Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 04-10-2018, 22:07   #1 (permalink)
CloseCOder's Avatar
Member: 2400231
Thanks Meter: 124
Question J727T Rev 3 Unlock help (solved)
I got a J727T with Rev 3 bootloader. I tried the old trick to read cert, wipe EFS and write cert but i keep getting error. I flashed combination and error as well. Is there any way to make the old method work or any other method?
Using Version...1.0.0.0056
Selected Port SAMSUNG Mobile USB Serial Port COM189
Selected Model Samsung GSM
Selected Task SAMSUNG Exynos Unlock
SAMSUNG Exynos Unlock started...
Searching phone...
Device Detected...
SELinux := Enforcing
model:= SM-J727T
ANDROID-ID = 5200ffa6b2d1b467_000015A33B
!!! Fail !!!!
Total Time Take...00:00:26
Searching phone...
Device Detected...
SELinux := Permissive
model:= SM-J727T
ANDROID-ID = 5200ffa6b2d1b467_0000B0AA35
Fail to read EMMC ID
Fail to detect phone Please make sure diag port is selected....1
!!! Fail !!!!
Total Time Take...00:00:25
The Following User Says Thank You to CloseCOder For This Useful Post:
Old 04-10-2018, 22:30   #2 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,645
Thumbs up for the info
Searching phone...
Device Detected...
model:= SM-J727T
!!! Fail !!!!
Searching phone...
Device Detected...
model:= SM-J727T
!!! Fail !!!!
http://forum.gsmhosting.com/vbb/f453...-bit3-2376644/
its here bro very clear very simple bro.
other link for info
http://forum.gsmhosting.com/vbb/f101...urity-2379565/
Old 04-10-2018, 23:35   #3 (permalink)
CloseCOder's Avatar
Member: 2400231
Thanks Meter: 124
Originally Posted by ghacks View Post
Works for the T-Mobile variant?
Old 04-10-2018, 23:57   #4 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,645
Thumbs up for info
signal searching i was thinking its sprint sorry bro i hear already tested but searching signal no signal coming up.
Old 04-11-2018, 05:29   #5 (permalink)
Member: 2107306
Thanks Meter: 612
Exactly why are you showing Exynos Unlock log? I'm curious. Are you able to read cert diag? Then wipe exynos efs? After that write_imei over uart.
Old 04-11-2018, 09:16   #6 (permalink)
CloseCOder's Avatar
Member: 2400231
Thanks Meter: 124
I have Z3X and it just throws errors when trying to read cert Diag. This log is from stock firmware
Operation: Read CERT DIAG
Selected model: SM-J727A
Software version: 31.2
Searching Samsung modem... detected COM188
Reading phone info...
Model: SM-J727T
AP version: J727TUVS3ARC1
CSC version: J727TTMB3ARC1
CP version: J727TUVS3ARC1
Product code: TMB
Phone SN: R28JB2T1XPF
IMEI: 355619085188397
Unique number: CAJ00FFA6B2D1B4
Searching Samsung diag port... detected COM189
Reading phone info... OK
CP build: Mar 5 2018 19:31:23
Reading data from phone... error (1)
This log is from flash combination file
Model: SM-J727T
AP version: FA70_J727TUVU3ARA1
CSC version: NONE
CP version: J727TUVU3ARA1
Reading phone info... error (0)
Check phone connection or KNOX WARRANTY VOID is 0x1
Knox is 0x0 so I don't know why the error occurred
Old 04-11-2018, 09:49   #7 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
@CloseCOder
Hello
J727T still no way to root or permissive if you can one of them you can still do via ASK/RPL option and credits.
Sad to say no way via diag its closed in RA and newer firmware.
The Following 2 Users Say Thank You to stanner_austin For This Useful Post:
Old 04-13-2018, 18:56   #8 (permalink)
Member: 2057260
Thanks Meter: 97
Originally Posted by stanner_austin View Post
@CloseCOder
Hello
I tried via server but no luck
Selected Model GT-I5500
Selected Task SAMSUNG T-MOBILE UNLOCK
Searching ADB device Please wait..
Device Detected...
model:= SM-J727T1
Androids Version:= 7.0
Description Version:= j7popeltemtr-user 7.0 NRD90M J727T1UVS3ARC1 release-keys
Platform:= exynos5 [ samsungexynos7870 ] [ SHANNON315 ]
Baseband:= J727T1UVS3ARC1
VER:= J727T1UVS3ARC1/J727T1TMK3ARC1/J727T1UVS3ARC1/J727T1UVS3ARC1
Carrier := TMK_USA
Knox Warranty := Not Void
AP UART Status := Disable.
Security Patch := 01-03-2018
Network Mode := LTE
Simstatus:= ABSENT
ANDROID-ID = 33004b20e40ac4e5_0000F2DBDE
Device is not rooted
SAMSUNG ALL TMB UNLOCKING STARTED...
Server Reply Error := ERR_Make Exynos Unlock First Then Unlock Again.
Fail to check server..ZYy5DQAxDMNWkuw4T+kn+68UX31gI4ACFbIa183BS5 gpUEgGHdNM0OvQOXnbKRMLE2xDFtv+PoPSrS5YLPuwgHilVoqc 2FV8
!!! Fail !!!!
Restart Phone Manually if not done auto...
Old 04-13-2018, 19:43   #9 (permalink)
Member: 49752
Thanks Meter: 6,085
Hello
Please keep your sales spam out of our section.
Second if you read carefully http://forum.gsmhosting.com/vbb/13072387-post7.html
You will understand what i said. if you can not understand sorry i dont know how to help you..
Old 04-15-2018, 18:00   #10 (permalink)
Member: 2334540
Thanks Meter: 12
all you have to do it download the RA1 combo flash the modem and unlock and read cert like normal
Old 04-15-2018, 18:01   #11 (permalink)
Member: 2334540
Thanks Meter: 12
@CloseCOder
Hello
NO sir you can flash the RA1 combo modem and then read cert Via Diag
The Following 2 Users Say Thank You to iluvny For This Useful Post:
Old 04-28-2018, 16:04   #12 (permalink)
Member: 92260
Thanks Meter: 843
This is true, and actually all you need to do is flash the
J727U_UVU3ARA1_v7.0.0 Modem only which allows HWID Diag read.
The Following User Says Thank You to BillA For This Useful Post:
Old 04-29-2018, 16:39   #13 (permalink)
luisy's Avatar
Member: 2352896
Thanks Meter: 116
Can I flash "U" firmware in a "T" or "T1" phone? Will be nice cause "U" firmware is unbranded.
Old 05-03-2018, 07:32   #14 (permalink)
Member: 92260
Thanks Meter: 843
Yes I've tried it, and it gives a nice unbranded UI.
Use the latest Samsung_Odin_v3.13.1_Patched from here:
https://www.androidfilehost.com/?fid=673956719939831735
By the way the "U" firmware only works on the gsm/lte versions "A", "T", and "T1", but don't believe it will work on the cdma/lte versions "P" and "V".
For the last two models you can try the XAS and LRA versions respectively if they exist, though I haven't tried them myself.
The Following 4 Users Say Thank You to BillA For This Useful Post:
Old 05-03-2018, 09:05   #15 (permalink)
Cheater -Don't Deal with him-
Member: 2512574
Thanks Meter: 29
You phone Metro Pcs ?
Page generated in 0.24142 seconds with 8 queries
