09-04-2016, 18:21 | #1 (permalink) |
Banned Join Date: Jan 2014 Location: Havana, Cuba Age: 40
Member: 2107306 Status: Offline Thanks Meter: 612 | N930P service menu gcf activation ? Does anyone have any clue about how to enter service mode in order to achieve gcf activation for full gsm signal? Any help is apreciated. Thanks in advance. |
The Following User Says Thank You to Prsctt For This Useful Post: |
09-04-2016, 20:06 | #2 (permalink) | |
No Life Poster Join Date: Aug 2015 Location: usa
Member: 2444830 Status: Offline Thanks Meter: 162 | Quote:
After that you're going to need to click the menu > key input > Q, menu > back, menu > key input > 0000. Wait for about 20 seconds then a menu will appear. Once the menu appears go to: >UE SETTING & INFO >SETTING >PROTOCOL >GCF >GSM/(E)GPRS/WCDMA GCF ON | |
09-05-2016, 23:36 | #4 (permalink) | |
Member: 2107306 Status: Offline Thanks Meter: 612 | Quote:
Thanks for the replay. Already did that. When I post that problem is cause I tried everything in my hands and search in this forum. Thanks anyway. | |
09-06-2016, 05:39 | #5 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2545921 Status: Offline Thanks Meter: 7 | On 6.0.1 settings activate this phone vol- vol- vol+ vol+ vol+ vol- [shows the service mode] testmode->settinginfo->setting->protocol->gcf->gsm(e)gprs/wcdma gcf on restart phone |
09-06-2016, 06:23 | #6 (permalink) | |
Interesting solution yours as it is the same I posted for other threads to users in this forum. You should be tagged as copy/paster. Ohh and, does not work on n930p. | |
09-09-2016, 00:14 | #8 (permalink) | |
My apologies then. It seems that I'm the only one that uses the "search" button before asking for a solution. Other ppl should do the same. Anyways, are you trying to help or just being a laywer? Thanks in advance. | |
09-11-2016, 00:11 | #10 (permalink) |
Member: 2107306 Status: Offline Thanks Meter: 612 | If you were to live here in my country, using GSM 2g networks, you wont be thinking like that. In my case, if I dont use gcf activation, cellphone gets coverage and when loses it, you have to restart phone in order to obtain it again. Hope you understand my situation. I was having that issue with g920/g930p and gcf saved my life. |
The Following 2 Users Say Thank You to Prsctt For This Useful Post: |
09-12-2016, 09:21 | #11 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | Quote:
@Prsctt Did you found the GCF activation workaround in Sprint Note 7? | |
09-12-2016, 09:43 | #12 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @jepetu Hello GCF ENABLE is added in gcpro long time. just unlock phone without root make sure diag port is selected with ##3424# while unlocking. |
The Following 2 Users Say Thank You to stanner_austin For This Useful Post: |
09-13-2016, 18:54 | #14 (permalink) |
Member: 2107306 Status: Offline Thanks Meter: 612 | Hehehe Dont know others, but I will pay anything to samsung if they block ANY device using here in Cuba. @Jepetu I'll try stanner's solution today in the night and post results. Wish me luck. |
