10-26-2015, 06:44 | #2 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 307625 Status: Offline Thanks Meter: 25 | Phone Found Wait... TEST MODE FAIL Make sure Phone is on UART PDA for newer OS.. No reply on samsung mode.. Enter *#7284# select UART > PDA Enter *#0808# select AP > MTP+ADB MUST USE UART C3303K !!!RJ45 CABLE!!! ON ALL NEW SAMSUNG DEVICES. DIAL *#0*# AND TRY AGAIN... Total Time Take...00:00:26 |
10-26-2015, 07:08 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello log you post is half. did you selected Box port? did you dial in phone *#0*# ?? did you used uart c3300k or c3303k cable ? what model you trying ? Last edited by stanner_austin; 10-26-2015 at 13:08. |
10-26-2015, 07:54 | #5 (permalink) |
Member: 307625 Status: Offline Thanks Meter: 25 | Using Version...1.0.0.0021 Selected Port ssudmdm0000 = COM231 Selected Model SM-G900V Selected Task SAM MEID SAMSUNG MEID REPAIR STARTED... Searching Phone Please wait... Phone Not Found Retry Please. Enter *#7284# select UART > PDA Enter *#0808# select AP > MTP+ADB MUST USE UART C3303K !!!RJ45 CABLE!!! ON ALL NEW SAMSUNG DEVICES. DIAL *#0*# AND TRY AGAIN... !!! Fail !!!! Total Time Take...00:00:08 |
10-26-2015, 09:48 | #7 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @joe zack Hello You are using "Selected Port ssudmdm0000 = COM231" which is wrong you have to use BOX port and plug cable in box and phone. Most phone need MEID CERT you can not repair direct just MEID without cert it will show imei cert fail.. Lucky you can use any SM-G900 imeicert as MEID CERT WRITE option and gcpro will fix meid,imei to one in cert file. You can use battery tape on BSI point. You can use *#0*# You can use via adb and root temporary ENABLE UART in gcpro. after restart its gone. There is many option all is already mention in updatexx\HelpFile\ Try to read meid cert write helpfile GCPRO do not care what interface you are using or what cable.. use any box with there cables. |
10-26-2015, 21:49 | #8 (permalink) | |
Freak Poster Join Date: Mar 2014 Location: United States
Member: 2146046 Status: Offline Thanks Meter: 62 | Quote:
Is your UART cable working on the Z3X box?? If you can it should work 100% with GCPROKEY. Make sure you have USB Serial Port showing up in Windows Device Manager. This is the port used for UART. Make sure when you use UART you select "USB SERIAL PORT" in GCPROKEY or Z3X Box and it should work... | |
The Following User Says Thank You to GTrader For This Useful Post: |
09-07-2016, 22:02 | #10 (permalink) |
Junior Member Join Date: Aug 2009 Location: texas
Member: 1103295 Status: Offline Thanks Meter: 3 | when i try to use the z3x box for uart , i get i am trying to use a z3x box for uart with my gcprokey dongle but when i try to do things it gives me this Using Version...1.0.0.0036 Selected Port VCP0 = COM43 Selected Model SM-G935A Port Already Open Its In Use... can anyone help me with this. why is it saying the port is already in use? |
The Following User Says Thank You to jtnorbert For This Useful Post: |
09-08-2016, 11:11 | #11 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @jtnorbert Hello if software show port is in use then its in use by other tool in background or bad driver. Please check your pc for driver and make sure all other tools are closed no background running . |
The Following User Says Thank You to stanner_austin For This Useful Post: |
09-10-2016, 15:53 | #12 (permalink) |
Member: 1103295 Status: Offline Thanks Meter: 3 | yes , i know that is what it means but i can't find any other software or device that is using that port. i even did a fresh install of windows 8.1 and only installed the driver for the box. it is the only port show but i get the same message. |
09-13-2016, 17:46 | #14 (permalink) |
Member: 1103295 Status: Offline Thanks Meter: 3 | did you end up figuring this out tornado? i am still have the invalid port issue. so i can not use uart. i feel like i wasted my money on this since i can't use uart. without being able to use uart it is no different than my z3x box. |
09-13-2016, 17:51 | #15 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @jtnorbert Hello How you think we can guess what your issue without any log or details ? You have error con port in use or any other ? use any image hosting web post screenshot of problem or contact me on skype i check via team. Using uart is basic thing on repairing samsung phones, you can use search there many user posted there logs. |
