Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 04-26-2018, 10:55   #1 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
i9505 baseband unknow help
how to repair in gc prokey ?
i got dongle from supplier but dont know procedure
pls help me team
Old 04-26-2018, 11:16   #2 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
@umarmsn
Hello
To repair XX626(I9300,I9500,N7100) baseband make sure you reflash stock and verify its not due to patch imei.If after reflash also same.
Use Exynos efs reset in download mode. Now check baseband is back or not.
If not check phone in hardware.
If repaired use imeicert write via uart to repair certificate..
Old 04-26-2018, 11:27   #3 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
Originally Posted by stanner_austin View Post
@umarmsn
Hello
Using Version...1.0.0.0056
Selected Port SAMSUNG Mobile USB Modem #2 COM8
Selected Model GT-I9505
Selected Task SAMSUNG ExynosEFS RESET
Searching phone...
Init ok..
Fail-Flash..
Possible New BootLoader Try Downgrade and retry...
Finish...
!!! Fail !!!!
Restart Phone if not auto...
Total Time Take...00:00:16
Log Saved
Old 04-26-2018, 11:39   #4 (permalink)
Member: 49752
Thanks Meter: 6,085
@umarmsn
Hello
Your phone is not I9500 its I9505 QCOM not XX626 .
Use Modemstx reset or m9kefs reset and once baseband is repaired use IMEI Repair option to write original imei.
Page generated in 0.16652 seconds with 9 queries
