Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 09-24-2017, 16:18   #16 (permalink)
Member: 2761063
Originally Posted by najeeb2020 View Post
I found the eng boot but could not flash it
An error appears on the phone after odin start flashing the file says( This is Eng binary please use user binary (boot))....
I promise i can flash and gain root for EVERYONE, why not post or tell where you found it. i have never seen an ENG say that during flash
Old 09-26-2017, 08:37   #17 (permalink)
Member: 1798350
Need help to remove frp please
Originally Posted by altnoc View Post
anyone need frp soluiton for j327t1 let me know
i have a samsung sm-j327t1
it is metro pcs and has a the google frp lock on and i would love help removing this so i can use the phone again without the original google password information attached. Can you help with that?
Old 09-28-2017, 04:15   #18 (permalink)
Member: 2761063
Frp
Flash the combo firmware, or get accessibility going, swipe left down or right down, accessibility settings, manage gesture do an open one for overview, i know its already ter but trust that will get you to chrome.
rootjunkysdldotcom
download sidebar, frp bypass, gam 7, shortcut and es.
but get the sidebar last and update es with galaxy app
force stop everything google an samsung, especially setup wizard. install gam 7, use frpbypass, 3 dots top right browser sign in, log in..set up sidebar now if you havent, power down wait 10 seconds an power up, use side to go to settings factory reset and that is that
Old 09-30-2017, 19:30   #19 (permalink)
Member: 785389
Thanks Meter: 6
i need frp solution for j327t1 please help
Old 10-15-2017, 00:21   #20 (permalink)
Member: 2767436
hello
plees root j327t1
Old 10-15-2017, 00:34   #21 (permalink)
Member: 2767436
hallo
can I have root j327t1
Old 10-22-2017, 15:21   #22 (permalink)
Member: 92260
Thanks Meter: 843
This FRP method should work for both Tmo and Metro.
Flash full COMBI firmware.
https://androidfilehost.com/?fid=961840155545576588
Flash these stock parts only: sboot.img, system.img
https://androidfilehost.com/?fid=962021903579480962
Do an FRP unlock by selecting model Samsung-GSM, and also factory reset it from the settings menu.
Finally, reflash it with full stock firmware.
(the full second file above)
The Following 6 Users Say Thank You to BillA For This Useful Post:
Old 10-25-2017, 16:51   #23 (permalink)
Member: 2059225
Thanks Meter: 3
Could u please make a step by step video or pictures. I´m trying to do it but seems that i did not understand it. Thanks in advance.
Old 11-01-2017, 19:30   #24 (permalink)
Member: 2188956
Thanks Meter: 29
thanks it worked fantastic, i didn't even had to o the samsung gsm reset part, just flashed the Combination, then flash the Sboot and System like you said, took me to main screen right away and i was able to do the master reset from inside the phone. thanks
The Following 3 Users Say Thank You to truwrxtacy For This Useful Post:
Old 11-02-2017, 17:08   #25 (permalink)
Member: 1606451
Thanks Meter: 53
dont really work
in my case it getonly stuck on the metro pcs logo
Old 11-03-2017, 02:35   #26 (permalink)
Member: 92260
Thanks Meter: 843
After flashing the full COMBI, don't let it power on (in Odin under Options uncheck the Auto-Reboot), put it in download mode again and flash the stock sboot and system ONLY, then power on. It works tested by a few people.
The Following 2 Users Say Thank You to BillA For This Useful Post:
Old 11-24-2017, 18:11   #27 (permalink)
Member: 2782223
So does this get us closer to root...?
So I followed the instructions here and turned my TMobile phone into a MetroPCS phone with no LTE, so I am attempting to re-flash the stock FW now.
I am relatively new to Android but doing some development and would prefer root -- are these instructions supposed to get us there?
Old 02-24-2018, 00:20   #28 (permalink)
Member: 92260
Thanks Meter: 843
Here's an easier way to do FRP unlock with one less step than before.
Note:
No need to first flash FULL combi, and also stock sboot.img and system.img
The files below are for Rev-1 firmware, for higher versions you must find and flash a matching revision.
This will not convert to MetroPCS, it will stay Tmobile.
Step 1.
Flash combi with Z3X, by de-selecting both sboot.img and system.img
COMBINATION_TMB_FA70_J327TUVU1AQC3.rar
https://androidfilehost.com/?fid=673791459329071035
Step 2.
Do FRP unlock using model J327P, and turn on OEM-Unlock.
Reflash with full stock firmware.
J327TUVU1AQK6_J327TTMB1AQK6_TMB 7.0 Repair Firmware.rar
https://androidfilehost.com/?fid=673956719939818405
Enjoy!
Old 04-13-2018, 21:06   #29 (permalink)
Member: 2288266
j327t1
I have one with J327T1UVS2ARC1, won't flash combo with regular odin, or comsy, or just flashing boot on octopus.
Can't seem to do anything with this thing.
Old 04-13-2018, 21:26   #30 (permalink)
CloseCOder's Avatar
Member: 2400231
Thanks Meter: 124
Reason it won't flash is because you have bootloader version 2. The combo file posted here is for bootloader version 1. You need to find combo file J327T1VU2ARC2
Page generated in 0.27757 seconds with 9 queries
