Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 04-28-2018, 13:42   #16 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,051
@MbashirAjmal
Hello
If you want to do over uart as you selected UART
Serial Port COM74
Please unplug phone from usb and connect PHONE to uart before Enter port when software ask.
If you want to do over modem port Select Modem port.
Old 04-28-2018, 14:05   #17 (permalink)
Member: 2759294
every trick not working
can you work via teamviewer
please help me
Old 05-20-2018, 16:01   #18 (permalink)
Member: 2456921
Thanks Meter: 46
can anyboy post eng root for this phone?
Old 06-25-2018, 03:35   #19 (permalink)
Member: 2437020
Thanks Meter: 2
Confirmed, works wonders ,,, Thanks GCPRO team
Old 06-25-2018, 09:41   #20 (permalink)
Member: 49752
Thanks Meter: 6,051
@Dananmerida
Hello
Please post success log so other can see its work.
Old 08-03-2018, 01:24   #21 (permalink)
Member: 2710649
Thanks Meter: 46
Using Version...1.0.0.0058
Selected Port SAMSUNG Mobile USB Modem #33 COM45
Selected Model GT-I5503
Selected Task SAMSUNG RLOCK_ADB
Searching ADB device Please wait..
Device Detected...
Security:= OFF Unsecure device
SELinux := Permissive
model:= SAMSUNG-SM-N910A
Androids Version:= 6.0.1
Description Version:= trlteuc-user 6.0.1 MMB29M N910AUCU2EPH5 release-keys
Platform:= apq8084 [ qcom ] [ MDM9225M ]
Baseband:= N910AUCU2EPH5
VER:= N910AUCU2EPH5/N910AATT2EPH5/N910AUCU2EPH5/N910AUCU2EPH5
Carrier := ATT_USA
EFS CSC := ATT
Knox Warranty := Not Void
Security Patch := 01-08-2016
Network Mode := LTE
Simstatus:= ABSENT
ANDROID-ID = 63d6dad0_00007A42A7
Device is Unsecure Rooted
SAMSUNG RLOCK_ADB UNLOCK STARTED...
Phone Found Wait...
Model := AT+SW
VER := AT+SWVERSION=1,0
Model := SM-N910A
SWVer := N910AUCU2EPH5
UNIQID := CR20063D6DAD081
Phone IMEI := 35448306132426
REACTIVATION LOCKED...
REACTIVATION DISABLE SUCCESS...
Please Reflash such phone...
!!! Success !!!!
Total Time Take...00:02:13
Log Saved
The Following User Says Thank You to Christina714 For This Useful Post:
Old 08-21-2018, 17:20   #22 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 938
Can be confirmed ... it work
It work ... 6.0.1
N910AUCS2EPH7 release-keys
Platform:= apq8084 [ qcom ]  [  ]
Warning Baseband is Unknown or damaged....
VER:= N910AUCS2EPH7/N910AATT2EPH7/N910AUCS2EPH7
Carrier := ATT_USA
EFS CSC := ATT
Knox Warranty := Void
Security Patch := 01-09-2016
Network Mode := 0
Simstatus:= ABSENT
ANDROID-ID = 29b0c259_00007B6466
Starting RLOCK Remove.
Phone Found Wait...
Model := N910A
VER := N910AUCS2EPH7/N910AATT2EPH7//N910AUCS2EPH7
Phone IMEI := null/empty
!!! Success !!!!
Total Time Take...00:01:23
Log Saved
The Following User Says Thank You to debeliamark For This Useful Post:
Old 10-02-2018, 08:06   #23 (permalink)
Member: 2687410
Using Version...1.0.0.0059
Selected Port SAMSUNG Mobile USB Modem #14 COM53
Selected Model SM-N910A
Device Detected...
Androids Version:= 5.1.1
Description Version:= trlteuc-user 5.1.1 LMY47X N910AUCU2DOI2 release-keys
Baseband:= N910AUCU2DOI2
VER:= N910AUCU2DOI2/N910AATT2DOI2/N910AUCU2DOI2/N910AUCU2DOI2
Carrier := ATT_USA
EFS CSC := ATT
AP UART Status := Disable.
Network Mode := 0
Simstatus:= ABSENT
ANDROID-ID = ca67d090_00009F888B
SU Version..kingo 141
Device is Secure Rooted..uid=0
System Permission is Read/Write...
Starting RLOCK Remove...
Saving Backup...
Preparing for RLOCK Remove..
Phone Found Wait...
Model := N910A
VER := N910AUCU2DOI2/N910AATT2DOI2/N910AUCU2DOI2/N910AUCU2DOI2
!!! Success !!!!
