07-26-2016, 03:51 | #1 (permalink) |
Insane Poster Join Date: May 2016
Member: 2575895 Status: Offline Thanks Meter: 10 | Lg Stylo 2 Boost mobile ( LS775) No service after unlock I see this phone has a GSM mode in the mobile network settings and The APN can be edited as well. But when I insert a Tmobile USA sim, the phones Searches forever and then Say no signal. When I insert a foreign sim card it shows both ATT and Tmobile Networks as selectable Roaming networks. If I were to go to a Different country other than the USA, will this Phone work on the Foregin GSM network? I don't want to use the phone In the USA anyways. |
07-26-2016, 22:37 | #8 (permalink) | |
No Life Poster Join Date: Oct 2013
Member: 2051392 Status: Offline Thanks Meter: 161 | Quote:
Sent from my SM-N920T using Tapatalk | |
07-26-2016, 22:52 | #10 (permalink) | |
07-26-2016, 23:43 | #12 (permalink) |
Insane Poster Join Date: Nov 2013 Location: Florida USA
Member: 2057592 Status: Offline Thanks Meter: 6 | I have the same issue with one I unlocked. Phone has clean imei, no invalid sim message. It gets signal for a moment then cuts out and does not establish signal again |
08-21-2016, 16:30 | #15 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | You may want to try a couple of things ... 1. With QuickShortcut search for "ROAM" Try all the activities till you find the one with network select manual/auto, set to auto if selectable, roaming allow ALL, roam guard all OFF. 2. Enable GCF either via shortcut or preferably via NV item. We need a way to read the spc/msl especially for nv read/write. Octo seems to read it through the logcat/syslog or radiolog while entering ##3424# |
The Following User Says Thank You to BillA For This Useful Post: |
