Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 08-14-2016, 08:30   #1 (permalink)
Member: 2554552
Thanks Meter: 21
J700t1 frp remove fail!! Please help!! Gc key pro.
Using Version...1.0.0.0035
Selected Port ssudmdm0000 = COM22
Selected Model SM-J700T1
Selected Task SAMSUNG FRP Remove
Searching phone...
Device Found..
MODEL=SM-J700T;UN=C000062888AB123;CAPA=16;VENDOR=TOSHIBA;FW VER=4;PRODUCT=400073;
Init ok..
Fail-flash..
Possible New BootLoader Try Downgrade and retry...
Finish...
!!! Fail !!!!
Restart Phone if not auto...
Total Time Take...00:00:13
Log Saved
Old 08-14-2016, 16:54   #2 (permalink)
Member: 2457641
Thanks Meter: 153
Searching phone...
Device Found..
Init ok..
Fail-flash..
Finish...
!!! Fail !!!!
Log Saved
flash eng boot then remove frp using adb
you can find the file here on the forum
Old 08-14-2016, 17:53   #3 (permalink)
Member: 2554552
Thanks Meter: 21
i did search i cant see the engsboot for it
Sent from my SM-N920T using Tapatalk
Old 08-14-2016, 17:53   #4 (permalink)
Member: 2554552
Thanks Meter: 21
do u have it ?
Old 08-14-2016, 21:35   #5 (permalink)
Member: 2457641
Thanks Meter: 153
http://f5b3bd6c415023f7ba1d-83a5609a...0T_PF2.tar.rar
thats the link, extract the boot img only
The Following User Says Thank You to ali2194 For This Useful Post:
Old 08-16-2016, 01:58   #6 (permalink)
Member: 996077
Thanks Meter: 19
can you post the already extracted and converted sboot?
Old 08-17-2016, 00:04   #7 (permalink)
Member: 2554552
Thanks Meter: 21
i think this is for j7oot , i am looking for j700t1
Old 08-22-2016, 04:21   #8 (permalink)
Member: 2457641
Thanks Meter: 153
This file works on both models
Sent from my SM-G935T using Tapatalk
Old 08-22-2016, 05:25   #9 (permalink)
Member: 2554552
Thanks Meter: 21
how to use it
Old 10-07-2016, 02:35   #10 (permalink)
Member: 2235918
Thanks Meter: 127
Ali2194. bro; is this one the combination file to bypass FRP on J700T? I'm lil confuse coz you wrote down the word "link" and this is a file. Can you explain, please? Thanks in advance. Br.
Old 10-07-2016, 02:51   #11 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
just use winrar than extract it then take only 1 boot.img then build.tar use cywin then flash via odin in AP then use Gcpro remove FRP done
The Following User Says Thank You to CHANDARAKK For This Useful Post:
Old 10-13-2016, 19:17   #12 (permalink)
Member: 2179929
Thanks Meter: 34
Originally Posted by chandarakk View Post
just use winrar than extract it then take only 1 boot.img then build.tar use cywin then flash via odin in ap then use gcpro remove frp done
more explation would be nice . :d
Old 03-18-2017, 15:51   #13 (permalink)
Member: 818177
Sonork: julian0309
is realy easy... extract this file put in pda in your z3x or use 7zip for open this file. and only take or use bootleader
flash this phone with this file and then use whatever program that do you have for reset frp... that is all and is easy... tell me if you need more help i can send send you a link with one video.
Old 03-18-2017, 17:28   #14 (permalink)
Member: 2395490
Thanks Meter: 515
Here the file. Only boot.img
https://mega.nz/#!1ZcETIha!TW2K_UH4g...If_0QwtuMctoIo
The Following 2 Users Say Thank You to Alexandroid For This Useful Post:
Old 05-22-2017, 21:17   #15 (permalink)
Member: 2719765
If I do this, will it wipe the device? I need to get past FRP, but I also need the information on the device so wiping is not an option.
Page generated in 0.29251 seconds with 8 queries