Total Time Take...00:01:10
The Following User Says Thank You to Rychy_Breezy For This Useful Post:
Old 10-16-2018, 12:16   #24 (permalink)
Member: 92260
Thanks Meter: 802
Did you flash it with combination firmware, and why is the imei null//empty?
Old 10-20-2018, 09:33   #25 (permalink)
Member: 49752
Thanks Meter: 6,051
@BillA
Hello
Its not read over usb/uart some time due to eng boot/root conflict.. that's no issue.. reflash and all is good to go.
The Following User Says Thank You to stanner_austin For This Useful Post:
Old 11-20-2018, 09:57   #26 (permalink)
Member: 92260
Thanks Meter: 802
Originally Posted by Celhack View Post
Using Version...1.0.0.0054
Selected Port ssudmdm0027 = COM93
Selected Model SM-N910T
Device Detected...
model:= SM-N910T
Description Version:= trltetmo-user 6.0.1 MMB29M N910TUVS2EPK2 release-keys
Baseband:= N910TUVS2EPK2
VER:= N910TUVS2EPK2/N910TTMB2EPK2/N910TUVS2EPK2/N910TUVS2EPK2
Carrier := TMB_USA
EFS CSC := TMB
Security Patch := 01-11-2016
Network Mode := LTE
Simstatus:= ABSENT
ANDROID-ID = a612e497_0000A81D04
Phone Found Wait...
Model := AT+SW
VER := AT+SWVERSION=1,0ERROR
Phone IMEI := AT+IMEITEST=1,
Fail to get reply...NYrBDcAgDANXIiGB8gS1rHH7b1ESCck6WWeLIA0buA WjfEjKE13UfjnRFqu9uGIbf/CZZlBLmvPpPw==
!!! Fail !!!!
Total Time Take...00:00:41
Log Saved
Try enabling the modem port properly via the following adb/at commands.
Just remember some commands may fail, while other may work.
You may have to experiment a bit to see what works for you.
Sometimes the solution is as simple as plugging the phone into another usb port or another computer.
ADB+Diag+Modem
adb shell setprop sys.usb.config diag,acm,adb
adb shell setprop persist.usb.eng 1
adb shell setprop usb.rndis.enable 1
adb shell echo 1 > /sys/class/usb_composite/modem/enable
You can try to force the USBSettings activity to pop up on the setup screen via:
adb shell am start -n com.sec.modem.settings/com.sec.modem.settings.usbsettings.USBSettings
OR
adb shell am start -n com.sec.android.app.phoneutil/com.sec.android.app.phoneutil.USBSettings
OR to enable uart
adb shell echo 1 > /sys/class/sec/switch/uart_en
May need to restart the phone after finishing all the command via
adb shell reboot
OR
You can play around with these AT commands to enable usb/modem:
AT+UARTSWIT
AT+USBCHANG
AT+USBMODEC
AT+USBMODEM
And here are some test command to try but be careful
AT+AIRPLANEVALUE
AT+BATGETLEVEL - ?
AT+CIMI
AT+DEVCONINFO - Long info
AT+FACTORST - ?
AT+FUS? - DL mode
AT+GSN - IMEI
AT+IMEINUM
AT+SERIALNO
AT+SIZECHECK - Storage info
AT+SIZECHECK=1,0 - Storage info
AT+SVCIFPGM=1,1 - Short Info
AT+SWDLMODE - ??
AT+SWVER=1,0
AT+SWVERSION=1,0
AT+SYSSCOPE=1,0
AT+WPROTECT=1,0
Some AT commands may require a sufix at the end:
=1,0/1 - Read value
=2,0/1 - Write value
Old 11-22-2018, 01:24   #27 (permalink)
Member: 416710
Thanks Meter: 391
ADB+Diag+Modem
OR
OR to enable uart
adb shell reboot
OR
AT+UARTSWIT
AT+USBCHANG
AT+USBMODEC
AT+USBMODEM
AT+AIRPLANEVALUE
AT+BATGETLEVEL - ?
AT+CIMI
AT+FACTORST - ?
AT+FUS? - DL mode
AT+GSN - IMEI
AT+IMEINUM
AT+SERIALNO
AT+SWDLMODE - ??
AT+SWVER=1,0
AT+SWVERSION=1,0
AT+SYSSCOPE=1,0
AT+WPROTECT=1,0
=1,0/1 - Read value
Thanks bro, I will have in mind next time. I did that one with nonhlos trick.
Page generated in 0.37095 seconds with 7 queries
