Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 09-21-2016, 07:04   #1 (permalink)
atinder_2006's Avatar
Member: 1809913
Thanks Meter: 35
Note 5 ATT SM-N920A PH4 FRP eng boot help needed
Flashed wrong boot.img and now phone is stuck at samsung.
I saw gcpro could help on eng boot and if someone could possible give me stock N920AUCS3BPH4 boot.img or whole firmware would be appreciated.
Checking Card Ok.
Verify Card verify ok...
Card OsVer 0001
GCPro SN:= [GC207E87A1]
GCPRO Activation := CARD IS ACTIVE
Old 09-27-2016, 00:34   #2 (permalink)
Member: 1239608
Sonork: dombronx
Thanks Meter: 39
hi friend, here is the stock firm n920a ph4
download, just hit thanks
The Following 10 Users Say Thank You to dombronx For This Useful Post:
Old 09-27-2016, 00:46   #3 (permalink)
Member: 2202707
Sonork: Tomelich
Thanks Meter: 175
hello friend just in case you had software s5 active G870A vertion G870AUCU2DPH2 or G870AUCS2DPH3
I would greatly appreciate it friend
Old 09-28-2016, 23:02   #4 (permalink)
Member: 1239608
Sonork: dombronx
Thanks Meter: 39
Hi friend, welcome, i dont have that file , but in your case you can use KIES 3 or SMART SWITCH to upgrade to latest firmware available to your phone, just search in google how to, and you will get success.
Old 10-07-2016, 00:43   #5 (permalink)
Member: 1946334
Thanks Meter: 16
frp N920A PH4 FIX?
ive been waiting for a bypass or files to flash..
is there a solution?
files?
if anyone has any info please say...
Old 10-07-2016, 02:54   #6 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,170
Originally Posted by DUMB-LUCK View Post
frp N920A PH4 FIX?
files?
use combin firmware then remove Done
Old 10-10-2016, 18:23   #7 (permalink)
Member: 1295987
Thanks Meter: 4
can u give a link for n920a ph2 combination
Old 10-10-2016, 19:16   #8 (permalink)
Member: 1295987
Thanks Meter: 4
can u give a link for n920a ph4 combination or eng
Old 10-10-2016, 19:53   #9 (permalink)
Member: 2343867
Thanks Meter: 2
do you have the G928A files I need to remove FRP PH4 cant find anywhere
Old 10-11-2016, 20:52   #10 (permalink)
Member: 1295987
Thanks Meter: 4
who have the n920a ph4 eng boot?
Old 10-12-2016, 04:02   #11 (permalink)
Member: 2306078
Sonork: 1660961
Thanks Meter: 19
yes i have combination for N920AUCU3APH2_FACTORY_user_mid_noship
Contact me if you want
Old 10-25-2016, 02:27   #12 (permalink)
Member: 592944
Thanks Meter: 2
I bought the PH3 combination file for N920A but it doesn't let me flash it. It gives the same error as when I try to downgrade. The phone is a PH3 version but I was told that it should be able to flash. Any ideas?
This is the file I'm trying to flash: COMBINATION_FA51_N920AUCU2APH3_CL6053901_QB1070049 9_REV00_user_mid_noship
Old 10-25-2016, 03:00   #13 (permalink)
jepetu's Avatar
Member: 181633
Thanks Meter: 607
Sorry but you bought the wrong file or you have been cheated because N920AUCU2APH3 in your file means rollback bit protection "2" and you need "3"
This is the file you need:
COMBINATION_FA51_N920AUCU3APH1_CL6053901_QB1060808 3_REV00_user_mid_noship.tar
Old 10-25-2016, 03:51   #14 (permalink)
Member: 592944
Thanks Meter: 2
Got it, ok thank you very much for that. So I'm guessing COMBINATION_FA51_N920AUCU3APH2_CL6053901_QB1064908 1_REV00_user_mid_noship.tar will work?
Old 10-25-2016, 06:45   #15 (permalink)
Member: 2335578
Thanks Meter: 105
Yes will work
Sent from my SM-N930T using Tapatalk
Page generated in 0.32158 seconds with 7 queries
