12-29-2016, 22:56 | #1 (permalink) | |
Freak Poster Join Date: Nov 2013 Location: Venezuela-Falcon
Member: 2074524 Status: Offline Sonork: 100.1627435 Thanks Meter: 135 | Repair Samsung G928V Done Quote:
02-02-2017, 20:45 | #4 (permalink) |
Major Poster Join Date: Nov 2014
Member: 2286905 Status: Offline Thanks Meter: 6 | How do you repair this problem? If you do IMEICERT Write and then phone has no signal? I am trying to do a MEID Cert Write, but when I press on the phone *#0808# or *#0*# I get error message Mobile Network Not Available. Please help. Thank you |
02-03-2017, 22:43 | #6 (permalink) |
Member: 2286905 Status: Offline Thanks Meter: 6 | I used a g928P cert. But did a IMEICERT write and the g928V phone shows no signal. I want to do MEID Cert write buy I can't get phone to talk to box using *#0808# or *#0*# commands |
02-03-2017, 23:10 | #7 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 442504 Status: Offline Thanks Meter: 4 | I am not familiar with GCpro Key but does it match the ESN when it writes the certificate.?. If you than you have to use CDMA workshop and match your ESN to the imei to get signal Also I know how to enable diagonostic port with Octopus but do not know if same procedure will work with GCpro |
The Following User Says Thank You to harrybh For This Useful Post: |
02-06-2017, 11:55 | #8 (permalink) |
Freak Poster Join Date: May 2015 Location: Los Angeles Age: 29
Member: 2400231 Status: Offline Thanks Meter: 124 | Trick is to have UART cable connected to phone. Reboot phone and then dial *#0# the menu will show up. Unplug cable then replug to make sure it works and then use any box like octoplus or z3x to write MEID cert |
The Following 2 Users Say Thank You to CloseCOder For This Useful Post: |
