12-18-2018, 23:20 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: Dominican Republic
Member: 2507961 Status: Offline Sonork: 100.1671607 Thanks Meter: 28 | moto e5 cruise |
12-19-2018, 09:20 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @maicolodalis Hello You can use motorola unlock option to unlock motorola phones. most people just cross flash or use trick to downgrade it and success to unlock it. We do not list such model as official support because tricks are not real solution. |
The Following User Says Thank You to stanner_austin For This Useful Post: |
01-10-2019, 19:02 | #4 (permalink) | |
Freak Poster Join Date: Aug 2007 Location: USA
Member: 575293 Status: Offline Thanks Meter: 40 | Quote:
When you say cross flash, are you saying that firmware flashing like Samsung is possible in these? So if I find unlocked e5 firmware it should work? | |
01-11-2019, 10:01 | #5 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @cellfonepimp Hello What i mean is for example xyz1 phone have released latest firmware which close exploit gcpro use for unlock & repair. and same cpu base xyz2 phone have older firmware people use modem of such phone to get unlock & repair then reflash stock. Second trick what i think is doing, is now days is flashing custom fsg which corrupt modemst configuration and baseband continue work by thinking its zero security result imei zero. if baseband is old gcpro will show success to write meid or imei (this will rebuild security) and reflash stock fsg to fix corruption. To be frank all latest motorola use latte baseband and its not supported in existing method. most of people use official dongle to rebuild security over factory method. which use PKI challenge(rsa base). |
