02-07-2018, 09:33 | #1 (permalink) |
Crazy Poster Join Date: Oct 2010
Member: 1417534 Status: Offline Thanks Meter: 4 | j700t imei disappear after writing gcpro modem from supoort (solved) |
02-07-2018, 09:39 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @Makanju Hello Reflash same version modem or full flash which you had before you flashed modem for unlock. Also J700T modem is only use for msl reset older firmwares not for unlock.. You can unlock such model with root and tmobile unlock option any baseband. Please search and check how to match REV code before flashing phone. |
02-07-2018, 09:41 | #3 (permalink) |
Member: 1417534 Status: Offline Thanks Meter: 4 | The phone has android 6.0.1 on it now and i am about upgrading it to latest android 7.1.1 hope that will not complecate the issue. No cert backup before flashing gcpro modem.bin |
02-07-2018, 09:44 | #4 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @Makanju Hello You just need to reflash same modem version you had before. no need to worry its not lost security is still in side phone. just because you changed modem to too old its rejecting to display. So check what version of your AP firmware and reflash stock modem you do not need to full flash or data lost. |
02-07-2018, 15:32 | #6 (permalink) |
Member: 1417534 Status: Offline Thanks Meter: 4 | Eventually it worked after flashing it with the same android version and the same bit and bootloader version. Thanks to stanner for the information. |
The Following User Says Thank You to Makanju For This Useful Post: |
