01-24-2019, 05:30 | #1 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Minneapolis MN USA
Member: 1815016 Status: Offline Thanks Meter: 77 | LS775 Bypass Locks Problem ...Port list start... LGE AndroidNet USB Serial Port (COM409) LGE AndroidNet USB Modem #76 (COM408) ...Port list end... Using Version...1.0.0.0062 Selected Port LGE AndroidNet USB Modem #76 COM408 Selected Model GT-I5500 Selected Task Enable ADB Bypass Locks Searching Phone... Sw Version = LS775ZV9_01 OK IMEI = 3563040715xx Done Enjoy... Total Time Take...00:00:01 Log Saved |
01-24-2019, 05:42 | #2 (permalink) |
Member: 1815016 Status: Offline Thanks Meter: 77 | Add note: This problem seem to affect all models. Have also verified same problem with V521 tablet. Locks bypass successful but no file access via MTP afterwards. If make restart, then yes MTP access. But also screen lock return again |
01-25-2019, 06:42 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello As far as i understand your issue is you want to change mode your self instead software do for you ? what stop you to go to setting enable developer mode off and on again? and set keylock ur own code ? or backup via adb etc ? i can add what you requested about optional adb enable when bypass. so ur old always mode stick. |
01-25-2019, 17:31 | #4 (permalink) | |
Member: 1815016 Status: Offline Thanks Meter: 77 | Quote:
1. Unless phone was already set in File Transfer mode before lock was enable, cannot enable File Transfer mode when lock is bypass. Always stay in Charging mode. Even if select File Transfer, USB mode not change - MTP not enable. Can send video for proof if you want, but try yourself and you will see. 2. Keylock cannot be changed. This operation is bypass - not remove. For change keylock, must be enter current keylock. And no way to know current keylock. Also, keylock required for remove Google account or enable OEM unlocking, so even after bypass, only option to continue to use device is factory reset via recovery menu which means FRP will be enable. Can send video for proof if you want, but try yourself and you will see. | |
01-25-2019, 18:14 | #5 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @namos23 Hello About not tested how you think it's enable adb and let you access phone ? If you can't understand some part avoid saying we did not tested our self. About mode change its because bypass do enable adb and its stick to that mode only. As i said before i can add optional method to skip enable for that need such device. Contact on skype. |
01-25-2019, 18:18 | #6 (permalink) |
Freak Poster Join Date: Feb 2015 Location: L&J_CUBA
Member: 2352896 Status: Offline Thanks Meter: 116 | @namos23; If this procedure bypass locks instead remove them, but works in new security means SUCCESS for me. It means you can bypass, save all data on phone and then hard reset, frp... But you can save your data. This is wonderfull thing. AT least for me. Just saying... |
01-25-2019, 19:10 | #7 (permalink) | |
01-25-2019, 20:35 | #8 (permalink) | |
Member: 2352896 Status: Offline Thanks Meter: 116 | Quote:
well, when I say "you" I mean all us. But it is a very important thing. | |
