Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 09-17-2014, 08:09   #1 (permalink)
Member: 1186495
Thanks Meter: 7
Micromax A51 pattern lock fail (SOLVED SUCCESS)
Error while removing pattern lock, giving error NON ROOTED DEVICE CAN NOT CONTINUE...
however its showing there SU Version..3.30:kinguser_s
it means its rooted. here is log...
Using Version...1.0.0.0006
Selected Model
Selected Task GTALK REMOVE SAFE
Searching ADB device Please wait..
Device Detected...
model:= Micromax A51
Androids Version:= 2.3.7
Description Version:= brcm_bcm21553-user 2.3.7 REL_2.3.12 eng.root.20130227.143144 release-keys
Platform:= bcm21553
Device Hardware:= bcm21553
Baseband:= BCM2155x_CustomerRel_2_3_12_DS_P7
Simstatus:= ABSENT
BOOT:= unknown
IMEI-1 = 911311000237601
IMEI-2 = 911311000237619
ANDROID-ID = A51_911311000237601
Detected su binary at /xbin
Detected su binary at /bin
!! NOT ROOTED !! NO SU PERMISSION RE ROOT DEVICE OR GRANT/ACCEPT PERMISSION...
BusyBox version := 1.10.4
Repair Gtalk/pattern/lock code started..
Job fail with error..
Killed adb All job finish..
Restart Phone Manually before doing anything...
Total Time Take...00:00:01
Log Saved
Old 09-17-2014, 09:21   #2 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
Hello
not fail.
its super su protection not allow phone even if its rooted.
use option EMERGENCY CALL then see if its ask for accept grant or not.
else use any shell root option to get unsecure root.
ps: i can see 2 su binary in /system .. this issue can be fix by online team viewer or ammy if you still have in hand.
ps2: you can always use custom recovery and remove pattern option too.
Regards,
Chevli
The Following User Says Thank You to stanner_austin For This Useful Post:
Old 09-17-2014, 10:37   #3 (permalink)
Member: 1186495
Thanks Meter: 7
Thanks Sir its done after granting permission in emergency mode.
here is the logs....
Selected Model
Device Detected...
Platform:= bcm21553
Simstatus:= ABSENT
BOOT:= unknown
Device is Secure Rooted..uid=0
Reading Backup File...
Access Found Type 2.
Removing Lock...
Saving work...
Uploading Stuff..
File Update ok....
Repair Success..
Total Time Take...00:00:42
Log Saved
The Following User Says Thank You to Bansilal For This Useful Post:
Page generated in 0.22873 seconds with 8 queries
