOU MAY LOST CARD.. Best Regards, GCPro_Team GCPROKEY |
