Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 03-06-2019, 20:44   #1 (permalink)
japunlock's Avatar
Member: 87396
Thanks Meter: 64
n960u unlock via msl
hello
i was wondering if this phone can be unlocked via MSL code using gcpro
can anybody confirm?
Old 03-06-2019, 22:00   #2 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,273
Originally Posted by japunlock View Post
hello
Which carrier?? Tmb spr AT&T??
Old 03-07-2019, 03:04   #3 (permalink)
Member: 2148129
Thanks Meter: 42
N960U is a MSLcert based phone. Using MSL Code is a waste of money.
The Following User Says Thank You to chicofiebru For This Useful Post:
Old 03-07-2019, 04:14   #4 (permalink)
GsmServerEcuado's Avatar
Member: 2871022
Sonork: BestResellerEcuador
Thanks Meter: 36
brother that company is
Old 03-07-2019, 08:45   #5 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
@japunlock
Hello
Please attach readinfo adb log before making question. without carrier we can not advice.
Any model newer then S9 is use MSLCERT msl code is not going work on such device. we have mslcode service but not have mslcert service at present.
If its application locked gcpro will support it in coming updates. if it's anything else will take some time to support it.
The Following User Says Thank You to stanner_austin For This Useful Post:
Old 03-11-2019, 03:25   #6 (permalink)
japunlock's Avatar
Member: 87396
Thanks Meter: 64
Thank you for your answers I don't have read info via adb log right now but it is 1 n960u phone locked, operator logo at startup only says spectrum, I will have to order factory unlock code from any other source
It does ask for unlock code, not app locked phone
Old 03-11-2019, 12:40   #7 (permalink)
Member: 2148129
Thanks Meter: 42
Just order unlock code. no need to do nothing else
Old 03-11-2019, 15:48   #8 (permalink)
Member: 2598737
Thanks Meter: 4
Is Note 9 sprint unlockable ?
Old 03-11-2019, 20:28   #9 (permalink)
reyxito's Avatar
Member: 2549748
Thanks Meter: 212
yes but not with this tool
Old 03-12-2019, 12:06   #10 (permalink)
Member: 2148129
Thanks Meter: 42
Yes it is unlockable and very easy
Old 03-14-2019, 04:48   #11 (permalink)
Member: 1744748
Thanks Meter: 752
Yes, you need 2 things,
Read your original Note 9 cert (you need this)
Wipe efs on the Note 9 (this will unlock your Note 9)
Write back the cert for your Note 9 (if you dont do this imei will be 000 and no network)
Thanks,
Old 03-15-2019, 04:56   #12 (permalink)
shedeed's Avatar
Member: 527884
Sonork: 100.1583794
Thanks Meter: 850
Thanks,
I know all this but how ! I know that imeigurus service tool supported it but its need activation or something like this by enable cp debugging to high then low read cert using upload mode then wipe efs and finally writing cert
Page generated in 0.20424 seconds with 8 queries
