09-17-2014, 08:09 | #1 (permalink) |
Junior Member Join Date: Dec 2009 Location: Delhi, India
Member: 1186495 Status: Offline Thanks Meter: 7 | Micromax A51 pattern lock fail (SOLVED SUCCESS) however its showing there SU Version..3.30:kinguser_s it means its rooted. here is log... Using Version...1.0.0.0006 Selected Model Selected Task GTALK REMOVE SAFE Searching ADB device Please wait.. Device Detected... model:= Micromax A51 Androids Version:= 2.3.7 Description Version:= brcm_bcm21553-user 2.3.7 REL_2.3.12 eng.root.20130227.143144 release-keys Platform:= bcm21553 Device Hardware:= bcm21553 Baseband:= BCM2155x_CustomerRel_2_3_12_DS_P7 Simstatus:= ABSENT BOOT:= unknown IMEI-1 = 911311000237601 IMEI-2 = 911311000237619 ANDROID-ID = A51_911311000237601 Detected su binary at /xbin Detected su binary at /bin SU Version..3.30:kinguser_s !! NOT ROOTED !! NO SU PERMISSION RE ROOT DEVICE OR GRANT/ACCEPT PERMISSION... BusyBox version := 1.10.4 Repair Gtalk/pattern/lock code started.. NON ROOTED DEVICE CAN NOT CONTINUE... Job fail with error.. Killed adb All job finish.. Restart Phone Manually before doing anything... Total Time Take...00:00:01 Log Saved |
09-17-2014, 09:21 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello not fail. its super su protection not allow phone even if its rooted. use option EMERGENCY CALL then see if its ask for accept grant or not. else use any shell root option to get unsecure root. ps: i can see 2 su binary in /system .. this issue can be fix by online team viewer or ammy if you still have in hand. ps2: you can always use custom recovery and remove pattern option too. Regards, Chevli |
The Following User Says Thank You to stanner_austin For This Useful Post: |
09-17-2014, 10:37 | #3 (permalink) |
Member: 1186495 Status: Offline Thanks Meter: 7 | Thanks Sir its done after granting permission in emergency mode. here is the logs.... Using Version...1.0.0.0006 Selected Model Selected Task GTALK REMOVE SAFE Searching ADB device Please wait.. Device Detected... model:= Micromax A51 Androids Version:= 2.3.7 Description Version:= brcm_bcm21553-user 2.3.7 REL_2.3.12 eng.root.20130227.143144 release-keys Platform:= bcm21553 Device Hardware:= bcm21553 Baseband:= BCM2155x_CustomerRel_2_3_12_DS_P7 Simstatus:= ABSENT BOOT:= unknown IMEI-1 = 911311000237601 IMEI-2 = 911311000237619 ANDROID-ID = A51_911311000237601 Detected su binary at /xbin Detected su binary at /bin SU Version..3.30:kinguser_s Device is Secure Rooted..uid=0 BusyBox version := 1.10.4 Repair Gtalk/pattern/lock code started.. Reading Backup File... Access Found Type 2. Removing Lock... Saving work... Uploading Stuff.. File Update ok.... Repair Success.. Killed adb All job finish.. Restart Phone Manually before doing anything... Total Time Take...00:00:42 Log Saved |
The Following User Says Thank You to Bansilal For This Useful Post: |
