Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 02-12-2019, 06:15   #1 (permalink)
Member: 2551465
Thanks Meter: 56
Reparar Imei Certi Fail J727p Binario 4
1 poner en modo descarga el j727p
2 buscan el puerto que genera en modo descarga
3 seleccionan en e modelo samsung gsm
4 buscan el las opciones modemstx_reset
5 le dan start
gc pro resetiar las particiones del modem y asi mismo reparando el imei certi fail y al encender marcan *#0011# y veran que el imei certi quedara pass
The Following User Says Thank You to CelularCris For This Useful Post:
Old 02-12-2019, 09:02   #2 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
@CelularCris
Hello
This forum is english only. if you need help post your question in english.
Old 02-12-2019, 11:22   #3 (permalink)
Member: 2148129
Thanks Meter: 42
5 le dan start
Olle muy bueno. No sabia sobre esta opcion. Muchas gracias por el aporte.
Old 02-12-2019, 13:49   #4 (permalink)
Member: 1422878
Thanks Meter: 164
El forum es en ingles, pero ojala se dieran tan buenas soluciones como esta q esta en espaņol
The forum is in English, but hopefully they gave as good solutions as this is in Spanish
Repair Imei Certi Fail J727p Binary 4
1 put in download mode the j727p
2 look for the port that generates in download mode
3 select in e model samsung gsm
4 search the modemstx_reset options
5 give you start
gc pro reset the modem partitions and likewise repairing the imei certi fail and on power up they dial * # 0011 # and you will see that the certi imei will remain pass
The Following User Says Thank You to helpinterchange For This Useful Post:
Old 02-13-2019, 06:47   #5 (permalink)
Member: 2551465
Thanks Meter: 56
Repair Imei Certi Fail J727p Binario 4
1.- Put in download mode the j727p
2.- Select on the samsung GSM model
3.- search modemstx_reset options
4.- they give start
gcpro reset the modem partitions and likewise repairing the imei certi fail and on power up they dial * # 0011 # and you will see that the certi imei will remain pass
Old 02-13-2019, 12:15   #6 (permalink)
Member: 2620145
Thanks Meter: 319
https://www.gsmhelperteam.info/2019/...pD7qjTq6AXBY7g
4.- they give start
Old 02-14-2019, 14:43   #7 (permalink)
Member: 852991
Thanks Meter: 19
if imei cert fail
check meid and imei if match if doesn't it give imei cert fail all need to do is repair meid and you all good
The Following User Says Thank You to thee011 For This Useful Post:
Old 07-05-2019, 18:16   #8 (permalink)
Member: 1793498
Thanks Meter: 3
hi i need help whit a samsung j727p bit 5 imei cert fail how to repair
Page generated in 0.15701 seconds with 8 queries
