07-27-2018, 16:58 | #1 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Puerto Rico
Member: 2549748 Status: Offline Thanks Meter: 212 | Problems with uart port gcpro(SOLVED) Using Version...1.0.0.0058 Selected Port USB Serial Port COM13 Selected Model GT-I5500 Selected Task SAMSUNG DRK FIX Started Samsung DRK Fix... No reply on samsung mode.. DIAL *#0*# AND TRY AGAIN... !!! Fail !!!! Total Time Take...00:01:13 Log Saved |
07-27-2018, 17:19 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @reyxito Hello I advice you to read one time basic helpfiles C:\GCPro_Team\Helpfiles\How to work with UART If you already read make sure your phone baseband is valid without baseband you can not use modem functions such as uart or imeicert write etc. Phone should be in normal mode with baseband working not invalid or unknown to use drk repair. |
07-27-2018, 17:28 | #3 (permalink) | |
Member: 2549748 Status: Offline Thanks Meter: 212 | Quote:
thanks for fast replying... the phone stuck in recovery mode and says drk error dnt pass to normal | |
07-28-2018, 04:27 | #4 (permalink) |
Freak Poster Join Date: Aug 2014 Location: Dominican Republic
Member: 2235918 Status: Offline Thanks Meter: 127 | Man, your phone’s running 7.0 nougat version and, I must ask: Can you fix drk on 7.0? I’m just asking. |
The Following User Says Thank You to Nile56 For This Useful Post: |
07-28-2018, 09:55 | #6 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @reyxito Hello DRK Repair only work if phone is alive. some phones can be alive with root on your case bootloader locked so you can not use this way. other way is combination as you said there is no U3 combination .. only option for you is wait till stock and combination come available . |
07-29-2018, 20:28 | #7 (permalink) | |
can someone help me with this | |
07-29-2018, 20:50 | #8 (permalink) |
Member: 2549748 Status: Offline Thanks Meter: 212 | I already solved it... maybe uart port driver issue... I used the z3x rj45 port and work perfectly |
The Following User Says Thank You to reyxito For This Useful Post: |
