09-26-2017, 08:37 | #17 (permalink) |
Junior Member Join Date: Aug 2012
Member: 1798350 Status: Offline Thanks Meter: 1 | Need help to remove frp please i have a samsung sm-j327t1 it is metro pcs and has a the google frp lock on and i would love help removing this so i can use the phone again without the original google password information attached. Can you help with that? |
09-28-2017, 04:15 | #18 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2761063 Status: Offline Thanks Meter: 0 | Frp Flash the combo firmware, or get accessibility going, swipe left down or right down, accessibility settings, manage gesture do an open one for overview, i know its already ter but trust that will get you to chrome. rootjunkysdldotcom download sidebar, frp bypass, gam 7, shortcut and es. but get the sidebar last and update es with galaxy app force stop everything google an samsung, especially setup wizard. install gam 7, use frpbypass, 3 dots top right browser sign in, log in..set up sidebar now if you havent, power down wait 10 seconds an power up, use side to go to settings factory reset and that is that |
10-22-2017, 15:21 | #22 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | This FRP method should work for both Tmo and Metro. Flash full COMBI firmware. https://androidfilehost.com/?fid=961840155545576588 Flash these stock parts only: sboot.img, system.img https://androidfilehost.com/?fid=962021903579480962 Do an FRP unlock by selecting model Samsung-GSM, and also factory reset it from the settings menu. Finally, reflash it with full stock firmware. (the full second file above) |
The Following 6 Users Say Thank You to BillA For This Useful Post: |
11-01-2017, 19:30 | #24 (permalink) | |
No Life Poster Join Date: May 2014
Member: 2188956 Status: Offline Thanks Meter: 29 | Quote:
thanks it worked fantastic, i didn't even had to o the samsung gsm reset part, just flashed the Combination, then flash the Sboot and System like you said, took me to main screen right away and i was able to do the master reset from inside the phone. thanks | |
The Following 3 Users Say Thank You to truwrxtacy For This Useful Post: |
11-03-2017, 02:35 | #26 (permalink) | |
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
11-24-2017, 18:11 | #27 (permalink) |
Junior Member Join Date: Nov 2017
Member: 2782223 Status: Offline Thanks Meter: 0 | So does this get us closer to root...? So I followed the instructions here and turned my TMobile phone into a MetroPCS phone with no LTE, so I am attempting to re-flash the stock FW now. I am relatively new to Android but doing some development and would prefer root -- are these instructions supposed to get us there? |
02-24-2018, 00:20 | #28 (permalink) | |
Here's an easier way to do FRP unlock with one less step than before. Note: No need to first flash FULL combi, and also stock sboot.img and system.img The files below are for Rev-1 firmware, for higher versions you must find and flash a matching revision. This will not convert to MetroPCS, it will stay Tmobile. Step 1. Flash combi with Z3X, by de-selecting both sboot.img and system.img COMBINATION_TMB_FA70_J327TUVU1AQC3.rar https://androidfilehost.com/?fid=673791459329071035 Step 2. Do FRP unlock using model J327P, and turn on OEM-Unlock. Reflash with full stock firmware. J327TUVU1AQK6_J327TTMB1AQK6_TMB 7.0 Repair Firmware.rar https://androidfilehost.com/?fid=673956719939818405 Enjoy! | |
04-13-2018, 21:26 | #30 (permalink) |
Freak Poster Join Date: May 2015 Location: Los Angeles Age: 29
Member: 2400231 Status: Offline Thanks Meter: 124 | Reason it won't flash is because you have bootloader version 2. The combo file posted here is for bootloader version 1. You need to find combo file J327T1VU2ARC2 |
